Debunking the Myth of Logical Errors in Transverse Doppler Effect Experiments
  • Thread starter Thomas
  • Tags
    Errors
In summary, the conversation discusses the validity of Einstein's theory of relativity and the ambiguity in determining which clock is slower in the transverse Doppler effect. It is argued that Einstein did not derive the Lorentz transformations, but rather used them as empirical equations. It is emphasized that there is no logical flaw in the theory of special relativity and it is a seamless whole. The conversation also touches on the importance of understanding the development of Einstein's theory in order to fully grasp its concepts.
Thomas
Originally posted by ahrkron
Take a look at the link provided by chroot. The effect has been extremely well tested in many different settings.
Experiments can't prove something which is logically flawed. Einstein's invalid procedure in deriving his transformation equations besides (see http://www.physicsmyths.org.uk/lightspeed.htm), motion is always only relative, so each of two obervers moving relatively to each other can claim that he is resting and the other moving, which makes it ambiguous which of the two clocks is going slower. In transverse Doppler effect experiments with source and receiver moving uniformly relatively to each other, an observer moving with the source would have to claim that the receiver has a lower than the rest frequency due to the motion, so he would have to lower the frequency of the emitter for the signal to match the receiver frequency. On the other hand, an observer moving with the receiver would claim that the emitter has a lower frequency due to the motion, so he would have to lower the receiver frequency in order to be able to receive the signal. This is obviously a logical contradiction because if both the emitter and receiver frequency are lowered by the same amount, it might as well remain unchanged. Yet in corresponding experiments the frequencies are not the same but detuned by a corresponding amount. This shows that the notion of moving clocks running slower is wrong. The observed 'transverse Doppler effect' either has to be a physical effect due to forces acting on emitter or receiver, or is in fact the normal Doppler effect associated with small distance changes between source and receiver which have not been taken into account for the experiment.
You are correct that it is ambiguous, but you are incorrect as to the cause of the ambiguity. It is ambiguous because you have not specified in which reference frame you are comparing the rates of the two clocks.
In transverse Doppler effect experiments...
I don't see how any part of your exposition follows logically...
The frequency of the source as observed in the reference frame of the source will be higher than the frequency of the source as observed in the reference frame of the receiver. Corrections are made to allow reception as necessary, either by dialing up the source or dialing down the receiver.
(I'm presuming the source and receiver are moving away from each other, possibly at an angle)
The only logical error demonstrated here is in the linked web page.
The quanities t= L/(c-v) and t = L/(c+v) are indeed used by AE in his paper, but they are used as I have expressed them as an expression as the TIME required to travel the distance L. L is the length of a rod moving with the velocity v. The above expressions are the times as measured by an observer watching the rod move past as the light beam travels first in the direction of motion of the rod then its return trip.
If you wish to argue errors in AE's math you will first need to read and understand the development he presents. Clearly this author has not done that.
Einstein didn't derive the transformation equations, Lorentz did, that's why they're called the Lorentz Transformation.
I was just thinking today that Einstein's paper is nearly 100 years old but there are still people who don't quite get it.
And there's nothing logically flawed with the Theory of Special Relativity, it is a seamless whole. There isn't a place in it you could wedge a knife blade into.
Lorentz's did not DERIVE the equations they were emperical, sort of a "hey look this works" set of equations with no real physical basis. Einstein showed that they could be mathematically derivived with only 2 assumptions. 1. That the laws of physics hold in all inerial frames. 2. That the speed of light is a constant to all observers. This is why AE gets credit for developing relativity and we still refer to the Lorentz transforms.
Here are two links that describe the Lorentz Transformations, and both say that H.A. Lorentz first found them.
http://www.wikipedia.org/wiki/Lorentz_transformation
http://www.adi.uam.es/Docs/Knowledge/Fundamental_Theory/rltvt/node3.html
Tyger,
Did you read my post? There is no doubt that Lorentz first wrote down the Lorentz Transforms, that is why they are named that. Do you you understand the difference between derived and empirical? An empirical relationship does not have to have any physical basis, such as the relationship Balmer arrived at to describe the Balmer series in the Hydrogen spectrum. With knowledge of a constant c from Maxwell, Lorentz arrived at his transforms because they worked, Einstein showed the physical basis for them.
Integral,
I think it would be helpful if you post links to the details you worked out for On the Electrodynamics of Moving Bodies.
Originally posted by Tom
Integral,
Consider it http://home.comcast.net/~rossgr1/specialrel.pdf
AE let some minor steps to the reader, here I have filled in the holes. The math needed is trivial, the concepts are a little deeper.
Greetings !
Remarkable !
I think people MUST frame this quote and put it on the
door step of every University so that people could walk
all over it as they enter. (No offense Thomas, I'm
just talking about this sentence.)
Live long and prosper.
Tyger,
Here is a link to Weisstein' Desciption of Lorentz's EM work. It sure doesn't sound very empirical to me!
