Loop-and-allied QG bibliography
  1. Nov 19, 2017 #2541
    atyy
    https://arxiv.org/abs/1708.07445
    Towards the map of quantum gravity
    Jakub Mielczarek, Tomasz Trześniewski
    (Submitted on 24 Aug 2017 (v1), last revised 5 Oct 2017 (this version, v2))
    In this paper we point out some possible links between different approaches to quantum gravity and theories of the Planck scale physics. In particular, connections between Loop Quantum Gravity, Causal Dynamical Triangulations, Ho\v{r}ava-Lifshitz gravity, Asymptotic Safety scenario, Quantum Graphity, deformations of relativistic symmetries and nonlinear phase space models are discussed. The main focus is on quantum deformations of the Hypersurface Deformations Algebra and Poincar\'{e} algebra, nonlinear structure of phase space, the running dimension of spacetime and nontrivial phase diagram of quantum gravity. We present an attempt to arrange the observed relations in the form of a graph, highlighting different aspects of quantum gravity. The analysis is performed in the spirit of a mind map, which represents the architectural approach to the studied theory, being a natural way to describe the properties of a complex system. We hope that the constructed graphs (maps) will turn out to be helpful in uncovering the global picture of quantum gravity as a particular complex system and serve as a useful guide for the researchers.
    https://arxiv.org/abs/1708.07716
    Extended Phase Space Analysis of Interacting Dark Energy Models in Loop Quantum Cosmology
    Hmar Zonunmawia, Wompherdeiki Khyllep, Nandan Roy, Jibitesh Dutta, Nicola Tamanini
    (Submitted on 25 Aug 2017)
    The present work deals with the dynamical system investigation of interacting dark energy models (quintessence and phantom) in the framework of Loop Quantum Cosmology by taking into account a broad class of self-interacting scalar field potentials. The main reason for studying potentials beyond the exponential type is to obtain additional critical points which can yield more interesting cosmological solutions. The stability of critical points and the asymptotic behavior of the phase space are analyzed using dynamical system tools and numerical techniques. We study two class of interacting dark energy models and consider two specific potentials as examples: the hyperbolic potential and the inverse power-law potential. We found a rich and interesting phenomenology including the avoidance of big rip singularities due to loop quantum effects, smooth and non-linear transitions from matter domination to dark energy domination and finite periods of phantom domination with dynamical crossing of the phantom barrier.
    https://arxiv.org/abs/1708.08667
    A non-polynomial gravity formulation for Loop Quantum Cosmology bounce
    Stefano Chinaglia, Aimeric Colleaux, Sergio Zerbini
    (Submitted on 29 Aug 2017 (v1), last revised 5 Sep 2017 (this version, v2))
    Recently the so-called mimetic gravity approach has been used to obtain corrections to Friedmann equation of General Relativity similar to the ones present in loop quantum cosmology. In this paper, we propose an alternative way to derive this modified Friedmann equation via the so-called non-polynomial gravity approach, which consists in adding geometric non-polynomial higher derivative terms to Hilbert-Einstein action, which are nonetheless polynomials and lead to second order differential equation in Friedmann-Lema\^itre-Robertson-Walker spacetimes. Our explicit action turns out to be a realization of the Helling proposal of effective action with infinite number of terms. The model is investigated also in presence of non vanishing cosmological constant and a new exact bounce solution is found and studied.
    https://arxiv.org/abs/1709.03242
    Noncommutativity in Effective Loop Quantum Cosmology
    Abraham Espinoza-García (UPIIG-IPN, México), Efraín Torres-Lomas (UG, México)
    (Submitted on 11 Sep 2017 (v1), last revised 12 Sep 2017 (this version, v2))
    We construct two noncommutative extensions of the Loop Quantum Cosmology effective scheme for the open FLRW model with a standard scalar field with quadratic potential. Firstly, noncommutativity is implemented in the configuration sector only (among the holonomy variable and the matter degree of freedom). We show that this type of noncommutativity seems to retain key features of the Loop Quantum Cosmology paradigm for a free field; however, when considering the addition of a quadratic potential,this compatibility weakens regarding the trajectories followed by the scalar field. Secondly, noncommutativity is implemented in the momentum sector (among the momentum associated to the holonomy variable and the momentum associated to the matter field). In the free case, the only effect of this noncommutativity is that of making the volume function to grow faster, retaining key features of the Loop Quantum Cosmology paradigm. We show that, when considering a quadratic potential, this second kind of noncommutativity is more favored than the first one in regard to the trajectories followed by the scalar field.
    https://arxiv.org/abs/1709.06331
    Von-Neumann Stability and Singularity Resolution in Loop Quantized Schwarzschild Black Hole
    Alec Yonika, Gaurav Khanna, Parampreet Singh
    (Submitted on 19 Sep 2017)
    Though loop quantization of several spacetimes has exhibited existence of a bounce via an explicit evolution of states using numerical simulations, the question about the black hole interior has remained open. To answer this question, it is important to first understand the stability of the quantum Hamiltonian constraint. We take first steps towards addressing these issues for a loop quantization of the Schwarzschild interior. The von-Neumann stability analysis is performed using separability of solutions as well as a full two dimensional quantum difference equation. This results in a condition which translates to stability for black holes which have a very large mass compared to the Planck mass. In addition, stability analysis leads to a constraint on the localization of the allowed states. With the caveat of using kinematical norm, Gaussian states are evolved using the quantum difference equation and singularity resolution is obtained. Bounce is found for one of the triad variables, but for the other triad variable singularity resolution amounts to a non-singular passage through the zero volume. States are found to be peaked at the classical trajectory for a long time before and after the singularity resolution, and retain their semi-classical character across the zero volume.
    https://arxiv.org/abs/1709.08370
    Random Invariant Tensors
    Youning Li, Muxin Han, Dong Ruan, Bei Zeng
    (Submitted on 25 Sep 2017)
    Invariant tensors are states in the (local) SU(2) tensor product representation but invariant under global SU(2) action. They are of importance in the study of loop quantum gravity. A random tensor is an ensemble of tensor states. An average over the ensemble is carried out when computing any physical quantities. The random tensor exhibits a phenomenon of `concentration of measure', saying that for any bipartition, the expected value of entanglement entropy of its reduced density matrix is asymptotically the maximal possible as the local dimension goes to infinity. This is also true even when the average is over the invariant subspace instead of the whole space for 4−valent tensors, although its entropy deficit is divergent. One might expect that for n≥5, n−valent random invariant tensor would behavior similarly. However, we show that, the expected entropy deficit of reduced density matrix of such n−valent random invariant tensor from maximum, is not divergent but a finite number. Under some special situation, the number could be even smaller than half a bit, which is the deficit of random pure state over the whole Hilbert space from maximum.
