What are the best preowned Thinkpad models for a budget-conscious PhD student?
In summary, the conversation revolves around the need for a new laptop for a PhD program. The individual is considering older models, specifically the T440, 2nd Gen x1 carbon, and X230/240, but is also open to other recommendations. The other person suggests getting a new laptop, citing potential unseen problems with used ones and the fact that companies and individuals typically replace their laptops after 3 and 5 years respectively. They also mention potential issues with the Thinkpad's system board and advise against risking problems with an old laptop during a PhD program. The individual also mentions considering the newer L460 model, but notes that there are not many reviews available. The conversation also briefly touches on the individual's experience with their own
RobosaurusRex
29
Hi,
I am starting my PhD in a few weeks, I am in desperate need of an upgrade. My laptop has finally died after 5 years of service.
I will be dual booting Linux and Windows, so a Thinkpad seems a solid option regarding my budget. I really can't afford to spend a whole lot.
I will be reading articles, running toy codes, writing, etc.
What older models would you guys recommend?
I have browsed a bunch and keep coming across;
T440
2nd Gen x1 carbon
X230/240
Any comment on these three? Even a complete other recommendation is greatly appreciated.
Thanks.
Computer science news on Phys.org
I have a 5 year old X220. Works great. Looks new, despite having traveled the equivalent distance of the moon and back. Maybe twice.
My feeling is you should get a new one. Used ones may have unseen problems like the system board is cracked, the disk drives are worn or the batteries are on their last legs. Companies typically swap out machines after 3 years and private individuals after 5 years and there's a reason they do this because the machine is no longer as speedy under the new OS and the failure rates go up and the warranties are gone.
A common recurrent problem with thinkpads and other light weight computers was that people would pick them up from the corner causing the system board to flew and after awhile to crack because the chassis was too flexible. It happened to mine and I remember hearing the crack and seeing the machine freeze up.
Also why would you want to risk a problem if you're starting a PhD where every second counts before you go crazy with the anxiety of completing your thesis.
I was told my quite a few people that older thinkpads normally perform very well. Which is why I am lookin for further opinions to gain as much of an unbiased view as I can.
I have also had this thought about old laptops, as far as new models go, I am looking into the l460. Perfect size, reasonably priced, decent spec, upgradable hardware, my only problem is that with it being a newer model there are not nearly as many review on the product.
Thanks for your words!
I have heard the x series have good support as well, if you went back would you of bought a new Thinkpad instead of an older if it was say 1.5 times as expensive.
A new one will last longer than an old one.
I bought a refurbished Lenovo (IBM derivative). It was like new, about 3 months old, probably returned due to the previous owner's dissatisfaction with screen size or some other limitation that was inherent with my Lenovo Yoga. It has been a great system for me and I saved probably 40% off of list while I still got my one year warranty and the option to buy a one or two year extension. The only problem with this type of purchase is that I could have received a laptop with a cosmetic blemish or scratch and I would not be able to exchange for that reason (non functioning ports or any functional problems would be covered by exchange or warrantee). My computer looked new and has been flawless.
My complaint about the Yoga series, it is basically a closed system without any way to easily modify or expand. Realizing that, I bought the highest end system available and it has handled everything I have needed it for.
1. What should I consider when looking at preowned Thinkpads?
When looking at preowned Thinkpads, you should consider the specific model, the age and condition of the device, the seller's reputation, and the price. These factors will help you determine the value and potential longevity of the Thinkpad.
2. How can I ensure the quality of a preowned Thinkpad?
To ensure the quality of a preowned Thinkpad, you can ask the seller for detailed photos and specifications, check for any physical damages or defects, and read reviews or ratings from previous buyers. It is also recommended to purchase from a trusted and reputable seller.
3. Are there any risks associated with buying a preowned Thinkpad?
There are some risks associated with buying a preowned Thinkpad, such as receiving a device with hidden damages or defects, encountering compatibility issues, or not receiving the device as advertised. However, these risks can be minimized by purchasing from a reputable seller and thoroughly researching the device before making a purchase.
4. Is it worth buying a preowned Thinkpad instead of a new one?
This ultimately depends on your specific needs and budget. Preowned Thinkpads can offer significant cost savings compared to new models, but you may have to compromise on the latest features and warranty. However, if you are on a tight budget, a preowned Thinkpad can still be a reliable and cost-effective option.
5. How can I make sure the preowned Thinkpad is compatible with my needs?
To ensure compatibility, you should carefully research the specifications and features of the preowned Thinkpad you are considering. You can also reach out to the seller for more information or consult with a professional if needed. It is also recommended to read reviews or ask for recommendations from other Thinkpad users.
  • Computing and Technology
18K