Lorentz beleived his first equation
Lorentz's did not DERIVE the equations they were emperical, sort of a "hey look this works" set of equations with no real physical basis. Einstein showed that they could be mathematically derived with only 2 assumptions. 1. That the laws of physics hold in all inerial frames. 2. That the speed of light is a constant to all observers. This is why AE gets credit for developing relativity and we still refer to the Lorentz transforms.
was involved with "ether contraction" so it didn't seem merely empirical to him, it had a physical basis. And yes, there's no doubt that Einstein put the whole picture together with a minimum of principles and discarded the Ether in the process.
This thread was hijacked
Just for information:
this thread has been hijacked from the thread 'time dilation' (https://www.physicsforums.com/showthread.php?s=&threadid=3498). What's more, my account (Thomas) has been disabled without any notice and explanation and I am therefore not even able to comment on it anymore.
Whoever did this should ask himself some serious questions regards the legality of his actions. Not only are they extremely offensive but could even be considered as libellous, as, contrary to the appearance, I did not start any thread called 'Logical Errors'. It was started by somebody who stole one of my posts and pretended to be me.
Your posts were merely split off to start a new thread by the mentor as he felt that they were de-railing the original thread.
Also, since your posts were moved intact, and with no changes, your charges of libel are laughable.
Besides, when you registered, you agreed to the forum rules when you clicked the "I agree" button. These rules state :
"The owners of Physics Forums have the right to remove, edit, move or close any thread for any reason."
I am afraid your assertions don't make any sense in the light of the fact that my account was suspended without any warning.
Also, only the one post and not the whole thread was moved, and my post was therefore taken out of context.
Anyway, I can't see how it can be seen as a derailing of a thread when I was explicitly responding to a previous post (Ahrkron's).
Opps, you are right Thomas, I did make a mistake. I left this split off thread in Physics, I should have moved it to Theory Developement. My first inclination was simply to delete it. But since your reply to Ahkron was so blatently off the topic of the thread I decided to play with the thread split feature.
Gregg, the thread split works great!
Thomas, to be a valued member of this forum you need to make an effort to reply to the topic at hand. Please avoid converting threads to your personal agenda.
QM comes to mind. Most of the major points of QM are logically flawed but they are about as thoroughly proven as any scientific theory can be.
A photon (electron!) in two places at once? Preposterous.
P.S. guys, the debate on whether the Lorenz Transforms were derived or discovered is kinda pointless and petty. It doesn't make a whole lot of difference. You guys are agreeing on far more than you are disagreeing.
You should read what I said about that sentence...:wink:
I think I did. You mean the one about college doormats? Great post and I was thinking of quoting it. But I was agreeing with you. So... [?] [?]
Btw, I've already copyrighted that sentence and the doormats should be on sale at WallMart within a few weeks.
Blatently off the topic ?? The original topic was about time dilation experiments and that's what the moved post (the first post in this thread) addresses. It was you and others who subsequently derailed this thread by turning it into a discussion about the history of the Lorentz Transformation.
Can you guys point me to where the college doormats sentence was written? I'd like to read it. I'll keep an eye on WallMart, but they are slow at putting things out, so...
On the other hand, I disagree with the idea that "most of the major points of QM are logically flawed". In brief, my reasons are:
1. QM is math'ly sound, and math is a formalization of logic, would you disagree?
2. When people say that "QM is illogical" they usually refer to conflicts between "everyday logic" and their interpretation of QM effects. However, "everyday logic" is a merge of logic (inference rules) and some axioms taken from our usual perceptions, which are inevitably in the realm of classical physics.
This second point is subtle, but important. "Logic" is devoid of content; it only deals with the rigor of the conclusions we draw from a set of axioms. The difference, then, lies in the axioms used, and we cannot expect axioms to be exactly the same for our usual interactions with the world (at scales measured in meters) as those that hold at scales 15 orders of magnitude smaller.
Besides, the QM axioms are indeed consistent with the behavior we obtain at bigger scales; i.e. when you work out the consequences you expect from such axioms (i.e., the QM ones) at big scales, they are indeed compatible with what we see.
The first sentence of this thread. :wink:
1. What is the transverse Doppler effect?
The transverse Doppler effect is a phenomenon in physics where the frequency of electromagnetic radiation (such as light) is affected by the relative motion between the source of the radiation and the observer. This effect is observed when the source and observer are moving perpendicular to each other.
2. What is the myth about logical errors in transverse Doppler effect experiments?
The myth is that transverse Doppler effect experiments are prone to logical errors, leading to the conclusion that the effect does not exist or is not significant. This myth has been perpetuated by a few flawed experiments and misunderstandings of the underlying principles.
3. How has this myth been debunked?
Through rigorous research and experiments, scientists have been able to demonstrate that the transverse Doppler effect does indeed exist and is a significant phenomenon in physics. They have also identified and addressed the logical errors that were present in previous experiments, providing a more accurate understanding of the effect.
4. Why is it important to debunk this myth?
Debunking this myth is important because the transverse Doppler effect has important implications in fields such as astronomy and relativity. It also helps to prevent misinformation and promote a better understanding of physics.
5. What are some common logical errors in previous transverse Doppler effect experiments?
Some common logical errors include not accounting for the relative velocity between the source and observer, not considering the direction of motion in relation to the observer, and not properly controlling for other factors that could affect the results of the experiment.
  • Other Physics Topics