    https://arxiv.org/abs/1709.08511
    Intertwiner Entanglement on Spin Networks
    Etera R. Livine
    In the context of quantum gravity, we clarify entanglement calculations on spin networks: we distinguish the gauge-invariant entanglement between intertwiners located at the nodes and the entanglement between spin states located on the network's links. We compute explicitly these two notions of entanglement between neighboring nodes and show that they are always related to the typical ln(2j+1) term depending on the spin j living on the link between them. This ln(2j+1) contribution comes from looking at non-gauge invariant states, thus we interpret it as gauge-breaking and unphysical. In particular, this confirms that pure spin network basis states do not carry any physical entanglement, so that true entanglement and correlations in loop quantum gravity comes from spin or intertwiner superpositions.
    https://arxiv.org/abs/1709.08989
    Simplicity constraints: a 3d toy-model for Loop Quantum Gravity
    Christoph Charles
    (Submitted on 26 Sep 2017)
    In Loop Quantum Gravity, tremendous progress has been made using the Ashtekar-Barbero variables. These variables, defined in a gauge-fixing of the theory, correspond to a parametrization of the solutions of the so-called simplicity constraints. Their geometrical interpretation is however unsatisfactory as they do not constitute a space-time connection. It would be possible to resolve this point by using a full Lorentz connection or, equivalently, by using the self-dual Ashtekar variables. This leads however to simplicity constraints or reality conditions which are notoriously difficult to implement in the quantum theory.
    We explore in this paper the possibility of imposing such constraints at the quantum level in the context of canonical quantization. To do so, we define a simpler model, in 3d, with similar constraints by extending the phase space to include an independent vielbein. We define the classical model and show that a precise quantum theory by gauge-unfixing can be defined out of it, completely equivalent to the standard 3d euclidean quantum gravity.
    We discuss possible future explorations around this model as it could help as a stepping stone to define full-fledged covariant Loop Quantum Gravity.
    https://arxiv.org/abs/1709.09806
    The emergence of 3+1D Einstein gravity from topological gravity
    Zheng-Cheng Gu
    (Submitted on 28 Sep 2017)
    Quantum field theory successfully explains the origin of all fundamental forces except gravity due to the renormalizability and ultraviolet(UV) completion puzzles. The ADS/CFT correspondence conjecture might naturally resolve the above two puzzles for ADS space gravity. In this paper, we propose a topological scenario to resolve the above two puzzles for generic cases(e.g., with or without cosmological constant term). First, we propose a 3+1D topological (quantum) gravity theory which is perturbatively renormalizable and potentially UV complete, this step can be regarded as a straightforward generalization of Edward Witten's Chern-Simons theory proposal for 2+1D topological gravity. Then, we show that Einstein-Cartan equation and classical space-time naturally emerge from topological (quantum) gravity via loop condensation. The second step is a unique feature in 3+1D and it might even naturally explain why our space-time is four dimensional. Experimentally measurable low energy predictions are also discussed.
    https://arxiv.org/abs/1710.04015
    Cosmological Coherent State Expectation Values in LQG I. Isotropic Kinematics
    Andrea Dapor, Klaus Liegener
    (Submitted on 11 Oct 2017)
    This is the first paper of a series dedicated to LQG coherent states and cosmology. The concept is based on the effective dynamics program of Loop Quantum Cosmology, where the classical dynamics generated by the expectation value of the Hamiltonian on semiclassical states is found to be in agreement with the quantum evolution of such states. We ask the question of whether this expectation value agrees with the one obtained in the full theory. The answer is in the negative. This series of papers is dedicated to detailing the computations that lead to that surprising result. In the current paper, we construct the family of coherent states in LQG which represent flat (k=0) Robertson-Walker spacetimes, and present the tools needed to compute expectation values of polynomial operators in holonomy and flux on such states. These tools will be applied to the LQG Hamiltonian operator (in Thiemann regularization) in the second paper of the series. The third paper will present an extension to k≠0 cosmologies and a comparison with alternative regularizations of the Hamiltonian.
    https://arxiv.org/abs/1710.04473
    Entanglement entropy and correlations in loop quantum gravity
    Alexandre Feller, Etera R. Livine
    (Submitted on 12 Oct 2017)
    Black hole entropy is one of the few windows toward the quantum aspects of gravitation and its study over the years have highlighted the holographic nature of gravity. At the non-perturbative level in quantum gravity, promising explanations are being explored in terms of the entanglement entropy between regions of space. In the context of loop quantum gravity, this translates into the analysis of the correlations between regions of the spin network states defining the quantum state of geometry of space. In this paper, we explore a class of states, motivated by results in condensed matter physics, satisfying an area law for entanglement entropy and having non-trivial correlations. We highlight that entanglement comes from holonomy operators acting on loops crossing the boundary of the region.
    https://arxiv.org/abs/1710.06195
    On the volume simplicity constraint in the EPRL spin foam model
    Benjamin Bahr, Vadim Belov
    (Submitted on 17 Oct 2017)
    We propose a quantum version of the quadratic volume simplicity constraint for the EPRL spin foam model. It relies on a formula for the volume of 4-dimensional polyhedra, depending on its bivectors and the knotting class of its boundary graph. While this leads to no further condition for the 4-simplex, the constraint becomes non-trivial for more complicated boundary graphs. We show that, in the semi-classical limit of the hypercuboidal graph, the constraint turns into the geometricity condition observed recently by several authors.
