Homework Help: Logarithm rearrangement
  1. Mar 21, 2017 #1
    2 - log10 3x = log10(x/12)
    2. Relevant equations
    logab=b log a
    log(a/b)= log a - log b
    3. The attempt at a solution
    2 + log10 12= log10 x - x log10 3
    Start seems simple but cannot see where to go from here, taking exponentials doesn't seem to help. Not sure what the next steps could be.
  3. Mar 21, 2017 #2
    log is base 10 or it is natural log ?
  4. Mar 21, 2017 #3
    I assume it is meant to be base 10, so I have edited post to include the base.
  5. Mar 21, 2017 #4
    After rearranging a bit I can't see how this has a nice solution.
    I get ##5^2 *2^4*3 = x3^x##.
  6. Mar 21, 2017 #5
    I'm happy with that as well, thanks.
  7. Mar 21, 2017 #6
    Mark44
    Staff: Mentor
    Your equation is equivalent to ##100 = \frac x {12} \cdot 3^x##. Because the variable occurs both as an exponent and as a multiplier, there are not any simple analytic ways to solve this equation. However, you can get good approximations by numeric means, simply by substituting value for x on the right side, and comparing the result with 100 on the left side. Using a spreadsheet I see that there is a solution near x = 50.16. The actual solution is slightly smaller than this.
    Edit: As Ray points out, my number here is incorrect. I was using an incorrect formula in my spreadsheet, using log(3^x) instead of 3^x.
  8. Mar 21, 2017 #7
    Ray Vickson
    For If ##f(x) = (x/12) 3^x,## we have##f(50) = (50/3) e^{50} \doteq 0.299 \times 10^{25}##, so the solution of ##f(x) = 100## must certainly be quite a bit less than 50. Maple gets ##x \doteq 4.990.##
  9. Mar 21, 2017 #8
    what is ##\doteq## ?
  10. Mar 21, 2017 #9
    Ray Vickson
    ##\doteq## means "approximately equal to", sometimes also written as ##\approx##. I avoid using "=" in such cases just so the reader will understand that the answer is not exactly 4.990. For example, a better approximation is obtained by using 60 digits of precision, giving
    ##x \doteq 4.99043541467729841484302401855197675632523233638262678465047## Even that is not exact.
  11. Mar 21, 2017 #10
    As a additional exercise, Can we prove that there is no nice real solution for equation, Also can we know the nature of the solution ?
  12. Mar 21, 2017 #11
    Mark44
    Staff: Mentor
    You are correct. Somehow I mistakenly had log(3^x) in my spreadsheet formula, not log(3^x) as it should have been.
Have something to add?
Draft saved Draft deleted
