What is the connection between Arctanh x and the logarithmic function?
In summary, the hyperbolic arctangent function, Arctanh x, can be expressed as (1/2) [ Log (1+x) - Log (1-x) ]. This can be shown by expanding both sides in a Taylor series and solving for x using basic algebra. Similarly, the logarithmic expressions for Arcsinh x and Arccosh x can be derived using Euler's Formula.
paulfr
193
I can not seem to figure out why Arctanh x [ Hyperbolic Arctan ]
can be expressed as
Arctanh x = (1/2) [ Log (1+x) - Log (1-x) ]
Note; I know the 1/2 means the expression is a square root
of the ratio of the 2 binomials and has been taken out with the Power Rule
Can anyone show me the connection ?
Note the above has been corrected for errors from the original post
You didn't write it correctly. What you wrote reduces to ArcTan(x) = (1/2) Log(2), which is clearly not correct. I think the correct expression is:
[tex]\tan ^{-1}(x)=i \log \left(\sqrt{\frac{1-i x}{1+i x}}\right) = \frac{i}{2}\log \left(\frac{1-i x}{1+i x}\right) = \frac{i}{2} (\log (1-i x)-\log (1+i x)) [/tex]
As to why, the best way I know to show the equality is to expand both sides in a Taylor series. Both sides can be expressed as:
[tex]\sum_{n=0}^{\infty}\frac{(-1)^nx^{2n+1}}{(2n+1)} [/tex]
I think you mean:
[tex]\arctan(z)=\frac{i}{2}\log\frac{i+z}{i-z}[/tex]
Then just let:
[tex]w=\frac{\sin(z)}{\cos(z)}[/tex]
then expand sin and cos in their complex form then solve for z using just basic algebra.
Darn, I was hoping I could correct this before anyone read it.
Sorry
I meant to write arc HYPERBOLIC tangent
And I did write it incorrectly
Arctanh = 1/2 [ Log (1+x) - Log (1-x) ] = Log [Sqrt { (1+x) / (1 - x) } ]
Again please forgive my carelessness.
And thanks for any insight you can offer.
Well, we have:
[tex]y=tanh(x)=\frac{e^{x}-e^{-x}}{e^{x}+e^{-x}}=\frac{(e^{x})^{2}-1}{(e^{x})^{2}+1}\to{y}=\frac{u^{2}-1}{u^{2}+1}, u=e^{x}[/tex]
Now, solve for u in terms of y (almost trivial), then solve for x in terms of y (also trivial).
Arildno
Thanks. That does lead directly to the Log expression.
The similar sequence to find the Log expresion for Arcsinh x and Arccosh x
is not so trivial though.
Sad to say I still can not show or prove this equation to be true.
How can one show that arcsinh x is expressible as this logarithm ?
Thanks for your help
Well, let:
[tex]y=\frac{e^{x}-e^{-x}}{2}[/tex]
Rearranging, we get:
[tex]e^{2x}-2e^{x}y-1=0[/tex]
Thus, we get:
[tex]e^{x}=\frac{2y\pm\sqrt{4y^{2}+4}}{2}=y+\sqrt{y^{2}+1}[/tex]
since the other solution is negative (impossible solution for exponential with real exponent).
Take the logarithm of on both sides to find x=arsinh(y)
So it is a direct consequence of Euler's Formula
What is the log equivalent of Arctan x?
The log equivalent of Arctan x is ln(1+x^2).
What is the domain of the log equivalent of Arctan x?
The domain of the log equivalent of Arctan x is all real numbers.
What is the range of the log equivalent of Arctan x?
The range of the log equivalent of Arctan x is (-∞, ∞).
How is the log equivalent of Arctan x used in real life?
The log equivalent of Arctan x is commonly used in mathematics and engineering to solve problems involving trigonometric functions and their derivatives.
What is the derivative of the log equivalent of Arctan x?
The derivative of the log equivalent of Arctan x is 1/(1+x^2).
  • Precalculus Mathematics Homework Help