    https://arxiv.org/abs/1711.04991
    Anomaly free cosmological perturbations with generalised holonomy correction in loop quantum cosmology
    Yu Han, Molin Liu
    (Submitted on 14 Nov 2017)
    In the spatially flat case of loop quantum cosmology, the connection k¯ is usually replaced by the μ¯ holonomy sin(μ¯k)μ¯ in the effective theory. In this paper, instead of the μ¯ scheme, we use a generalised, undertermined function g(k¯,p¯) to represent the holonomy and by using the approach of anomaly free constraint algebra we fix all the counter terms in the constraints and find the restriction on the form of g(k¯,p¯), then we derive the gauge invariant equations of motion of the scalar, tensor and vector perturbations and study the inflationary power spectra with generalised holonomy corrections.
    https://arxiv.org/abs/1711.05693
    Connecting Loop Quantum Gravity and String Theory via Quantum Geometry
    Deepak Vaid
    (Submitted on 15 Nov 2017)
    We argue that String Theory and Loop Quantum Gravity can be thought of as describing different regimes of a single unified theory of quantum gravity. LQG can be thought of as providing the pre-geometric exoskeleton out of which macroscopic geometry emerges and String Theory then becomes the \emph{effective} theory which describes the dynamics of that exoskeleton. The core of the argument rests on the claim that the Nambu-Goto action of String Theory can be viewed as the expectation value of the LQG area operator evaluated on the string worldsheet.
    https://arxiv.org/abs/1711.05967
    A Renormalizable SYK-type Tensor Field Theory
    Joseph Ben Geloun, Vincent Rivasseau
    (Submitted on 16 Nov 2017)
    In this paper we introduce a simple field theoretic version of the Carrozza-Tanasa-Klebanov-Tarnopolsky (CTKT) "uncolored" holographic tensor model. It gives a more familiar interpretation to the previously abstract modes of the SYK or CTKT models in terms of momenta. We choose for the tensor propagator the usual Fermionic propagator of condensed matter, with a spherical Fermi surface, but keep the CTKT interactions. Hence our field theory can also be considered as an ordinary condensed matter model with a non-local and non-rotational invariant interaction. Using a multiscale analysis we prove that this field theory is just renormalizable to all orders of perturbation theory in the ultraviolet regime.
    https://arxiv.org/abs/1711.06085
    Gravity Induced Non-Local Effects in the Standard Model
    S. O. Alexeyev, X. Calmet, B. N. Latosh
    We show that the non-locality recently identified in quantum gravity using resummation techniques propagates to the matter sector of the theory. We describe these non-local effects using effective field theory techniques. We derive the complete set of non-local effective operators at order NG2 for theories involving scalar, spinor, and vector fields. We then use recent data from the Large Hadron Collider to set a bound on the scale of space-time non-locality and find M⋆>3×10−11 GeV.
  2. Dec 3, 2017 #2542
    atyy
    https://arxiv.org/abs/1711.08482
    AdS2 holography and the SYK model
    Gábor Sárosi
    (Submitted on 22 Nov 2017)
    These are lecture notes based on a series of lectures presented at the XIII Modave Summer School in Mathematical physics aimed at PhD students and young postdocs. The goal is to give an introduction to some of the recent developments in understanding holography in two bulk dimensions, and its connection to microscopics of near extremal black holes. The first part reviews the motivation to study, and the problems (and their interpretations) with holography for AdS2 spaces. The second part is about the Jackiw-Teitelboim theory and nearly-AdS2 spaces. The third part introduces the Sachdev-Ye-Kitaev model, reviews some of the basic calculations and discusses what features make the model exciting.
    https://arxiv.org/abs/1711.08470
    Propagators for gauge-invariant observables in cosmology
    Markus B. Fröb, William C. C. Lima
    We make a proposal for gauge-invariant observables in perturbative quantum gravity in cosmological spacetimes, building on the recent work of Brunetti et al. [JHEP 08 (2016) 032]. These observables are relational, and are obtained by evaluating the field operator in a field-dependent coordinate system. We show that it is possible to define this coordinate system such that the non-localities inherent in any higher-order observable in quantum gravity are causal, i.e., the value of the gauge-invariant observable at a point x only depends on the metric and inflation perturbations in the past light cone of x. We then construct propagators for the metric and inflaton perturbations in a gauge adapted to that coordinate system, which simplifies the calculation of loop corrections, and give explicit expressions for relevant cases: matter- and radiation-dominated eras and slow-roll inflation.
    https://arxiv.org/abs/1711.09270
    Loop Quantum Cosmology Corrected Gauss-Bonnet Singular Cosmology
    K. Kleidis, V.K. Oikonomou
    (Submitted on 25 Nov 2017)
    In this work we investigate which Loop Quantum Cosmology corrected Gauss-Bonnet F(G) gravity can realize two singular cosmological scenarios, the intermediate inflation and the singular bounce scenarios. The intermediate inflation scenario has a Type III sudden singularity at t=0, while the singular bounce has a soft Type IV singularity. By using perturbative techniques, we find the holonomy corrected F(G) gravities that generate at leading order the aforementioned cosmologies and we also argue that the effect of the holonomy corrections is minor to the power spectrum of the primordial curvature perturbations of the classical theory.
    https://arxiv.org/abs/1711.09941
    Ryu-Takayanagi Formula for Symmetric Random Tensor Networks
    Goffredo Chirco, Daniele Oriti, Mingyi Zhang
    (Submitted on 27 Nov 2017)
    We consider the special case of Random Tensor Networks (RTN) endowed with gauge symmetry constraints on each tensor. We compute the R\`enyi entropy for such states and recover the Ryu-Takayanagi (RT) formula in the large bond regime. The result provides first of all an interesting new extension of the existing derivations of the RT formula for RTNs. Moreover, this extension of the RTN formalism brings it in direct relation with (tensorial) group field theories (and spin networks), and thus provides new tools for realizing the tensor network/geometry duality in the context of background independent quantum gravity, and for importing quantum gravity tools in tensor network research.
