Login Diagram Homework: Solving Logarithmic Equations
In summary: No. You're remembering the "y=mx+b" form of the equation of a line incorrectly. It's:y=mx+bnotx=my+bSo the equation of the line is:y=2x+band you just correctly found b. So the equation of the line is:y=2x+\log_3\left(\frac{5}{9}\right)-2But that wasn't the question. The question was to find z in terms of x. And as you correctly stated, we have:y=\log_3(z)So we can now write:\log_3(z
hostergaard
37
http://img21.imageshack.us/img21/2327/nummer1.jpg
6(a) y=2 so the answer should about 3,3
6(b)
Proplem is that i don't know what the opposite(invert) of log3 is...
then i could take that opposite and use it on y... a litle help here please :-)
The inverse of a logarithmic function is an exponential function. That is, let [itex]a>0[/itex], [itex]a\neq 1[/itex]. Then if [itex]f(x)=log_a(x)[/itex] then [itex]f^{-1}(x)=a^x[/itex].
Does that help?
no (sorry), i think i was wrong, and i am utterly and completely lost... would apreciate a litle help to get back on track...
OK, try this.
1.) Write down [itex]y[/itex] as a function of [itex]x[/itex]. You should be able to do this using part (b) of the given information. Call this function [itex]f(x)[/itex] for now.
2.) Note that [itex]y=\log_3(z)[/itex], as stated in the problem.
Since [itex]y=f(x)[/itex] and [itex]y=\log_3(z)[/itex] what can you conclude about [itex]z[/itex] as a function of [itex]x[/itex]?
well, if y is a function of z then f(x) must also be function of z
so, f-1(x)--> z=log3(y)? hmm...
wait, f(z)=x?
No, [itex]y=f(x)[/itex]. [itex]z[/itex] is some other function of [itex]x[/itex] (call it [itex]g(x)[/itex]. But first thing's first: You need to find [itex]y=f(x)[/itex]. It should be easy--its graph is a straight line!
first i have to remove the log, that is to put it into y side of the equation. agh, sorry. It's the midle of the night were i am sitting rigth now, so i am strugeling a bit.
:confused:
Forget the log for a minute. I'm asking you to find [itex]y[/itex] as a function of [itex]x[/itex]. They gave you the slope of the line and a point that the line passes through. Do you know how to write down the equation of a line?
what is a gradient? (it is the midle of the nigth here...)
gradient=slope
errr, y=ax+b? and, ohh, i remember gradient is the slope of line which is a. so in this case y=2x+b?
then 5/9=2x+b?
Yes.
then 5/9=2x+b?
No. You need to use the given point on the line to find b.
fot that point, that is...
so i have to make quess on what x is in this given case? which would be 2,3...
wich would make b=-4.04444...
to sum up; the answer should be z=2*2.3-4.0444...
Is this wrong? somebdy please check this answer! :-)
hostergrad, if you don't know how to write down the equation of a line given the slope and a point then this whole enterprise is pretty hopeless.
No, for any point on the line. A slope and a point uniquely determines a straight line.
No, they gave you the coordinates of a point on the line:
[tex](x,y)=\left(1,log_3\left(\frac{5}{9}\right)\right)[/tex]
No, and I have no idea of how you arrived at that.
It's wrong. We can continue once you give me the equation of that line. I'm not going to respond to any more random guessing.
ohh, wait. I wass up 2'o clock in hte night doing this and i somehow tough 1=y. really, staying up that late melts my brain... but what can i do? I live in eroupe and that's the only time the american conticent are awake (aviable at the computer, that is)...
ok so we get the equation:
y=2(1)+b
then; b is the y intercept.
so the y inercept would be z-2 (the 2 is the slope) or (5/9)-2?
that would mean that b=-13/9
wich gives us that:
z=2x-(13/9)=5/9
but that being said, I am still not sure that i found b the rigth way. So migth not correct either...
Sorry for being stupid:frown: , but at least i am trying to understand it... tougth i can understand that it is frustrating when i seem completely unable to grasb this. Yes, my ability to remember math formula is a bit bad... that's why I'm here, because i don't have the people skils to get classmates to help me...:confused: but I do really apreciate the help!:approve:
Well, the posts that we make aren't going anywhere. You can post your work during (your) daytime when you're fresh, and then I'll see it during (my) daytime.
y=2(1)+b
No. I don't know why you say "the y inercept would be z-2". There's no z here! But you've almost got the number right, you just forgot to include the log. You should have gotten:
[tex]b=\log_3\left(\frac{5}{9}\right)-2[/tex]
1. What is a logarithmic equation?
A logarithmic equation is an equation that contains a logarithm, which is a mathematical function that represents the power to which a base number must be raised to equal a given number. The general form of a logarithmic equation is logb(x) = y, where b is the base, x is the argument, and y is the solution.
2. How do I solve logarithmic equations?
To solve a logarithmic equation, you can use the properties of logarithms to rewrite the equation in a simpler form. Then, you can use algebraic techniques to isolate the variable and solve for its value. Remember to check your solutions to ensure they are valid in the original equation.
3. What are the properties of logarithms?
The properties of logarithms include the product rule, quotient rule, power rule, inverse rule, and change of base rule. These properties allow you to manipulate logarithmic expressions and equations to make them easier to solve.
4. Can logarithmic equations have more than one solution?
Yes, logarithmic equations can have more than one solution. This is because logarithmic functions are not one-to-one, meaning that different inputs can result in the same output. When solving a logarithmic equation, it is important to check your solutions to ensure they are all valid in the original equation.
5. How can I check my solutions for a logarithmic equation?
To check your solutions for a logarithmic equation, you can substitute them back into the original equation and see if they result in a true statement. You can also use a graphing calculator to graph both sides of the equation and see where they intersect, which should be at the solution(s).
12K
