Program to Detect Games Over Network
  • Thread starter Flying Penguin
  • Tags
    App
In summary, there are a few different methods that can be used to detect games running over a network. One option is to use a firewall to block ports, but this may not be effective for games that use common ports. Another option is to use software that allows you to set up your computer as a server and see how many games are running on it. Additionally, you could use a sniffer to look for the protocol of a specific game on the LAN, but this may require setting your NIC to promiscuous mode. The method used will depend on the game and the network environment.
Flying Penguin
Is there a program that can detect games running over a network? Kind of like the "Find LAN games" option you'll find in a network game, only to find any games at all?
Computer science news on Phys.org
It depends on the game and what port it uses. Any decent firewall can block ports, but you need to find out which ports the game is using. If the game uses port 80 (HTTP) or any other common port then your out of luck.
Here is a list to start off with:
http://www.portforward.com/cports.htm
i think the only way to know how many games are running over a network would be if you were the server are apart of the network- say you wanted to make your computer a server for a game network, the software you would be given to make your computer the server would be able to tell you how many games were running on your server- i know a little about how this works maybe you could specify the game and why..
You could use a sniffer and look for the protocol that any specified game was using on the LAN.
If the LAN is a switched environment (layer 2 switching) then you would have to use a port monitor on one interface on the switch, and set you NIC to promisceous mode. If the LAN is 1 brodcast domain then you just need to se your NIC to promisceous mode and start sniffing :-)
1. What is a "Program to Detect Games Over Network"?
A "Program to Detect Games Over Network" is a software tool that is designed to identify and monitor games being played over a network, such as a local area network (LAN) or the internet. It can detect the types of games being played, the players involved, and other relevant information.
2. How does a "Program to Detect Games Over Network" work?
A "Program to Detect Games Over Network" typically works by scanning network traffic and analyzing packets to identify game-related data. It may also use protocols specific to certain games to gather information. Some programs may require installation on the network, while others can work remotely.
3. What types of networks can a "Program to Detect Games Over Network" monitor?
A "Program to Detect Games Over Network" can monitor any type of network, including LANs, WANs, and the internet. However, the level of monitoring may differ depending on the network type, as some networks may have more security measures in place that can limit the program's access to game data.
4. Can a "Program to Detect Games Over Network" identify all types of games?
While a "Program to Detect Games Over Network" can identify many popular games, it may not be able to detect all types of games. This is because new games are constantly being developed and may use different protocols or encryption methods that the program may not be able to recognize.
5. Is a "Program to Detect Games Over Network" legal to use?
Generally, it is legal to use a "Program to Detect Games Over Network" as long as it is used for monitoring purposes and not for unauthorized access or manipulation of game data. However, it is important to check the terms of service and any applicable laws in your jurisdiction before using such a program.
  • Computing and Technology
  • General Discussion