    https://arxiv.org/abs/1711.10861
    The time-dependent mass of cosmological perturbations in the hybrid and dressed metric approaches to loop quantum cosmology
    Beatriz Elizaga Navascués, Daniel Martín de Blas, Guillermo A. Mena Marugán
    (Submitted on 29 Nov 2017)
    Loop quantum cosmology has recently been applied in order to extend the analysis of primordial perturbations to the Planck era and discuss the possible effects of quantum geometry on the cosmic microwave background. Two approaches to loop quantum cosmology with admissible ultraviolet behaviour leading to predictions that are compatible with observations are the so-called hybrid and dressed metric approaches. In spite of their similarities and relations, we show in this work that the effective equations that they provide for the evolution of the tensor and scalar perturbations are somewhat different. When backreaction is neglected, the discrepancy appears only in the time-dependent mass term of the corresponding field equations. We explain the origin of this difference, arising from the distinct quantization procedures. Besides, given the privileged role that the Big Bounce plays in loop quantum cosmology, e.g. as a natural instant of time to set initial conditions for the perturbations, we also analyze the positivity of the time-dependent mass when this bounce occurs. We prove that the mass of the tensor perturbations is positive in the hybrid approach when the kinetic contribution to the energy density of the inflaton dominates over its potential, as well as for a considerably large sector of backgrounds around that situation, while this mass is always nonpositive in the dressed metric approach. Similar results are demonstrated for the scalar perturbations in a sector of background solutions that includes the kinetically dominated ones, namely, the mass then is positive for the hybrid approach, whereas it typically becomes negative in the dressed metric case. More precisely, this last statement is strictly valid when the potential is quadratic for values of the inflaton mass that are phenomenologically favored.
    https://arxiv.org/abs/1711.10943
    The loop quantum cosmology bounce as a Kasner transition
    Edward Wilson-Ewing
    For the Bianchi type I space-time (vacuum or with a massless scalar field), the loop quantum cosmology bounce can be viewed as a rapid transition between two classical solutions, with a simple transformation rule relating the Kasner exponents of the two epochs. This transformation rule can be extended to other Bianchi space-times under the assumption that during the loop quantum cosmology bounce the contribution of the spatial curvature to the Hamiltonian constraint is negligible compared to the kinetic terms. For the vacuum Bianchi type IX space-time there are transformation rules for how each of the parameters characterizing the Kasner epochs change during the bounce. This provides a quantum gravity extension to the Mixmaster dynamics of general relativity, and may have interesting implications for the Belinski-Khalatnikov-Lifshitz conjecture.
  3. Dec 23, 2017 #2543
    atyy
    https://arxiv.org/abs/1712.03677
    Covariance and Anomaly-freedom in symmetry-reduced self dual models of Loop Quantum Gravity
    Jibril Ben Achour, Suddhasattwa Brahma
    (Submitted on 11 Dec 2017)
    In effective models of loop quantum gravity (LQG), the curvature of the connection in the Hamiltonian constraint is regularised based on the holonomy of the connection, prior to quantization. At this very first step, whether the holonomy-corrected system of "first-class" constraints form a closed algebra such that they still act as generators of gauge transformations, and consequently eliminate the same number of spurious degrees of freedom, is a crucial question which needs to be clarified before dealing with quantum dynamics. In the real Ashtekar-Barbero framework, such holonomy-corrected models have typically a deformed notion of covariance when no local degrees of freedom are involved, and fail to be (gauge-)covariant in models exhibiting local physical degrees of freedom. Recently discovered no-go results in models involving non-perturbative inhomogeneity challenge the possibility of including holonomy modifications in realistic scenarios depicting gravitational collapse of scalar matter or cylindrical gravitational waves. Moreover, it is known that the inclusion of the μ¯-scheme, which implements a coarse-graining procedure at the effective level, leads to additional difficulties in such models. In this article, we show how such conclusions can be by-passed when working in the self dual formulation, i.e. we investigate the fate of covariance in holonomy-corrected models of LQG based on the original self dual Ashtekar formulation. We consider two systems of particular interest: spherically symmetric gravity minimally coupled to a scalar field and (unpolarized) Gowdy cosmology. Both have local degrees of freedom and, therefore, represent midisuperspace models beyond what has been studied in the LQG literature.
    https://arxiv.org/abs/1712.06918
    On the distribution of the eigenvalues of the area operator in loop quantum gravity
    J. Fernando Barbero, Juan Margalef-Bentabol, Eduardo J. S. Villaseñor
    (Submitted on 19 Dec 2017)
    We study the distribution of the eigenvalues of the area operator in loop quantum gravity concentrating on the part of the spectrum relevant for isolated horizons. We first show that the approximations relying on integer partitions are not sufficient to obtain the asymptotic behaviour of the eigenvalue distribution for large areas. We then develop a method, based on Laplace transforms, that provides a very accurate solution to this problem. The representation that we get is valid for any area and can be used to obtain its asymptotics in the large area limit.
    https://arxiv.org/abs/1712.07266
    Cosmological evolution as squeezing: a toy model for group field cosmology
    Eugene Adjei, Steffen Gielen, Wolfgang Wieland
    We present a simple model of quantum cosmology based on the group field theory (GFT) approach to quantum gravity. The model is formulated on a subspace of the GFT Fock space for the quanta of geometry, with a fixed volume per quantum. In this Hilbert space, cosmological expansion corresponds to the generation of new quanta. Our main insight is that the evolution of a flat FLRW universe with a massless scalar field can be described on this Hilbert space as squeezing, familiar from quantum optics. As in GFT cosmology, we find that the three-volume satisfies an effective Friedmann equation similar to the one of loop quantum cosmology, connecting the classical contracting and expanding solutions by a quantum bounce. The only free parameter in the model is identified with Newton's constant. We also comment on the possible topological interpretation of our squeezed states. This paper can serve an introduction into the main ideas of GFT cosmology without requiring the full GFT formalism; our results can also motivate new developments in GFT and its cosmological application.
