Logarithmic Differentiation
  • Thread starter t_n_p
http://img253.imageshack.us/img253/5748/logdiffji4.jpg [Broken]
I've tried both and i) and ii) however something just doesn't seem right. Can somebody tell me if my method is correct?
i) http://img253.imageshack.us/img253/8791/img0186anh3.jpg [Broken] ii)http://img329.imageshack.us/img329/627/img0187azr5.jpg [Broken]
Answers and Replies
Hurkyl
Staff Emeritus
You forgot to differentiate.
I've got a total mindblock :yuck: , can you explain a little further?
differentiate both right and left hand side...
Oh yeh! I tried by using chain rule (Let sinx^cosx = u)
therefore i get :
(1/y)*(dy/dx) = (1/u)*[d/dx(sinx^cosx)]
How would I go about diff-ing sinx^cosx?
consider cosx as u and log(sinx) as v, then diff by the product rule (udv+vdu)
In diff. v, use the chain rule
Ah! so much easier!
Ok, after that tip from f(x) I got what I beleive is the final answer. Can this be simplified any further?
http://img156.imageshack.us/img156/115/img0192us4.jpg [Broken]
D H
Staff Emeritus
Insights Author
15,415
687
Your work looks good up until very last step. Try that final step one more time.
silly me! :rofl:
2nd time lucky!
http://img441.imageshack.us/img441/8141/answerem9.jpg [Broken]
D H
Staff Emeritus
Insights Author
15,415
687
Much better.
I'm not too sure how to go about part (ii)
So far i've converted the square roots to ^1/2 and expanded out to get
x^(3/2)[(1-x^2)^(1/4)]
I then let that equal u (chain rule) however the product rule within u seems to get pretty messy/complicated.
Is this the correct method?
cristo
Staff Emeritus
74
If [itex]y=x^{3/2}[(1-x^2)^{1/4}],[/itex] then let [itex]u=x^{3/2} [/itex]and [itex]v=(1-x^2)^{1/4} [/itex] so that y'=uv'+u'v, remembering that to calculate v' you will need to use the chain rule.
Ok, so I now know how to diff [itex]y=x^{3/2}[(1-x^2)^{1/4}],[/itex] but shouldn't I take log of both sides before diff-ing? In that case I need to figure out the derivative of ln[[itex]y=x^{3/2}[(1-x^2)^{1/4}],[/itex]]
Bump, can anybody help?
HallsofIvy
41,847
966
You could but you don't have to. Typically "logarithmic differentiation is used when you have a function of x in the exponent.
Just use the product rule:
[itex]y'= (x^{3/2})'(1- x^2)^{1/4}+ x^{3/2}[(1-x^2)^{1/4}]'[/itex]
[itex]= (3/2)x^{1/2}(1- x^2)^{1/4}+ (x^{3/2})(1/4)(1-x^2)^{-3/4}[/itex]
If you take the logarithm of both sides, you get [itex]ln y= (3/2)ln(x)+ (1/4)ln(1+ x^2)[/itex]. Now [itex](1/y)y'= 3/(2x)+ 2x/(4(1+x^2))[/itex]. That righthand side is much simpler but you still have to multiply by y.
VietDao29
1,424
Another way to differentiate the second expression is to change it to a single n-root, like this:
[tex]\sqrt{x ^ 3 \sqrt{1 - x ^ 2}} = \sqrt{\sqrt{x ^ 6 (1 - x ^ 2)}} = \sqrt[4]{x ^ 6 - x ^ 8}[/tex]
Let u = x6 - x 8. Now, the whole expression becomes [tex]\sqrt[4]{u}[/tex], you can apply the chain rule and finish the problem. Can you go from here? :)
I think ill go with this method. So using chain rule I get dy/dx = (1/4)((x^6-x^8)^(-3/4))*(6x^5-8x^7)
Hope you can make that out. So where does the logarithmic part come into it? Do I now take log of both sides?
I'm quite lost:confused:
VietDao29
1,424
Nope, you can differentiate it normally as you've just done.
Or you can tuse logarithmic differentiation as HOI has suggested, i.e, it goes like this:
[tex]y = \sqrt{x ^ 3 \sqrt{1 - x ^ 2}}[/tex]
Taking log of both sides yields:
[tex]\ln y = \ln \left( \sqrt{x ^ 3 \sqrt{1 - x ^ 2}} \right) = \frac{1}{2} \ln \left( x ^ 3 \sqrt{1 - x ^ 2} \right) = \frac{1}{2} \left( \ln (x ^ 3) + \ln( \sqrt{1 - x ^ 2} ) \right)[/tex]
Now, you can differentiate both sides to find y'.
There are many ways to approach a differentiation problem, so just choose the one that you like best.
That's very helpful! Had to navigate through the diff of [tex]\frac{1}{2} \left( \ln (x ^ 3) + \ln( \sqrt{1 - x ^ 2} ) \right)[/tex]. Was a bit tricky but I think I got it...
http://img253.imageshack.us/img253/6788/asdfry0.jpg [Broken]
Can you please confirm?
VietDao29
1,424
Nope, still incorrect. You forget to multiply it by y.
Multiply it by y, then simplify the expression you get, and it's all done. :)
Note that differentiating [tex]\ln( \sqrt{1 - x ^ 2} )[/tex] can be a little bit tricky, but if you pull out the 1/2, it should be easier. It goes like this:
[tex][\ln( \sqrt{1 - x ^ 2} ) ]' = \frac{1}{2} [\ln (1 - x ^ 2) ]' = \frac{1}{2} \times \frac{-2x}{1 - x ^ 2} = \frac{-x}{1 - x ^ 2}[/tex] :)
Yeh, that was just the diff without * y.
After making common denom of (6x^3)(4-4x^2) and * by y I get
http://img242.imageshack.us/img242/5305/finalansux3.jpg [Broken]
VietDao29
1,424
[/URL]
You still haven't simplified it... =.="
HINT: You can factor out x2 in the numerator and denominator, then the two x2's will cancel each other out.
[tex]y \times \left( \frac{3x ^ 2}{6x ^ 3} - \frac{2x}{4 - 4 x ^ 2} \right) = \sqrt{x ^ 3 \sqrt{1 - x ^ 2}} \times \left( \frac{1}{2x} - \frac{x}{2 - 2 x ^ 2} \right)[/tex]
[tex]= \frac{1}{2}\sqrt{x ^ 3 \sqrt{1 - x ^ 2}} \times \left( \frac{1}{x} - \frac{x}{1 - x ^ 2} \right)[/tex]
And... you can stop here, and leave it in this form. :smile: It's okay, simplified enough. You shouldn't make common denominator, as it's unnecessary, and you may also make some minor mistakes during doing so.
Finally got it. Many, many thanks!
Related Threads on Logarithmic Differentiation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
