Locking objects and threads
  1. Dec 4, 2007 #1
    I have a server set up which can accept multiple clients in different threads. Now the server keeps track of all client activities using a log feature which writes directly to a txt file. But soemtimes I notice when there are a lot of clients requesting there is an IOException becuase another process is using the log file. How do I synchronize or lock them? please help. I'm using C#.
  3. Dec 4, 2007 #2
    jim mcnamara
    Staff: Mentor
  4. Dec 7, 2007 #3
    In C# you can synchronize using the lock(){} statement or using the classes: Mutex, Monitor, Semaphore and ReaderWriterLock.
    If your threads are also reading from the file at certain times, then use the ReaderWriterLock (enforces single writes, but allows for multiple concurrent reads).
    Otherwise, lock (critical section) or Mutex will do, with Mutex being the more CPU intensive option but less prone to deadlocks.
    Code (Text):
    public class MyClass{
       private static Mutex MyMutex = new Mutex();
       private static FileInfo MyFile = new FileInfo("myFile.log");
       private static ReaderWriterLock RWLock = new ReaderWriterLock();
       public void DoWork{
           //using a critical section
           //we lock on type because MyFile is static, if it were an instance variable
           //then you would do lock(this){...}
               //write to file
           //using mutex
           //write to file
           //using read-write lock
           //write to file
Similar Threads - Locking objects threads Date
C/++/# Good books on threading/processes? Mar 26, 2017
Java Applet: Moving Image Object Feb 10, 2017
How can fix this code using the object oriented python ? Jan 1, 2017
Object oriented programming Sep 7, 2016
[SQL Server] Object Definition Aug 26, 2016