  4. Feb 3, 2018 #2544
    atyy
    https://arxiv.org/abs/1801.00273
    A new bound on polymer quantization via an opto-mechanical setup
    M. Khodadi, K. Nozari, S. Dey, A. Bhat, Mir Faizal
    (Submitted on 31 Dec 2017)
    The existence of a minimal measurable length as a characteristic length in the Planck scale is one of the main features of quantum gravity and has been widely explored in the context. Various different deformations of spacetime have been employed successfully for the purpose. However, polymer quantization approach is a relatively new and dynamic field towards the quantum gravity phenomenology, which emerges from the symmetric sector of the loop quantum gravity. In this article, we extend the standard ideas of polymer quantization to find a new and tighter bound on the polymer deformation parameter. Our protocol relies on an opto-mechanical experimental setup that was originally proposed in Ref.\cite{ref:Igor} to explore some interesting phenomena by embedding the minimal length into the standard canonical commutation relation. We extend this scheme to probe the \emph{polymer length} deformed canonical commutation relation of the center of mass mode of a mechanical oscillator with a mass around the Planck scale. The method utilizes the novelty of exchanging the relevant mechanical information with a high intensity optical pulse inside an optical cavity. We also demonstrate that our proposal is within the reach of the current technologies and, thus, it could uncover a decent realization of quantum gravitational phenomena thorough a simple table-top experiment.
    https://arxiv.org/abs/1801.00768
    Emergent de Sitter epoch of the quantum Cosmos
    Mehdi Assanioussi, Andrea Dapor, Klaus Liegener, Tomasz Pawłowski
    (Submitted on 2 Jan 2018)
    The quantum nature of the Big Bang is reexamined in the framework of Loop Quantum Cosmology. The strict application of a regularization procedure to the Hamiltonian, originally developed for the Hamiltonian in loop quantum gravity, leads to a qualitative modification of the bounce paradigm. Quantum gravity effects still lead to a quantum bounce connecting deterministically large classical Universes. However, the evolution features a large epoch of de Sitter Universe, with emergent cosmological constant of Planckian order, smoothly transiting into a flat expanding Universe.
    https://arxiv.org/abs/1801.01479
    Black Holes as Quantum Gravity Condensates
    Daniele Oriti, Daniele Pranzetti, Lorenzo Sindoni
    (Submitted on 4 Jan 2018)
    We model spherically symmetric black holes within the group field theory formalism for quantum gravity via generalised condensate states, involving sums over arbitrarily refined graphs (dual to 3d triangulations). The construction relies heavily on both the combinatorial tools of random tensor models and the quantum geometric data of loop quantum gravity, both part of the group field theory formalism. Armed with the detailed microscopic structure, we compute the entropy associated with the black hole horizon, which turns out to be equivalently the Boltzmann entropy of its microscopic degrees of freedom and the entanglement entropy between the inside and outside regions. We recover the area law under very general conditions, as well as the Bekenstein-Hawking formula. The result is also shown to be generically independent of any specific value of the Immirzi parameter.
    https://arxiv.org/abs/1801.03027
    Characteristic Time Scales for the Geometry Transition of a Black Hole to a White Hole from Spinfoams
    Marios Christodoulou, Fabio D'Ambrosio
    (Submitted on 9 Jan 2018)
    Quantum fluctuations of the metric provide a decay mechanism for black holes, through a transition to a white hole geometry. Old perplexing results by Ambrus and H\'aj\'i\v{c}ek and more recent results by Barcel\'o, Carballo--Rubio and Garay, indicate a characteristic time scale of this process that scales linearly with the mass of the collapsed object. We compute the characteristic time scales involved in the quantum process using Lorentzian Loop Quantum Gravity amplitudes, corroborating these results but reinterpreting and clarifying their physical meaning. We first review and streamline the classical set up, and distinguish and discuss the different time scales involved. We conclude that the aforementioned results concern a time scale that is different from the lifetime, the latter being the much longer time related to the probability of the process to take place. We recover the exponential scaling of the lifetime in the mass, as expected from na\"ive semiclassical arguments for the probability of a tunneling phenomenon to occur.
    https://arxiv.org/abs/1801.03353
    Bohmian quantum gravity and cosmology
    Nelson Pinto-Neto, Ward Struyve
    (Submitted on 10 Jan 2018)
    Quantum gravity aims to describe gravity in quantum mechanical terms. How exactly this needs to be done remains an open question. Various proposals have been put on the table, such as canonical quantum gravity, loop quantum gravity, string theory, etc. These proposals often encounter technical and conceptual problems. In this chapter, we focus on canonical quantum gravity and discuss how many conceptual problems, such as the measurement problem and the problem of time, can be overcome by adopting a Bohmian point of view. In a Bohmian theory (also called pilot-wave theory or de Broglie-Bohm theory, after its originators de Broglie and Bohm), a system is described by certain variables in space-time such as particles or fields or something else, whose dynamics depends on the wave function. In the context of quantum gravity, these variables are a space-time metric and suitable variable for the matter fields (e.g., particles or fields). In addition to solving the conceptual problems, the Bohmian approach yields new applications and predictions in quantum cosmology. These include space-time singularity resolution, new types of semi-classical approximations to quantum gravity, and approximations for quantum perturbations moving in a quantum background.
    https://arxiv.org/abs/1801.06017
    Spin networks on adiabatic quantum computer
    Jakub Mielczarek
    (Submitted on 18 Jan 2018)
    The article is addressing a possibility of implementation of spin network states on adiabatic quantum computer. The discussion is focused on application of currently available technologies and analyzes a concrete example of D-Wave machine. A class of simple spin network states which can be implemented on the Chimera graph architecture of the D-Wave quantum processor is introduced. However, extension beyond the currently available quantum processor topologies is required to simulate more sophisticated spin network states, which may inspire development of new generations of adiabatic quantum computers. A possibility of simulating Loop Quantum Gravity is discussed and a method of solving a graph non-changing scalar (Hamiltonian) constraint with the use of adiabatic quantum computations is proposed.
    https://arxiv.org/abs/1801.07313
    Towards Cosmological Dynamics from Loop Quantum Gravity
    Bao-Fei Li, Parampreet Singh, Anzhong Wang
    (Submitted on 22 Jan 2018 (v1), last revised 1 Feb 2018 (this version, v2))
    We present a systematic study of the cosmological dynamics resulting from an effective Hamiltonian, recently derived in loop quantum gravity using Thiemann's regularization and earlier obtained in loop quantum cosmology (LQC) by keeping the Lorentzian term explicit in the Hamiltonian constraint. We show that quantum geometric effects result in higher than quadratic corrections in energy density in comparison to LQC causing a non-singular bounce. Dynamics can be described by the Hamilton's or the Friedmann-Raychaudhuri equations, but the map between the two descriptions is not one-to-one. A careful analysis resolves the tension on symmetric versus asymmetric bounce in this model, showing that the bounce must be asymmetric and symmetric bounce is physically inconsistent, in contrast to the standard LQC. In addition, the current observations only allow a scenario where the pre-bounce branch is asymptotically de Sitter, similar to a quantization of the Schwarzschild interior in LQC, and the post-bounce branch yields the classical general relativity. For a quadratic potential, we find that a slow-roll inflation generically happens after the bounce, which is quite similar to what happens in LQC.
