Log Base 1
  • Thread starter JinM
I know that logarithms to the base 1 is undefined, due to the reason that:
[itex]\log_1{x} = \frac{\log_a{x}}{\log_a{1}}[/itex]
And this leads to divison by zero, which is undefined.
There was a question in one of my textbooks that asked describe the graph that results if [itex]y = \log_1{x}[/itex]. Is such a graph even possible?
If I switch this logarithm to exponential form I would get:
[itex]1^y = x[/itex]
Now, is it possible that the graph could be y = 1 and x = 1? Since [itex]1^y = x^1[/itex], [itex]y = 1[/itex] and [itex]x = 1[/itex].
Or is it the point of intersection of these two lines? If not, what is it?
Thanks.
Answers and Replies
HallsofIvy
41,833
956
Well, not "the" graph. You have two "functions" there and so two graphs. Yes, if y= log1(x) then x= 1y= 1 for all x. The reason I put "functions" in quotes above is that this is not actually a function: strictly speaking, log1(x) is not a function. But it is a relation and its graph is the vertical straight line x= 1.
y= 1x= 1 is a function: its graph is the horizontal straight line y= 1.
Well not even going into division by zero when considering a change of base, you should recognize that 1 raised to a power won't get you x, a variable.
1 raised to any power, whether fractional, negative, or worse, is just 1. So the graph will look like x = 1.
Wouldn't the expression y=log11 (or y=log1(x);x=1 for all x) be undifned too as logn1 is always zero; So y=log11 has both zero and one as an answer?
Related Threads on Log Base 1
  • Last Post
10K
  • Last Post
9K
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
30K
11K
