mikaela_clare
- 1
Does anyone know how to solve this integral?
int. (ln(ax+b))^2
Struggling!
Thanks :D
int. (ln(ax+b))^2
Struggling!
Thanks :D
A logarithmic integral is a special type of integral that involves the natural logarithm function. It is written as ∫ln(x)dx and is used to calculate the area under the curve of the natural logarithm function.
To solve an integral with a logarithmic function, you can use the substitution method or integration by parts. In the case of the integral int. (ln(ax+b))^2, you can use the substitution u = ln(ax+b) to simplify the problem.
The general formula for solving a logarithmic integral is ∫ln(ax+b)dx = (ax+b)(ln(ax+b) - 1) + C. This formula can be derived using integration by parts.
First, use the substitution u = ln(ax+b) to simplify the integral to ∫u^2du. Then, use the power rule to solve this integral, which results in (u^3)/3 + C. Finally, substitute back in u = ln(ax+b) to get the final answer of (ln(ax+b))^3/3 + C.
Yes, there are a few special cases for solving logarithmic integrals. For example, if the logarithmic function is in the denominator, you can use the substitution u = ln(x) to simplify the integral. Additionally, if the logarithmic function is raised to a fraction or a negative power, you can use the substitution u = ln(ax+b) and some algebraic manipulation to simplify the integral.