  5. Feb 17, 2018 #2545
    atyy
    https://arxiv.org/abs/1802.02382
    Space and Time in Loop Quantum Gravity
    Carlo Rovelli
    (Submitted on 7 Feb 2018)
    Quantum gravity is expected to require modifications of the notions of space and time. I discuss and clarify how this happens in Loop Quantum Gravity.
    https://arxiv.org/abs/1802.02661
    Gravitation in terms of observables
    Rodolfo Gambini, Jorge Pullin
    In the 1960's, Mandelstam proposed a new approach to gauge theories and gravity based on loops. The program for gauge theories was completed for Yang--Mills theories by Gambini and Trias in the 1980's. Gauge theories could be understood as representations of certain group: the group of loops. The same formalism could not be implemented at that time for the gravitational case. Here we would like to propose an extension to the case of gravity. The resulting theory is described in terms of loops and open paths and can provide the underpinning for a new quantum representation for gravity distinct from the one used in loop quantum gravity or string theory. In it, space-time points are emergent entities that would only have quasi-classical status. The formulation may be given entirely in terms of Dirac observables that form a complete set of gauge invariant functions that completely define the Riemannian geometry of the spacetime. At the quantum level this formulation will lead to a reduced phase space quantization free of any constraints.
  6. Mar 11, 2018 #2546
    atyy
    https://arxiv.org/abs/1802.06251
    Radial gauge fixing of first order gravity
    Emanuele Alesci, Costantino Pacilio, Daniele Pranzetti
    (Submitted on 17 Feb 2018)
    We consider the first order connection formulation of 4D general relativity in the radial gauge. We show how the partial gauge fixing of the phase space canonical coordinates leads to the appearance of second class constraints in the theory. We employ the gauge unfixing procedure in order to successfully complete the Dirac treatment of the system. While equivalent to the inversion of the Dirac matrix, the gauge unfixing allows us to work directly with the reduced phase space and the ordinary Poisson bracket. At the same time, we explicitly derive the new set of residual first class constraints preserving the partial gauge fixing, which are linear combinations of the original constraints, and these turn out to contain nonlinear terms. While providing an explicit example of how to consistently recast general relativity in a given partial gauge, the main motivation of this classical analysis is the application of the Quantum Reduced Loop Gravity program to a Schwarzschild black hole geometry.
    https://arxiv.org/abs/1802.07033
    The constraint algebra in Smolins' G→0 limit of 4d Euclidean Gravity
    Madhavan Varadarajan
    (Submitted on 20 Feb 2018)
    Smolin's generally covariant GNewton→0 limit of 4d Euclidean gravity is a useful toy model for the study of the constraint algebra in Loop Quantum Gravity. In particular, the commutator between its Hamiltonian constraints has a metric dependent structure function. While a prior LQG like construction of non-trivial anomaly free constraint commutators for the model exists, that work suffers from two defects. First, Smolin's remarks on the inability of the quantum dynamics to generate propagation effects apply. Second, the construction only yields the action of a single Hamiltonian constraint together with the action of its commutator through a continuum limit of corresponding discrete approximants; the continuum limit of a product of 2 or more constraints does not exist. Here, we incorporate changes in the quantum dynamics through structural modifications in the choice of discrete approximants to the quantum Hamiltonian constraint. The new structure is motivated by that responsible for propagation in an LQG like quantization of Paramaterized Field Theory and significantly alters the space of physical states. We study the off shell constraint algebra of the model in the context of these structural changes and show that the continuum limit action of multiple products of Hamiltonian constraints is (a) supported on an appropriate domain of states (b) yields anomaly free commutators between pairs of Hamiltonian constraints and (c) is diffeomorphism covariant. Many of our considerations seem robust enough to be applied to the setting of 4d Euclidean gravity.
    https://arxiv.org/abs/1802.09114
    Loop Quantum Corrected Einstein Yang-Mills Black Holes
    Mason Protter, Andrew DeBenedictis
    (Submitted on 26 Feb 2018)
    In this paper we study the homogeneous interiors of black holes possessing SU(2) Yang-Mills fields subject to corrections inspired by loop quantum gravity. The systems studied possess both magnetic and induced electric Yang-Mills fields. We consider the system of equations both with and without Wilson loop corrections to the Yang-Mills potential. The structure of the Yang-Mills Hamiltonian along with the restriction to homogeneity allows for an anomaly free effective quantization. In particular we study the bounce which replaces the classical singularity and the behavior of the Yang-Mills fields in the quantum corrected interior, which possesses topology R×S2. Beyond the bounce the magnitude of the Yang-Mills electric field asymptotically grows monotonically. This results in an ever expanding R sector even though the two-sphere volume is asymptotically constant. The results are similar with and without Wilson loop corrections on the Yang-Mills potential.
    https://arxiv.org/abs/1803.00332
    Geometry Transition in Covariant Loop Quantum Gravity
    Christodoulou Marios
    (Submitted on 1 Mar 2018)
    In this manuscript we present a calculation of a physical observable in a non-perturbative quantum gravitational physical process from covariant Loop Quantum Gravity. The process regards the transition of a trapped region to an anti--trapped region, treated as a quantum geometry transition akin to gravitational tunneling. Figuratively speaking, this is a quantum transition of a black hole to a white hole. The physical observables are the characteristic timescales in which the process takes place.
    After an introduction, we begin with two chapters that review, define and extend main tools relevant to Lorentzian spinfoams and their semiclassical limit. We then dedicate a chapter to the classical exterior spacetime, which provides the setup for the problem. In the last two chapters, we arrive at an explicit, analytically well-defined and finite expression for a transition amplitude describing this process and use the semiclassical approximation to estimate the relevant amplitudes for an arbitrary choice of boundary conditions. We conclude that the transition is predicted to be allowed by LQG, with a characteristic duration that is linear in the mass, when the process takes place. The probability for the process to take place is exponentially suppressed but non-zero, resulting to a long lifetime.
    Comments: PhD thesis submitted for the degree of Doctor in Theoretical and Mathematical Physics. Defended at the Center for Theoretical Physics/CNRS/Aix-Marseille University, the 23rd of October 2017. The manuscript is written in English and begins with a short summary in French
    https://arxiv.org/abs/1803.01119
    Effective line elements and black-hole models in canonical (loop) quantum gravity
    Martin Bojowald, Suddhasattwa Brahma, Dong-han Yeom
    (Submitted on 3 Mar 2018)
    Canonical quantization is often used to suggest new effects in quantum gravity, in the dynamics as well as the structure of space-time. Usually, possible phenomena are first seen in a modified version of the classical dynamics, for instance in an effective Friedmann equation, but there should also be implications for a modified space-time structure. Quantum space-time effects, however, are often ignored in this setting because they are not obvious: they require a careful analysis of gauge transformations and the anomaly problem. It is shown here how modified space-time structures and effective line elements can be derived unambiguously, provided an off-shell anomaly-free system of modified constraints exists. The resulting effective line elements reveal signature change as an inescapable consequence of non-classical gauge transformations in the presence of holonomy modifications. The general framework is then specialized to black-hole models in loop quantum gravity. In contrast to previous studies, a self-consistent space-time structure is taken into account, leading to a new picture of black-hole interiors.
    https://arxiv.org/abs/1803.01152
    Loop quantum deformation of a Schwarzschild black hole: an effective metric
    Jibril Ben Achour, Frédéric Lamy, Hongguang Liu, Karim Noui
    We consider the modified Einstein equations obtained in the framework of effective loop quantum gravity for spherically symmetric space-times. When one takes into account (only point-wise holonomy) quantum corrections, the deformation of Einstein equations is parametrized by a function f(x) of one variable . We solve explicitly these equations for static black holes and find the effective metric in the region inside the black hole for any f(x). When f(x) is the usual function used in loop quantum gravity, the effective metric presents strong similarities with the Reissner-Nordstrom metric (with a regular trapped region): it tends to the expected Schwarzschild metric when one approaches the outer horizon, and the inner horizon replaces the original Schwarzschild singularity. We discuss the possibility to extend the solution outside the trapped region, and possible phenomenological consequences of our results.
    https://arxiv.org/abs/1803.02577
    The Bronstein hypercube of quantum gravity
    Daniele Oriti
    (Submitted on 7 Mar 2018 (v1), last revised 8 Mar 2018 (this version, v2))
    We argue for enlarging the traditional view of quantum gravity, based on "quantizing GR", to include explicitly the non-spatiotemporal nature of the fundamental building blocks suggested by several modern quantum gravity approaches (and some semi-classical arguments), and to focus more on the issue of the emergence of continuum spacetime and geometry from their collective dynamics. We also discuss some recent developments in quantum gravity research, aiming at realising these ideas, in the context of group field theory, random tensor models, simplicial quantum gravity, loop quantum gravity, spin foam models.
  7. Mar 29, 2018 #2547
    atyy
    https://arxiv.org/abs/1803.04374
    Spacetime is as spacetime does
    Vincent Lam, Christian Wuthrich
    (Submitted on 12 Mar 2018)
    Theories of quantum gravity generically presuppose or predict that the reality underlying relativistic spacetimes they are describing is significantly non-spatiotemporal. On pain of empirical incoherence, approaches to quantum gravity must establish how relativistic spacetime emerges from their non-spatiotemporal structures. We argue that in order to secure this emergence, it is sufficient to establish that only those features of relativistic spacetimes functionally relevant in producing empirical evidence must be recovered. In order to complete this task, an account must be given of how the more fundamental structures instantiate these functional roles. We illustrate the general idea in the context of causal set theory and loop quantum gravity, two prominent approaches to quantum gravity.
    https://arxiv.org/abs/1803.06963
    Interpreting Theories without a Spacetime
    Sebastian De Haro, Henk De Regt
    (Submitted on 19 Mar 2018)
    In this paper we have two aims: first, to draw attention to the close connexion between interpretation and scientific understanding; second, to give a detailed account of how theories without a spacetime can be interpreted, and so of how they can be understood.
    In order to do so, we of course need an account of what is meant by a theory `without a spacetime': which we also provide in this paper.
    We describe three tools, used by physicists, aimed at constructing interpretations which are adequate for the goal of understanding. We analyse examples from high-energy physics illustrating how physicists use these tools to construct interpretations and thereby attain understanding. The examples are: the 't Hooft approximation of gauge theories, random matrix models, causal sets, loop quantum gravity, and group field theory.
    https://arxiv.org/abs/1803.09653
    Mimetic Loop Quantum Cosmology
    Jaume de Haro, Llibert Aresté Saló, Supriya Pan
    (Submitted on 26 Mar 2018)
    Considering as usual that the underlying geometry of our universe is well described by the spatially flat Friedmann-Lemaitre-Robertson-Walker line element, we show that the background of holonomy corrected Loop Quantum Cosmology (LQC) is equivalent to a simple modified version of the mimetic gravity. We also analyze the scalar and tensor perturbations of this modified mimetic model from which we find that, at the level of scalar perturbations, the modified mimetic model is exactly equivalent to the LQC while at the level of tensor perturbations, the modified mimetic gravity is indistinguishable from the General Relativity.
    https://arxiv.org/abs/1803.10289
    Emergence of Spacetime in a restricted Spin-foam model
    Sebastian Steinhaus, Johannes Thürigen
    (Submitted on 27 Mar 2018)
    The spectral dimension has proven to be a very informative observable to understand the properties of quantum geometries in approaches to quantum gravity. In loop quantum gravity and its spin foam description, it has not been possible so far to calculate the spectral dimension of spacetime. As a first step towards this goal, here we determine the spacetime spectral dimension in the simplified spin foam model restricted to hypercuboids. Using Monte Carlo methods we compute the spectral dimension for state sums over periodic spin foam configurations on infinite lattices. For given periodicity, i.e. number of degrees of freedom, we find a range of scale where an intermediate spectral dimension between 0 and 4 can be found, continuously depending on the parameter of the model. Under an assumption on the statistical behaviour of the Laplacian we can explain these results analytically. This allows us to take the thermodynamic limit of large periodicity and find a phase transition from a regime of effectively 0-dimensional to 4-dimensional spacetime. At the point of phase transition, dynamics of the model are scale invariant which can be seen as restoration of diffeomorphism invariance of flat space. Considering the spectral dimension as an order parameter for renormalization we find a renormalization group flow to this point as well. Being the first instance of an emergence of 4-dimensional spacetime in a spin foam model, the properties responsible for this result seem to be rather generic. We thus expect similar results for more general, less restricted spin foam models.
  8. Apr 4, 2018 #2548
    atyy
    https://arxiv.org/abs/1803.10807
    Hamiltonian structure and connection-dynamics of Weyl gravity
    Qian Chen, Yongge Ma
    (Submitted on 28 Mar 2018)
    A crucial property of Weyl gravity is its conformal invariance. It is shown how this gauge symmetry is exactly reflected by the two constraints in the Hamiltonian framework. Since the spatial 3-metric is one of the configuration variables. The phase space of Weyl gravity can be extended to include internal gauge freedom by triad formalism. Moreover, by a canonical transformation, we obtain a new Hamiltonian formulation of Weyl gravity with an SU(2) connection as one of its configuration variables. This connection dynamical formalism lays a foundation to quantize Weyl gravity nonperturbatively by applying the method of loop quantum gravity.
    https://arxiv.org/abs/1803.10858
    Is the average of timelike singularities really spacelike?
    Eugenio Bianchi, Hal M. Haggard
    Due to quantum fluctuations, a non-rotating black hole should be the average over an ensemble of black hole geometries with angular momentum. This observation invites the question: Is the average of timelike singularities really spacelike? We use the Bekenstein-Hawking entropy formula to introduce a microcanonical ensemble for spin fluctuations and argue that the onset of quantum gravity is always spacelike. We also hint at the possibility of an observational test.
    https://arxiv.org/abs/1803.10809
    Volume and Boundary Face Area of a Regular Tetrahedron in a Constant Curvature Space
    Omar Nemoul, Noureddine Mebarki
    (Submitted on 23 Mar 2018)
    An example of the volume and boundary face area of a curved polyhedron for the case of regular spherical and hyperbolic tetrahedron is discussed. An exact formula is explicitly derived as a function of the scalar curvature and the edge length. This work can be used in loop quantum gravity and Regge calculus in the context of a non-vanishing cosmological constant.
    https://arxiv.org/abs/1804.00012
    Effective universality in quantum gravity
    Astrid Eichhorn, Peter Labus, Jan M. Pawlowski, Manuel Reichert
    (Submitted on 30 Mar 2018)
    We investigate the asymptotic safety scenario for a scalar-gravity system. This system contains two avatars of the dynamical Newton coupling, a gravitational self-coupling and a scalar-graviton coupling. We uncover an effective universality for the dynamical Newton coupling on the quantum level: its momentum-dependent avatars are in remarkable quantitative agreement in the scaling regime of the UV fixed point. For the background Newton coupling, this effective universality is not present, but qualitative agreement remains.
    https://arxiv.org/abs/1804.00960
    Singularity from star collapse, torsion and asymptotic safety of gravity
    Abhishek Majhi
    (Submitted on 3 Apr 2018)
    A star of mass greater than the Chandrasekhar limit is believed to undergo a gravitational collapse to form a singularity, owing to Hawking-Penrose singularity theorem which is based on the Raychaudhuri equation in the absence of torsion. We argue that the spin-aspect of matter can lead to the evasion of singularity, caused by its mass-aspect, via torsion in asymptotically safe gravity.
    https://arxiv.org/abs/1804.01003
    An area rescaling ansatz and black hole entropy from loop quantum gravity
    Abhishek Majhi
    Considering the possibility of `renormalization' of the gravitational constant on the horizon, leading to a dependence on the level of the associated Chern-Simons theory, a rescaled area spectrum is proposed for the non-rotating black hole horizon in loop quantum gravity. The statistical mechanical calculation leading to the entropy provides a unique choice of the rescaling function for which the Bekenstein-Hawking area law is yielded without the need to choose the Barbero-Immirzi parameter (γ). γ is determined by studying the limit in which the `renormalized' gravitational constant on the horizon asymptotically approaches the `bare' value. Unlike the usual, much criticized, practice of choosing γ just for the sake of the entropy matching the area law, its value is now rather determined by a physical consistency requirement.
  9. Apr 10, 2018 #2549
    atyy
    https://arxiv.org/abs/1804.02184
    The emergence of space and time
    Christian Wuthrich
    (Submitted on 6 Apr 2018)
    Research in quantum gravity strongly suggests that our world in not fundamentally spatiotemporal, but that spacetime may only emerge in some sense from a non-spatiotemporal structure, as this paper illustrates in the case of causal set theory and loop quantum gravity. This would raise philosophical concerns regarding the empirical coherence and general adequacy of theories in quantum gravity. If it can be established, however, that spacetime emerges in the appropriate circumstances and how all its relevant aspects are explained in fundamental non-spatiotemporal terms, then the challenge is fully met. It is argued that a form of spacetime functionalism offers the most promising template for this project.
    https://arxiv.org/abs/1804.02428
    A predictive framework for quantum gravity and black hole to white hole transition
    Robert Oeckl (CCM-UNAM)
    The apparent incompatibility between quantum theory and general relativity has long hampered efforts to find a quantum theory of gravity. The recently proposed positive formalism for quantum theory purports to remove this incompatibility. We showcase the power of the positive formalism by applying it to the black hole to white hole transition scenario that has been proposed as a possible effect of quantum gravity. We show how the characteristic observable of this scenario, the bounce time, can be predicted within the positive formalism, while a traditional S-matrix approach fails at this task. Our result also involves a conceptually novel use of positive operator valued measures.
    https://arxiv.org/abs/1804.02262
    Cosmological consequences of Quantum Gravity proposals
    Marco de Cesare
    In this thesis, we study the implications of Quantum Gravity models for the dynamics of spacetime and the ensuing departures from classical General Relativity. The main focus is on cosmological applications, particularly the impact of quantum gravitational effects on the dynamics of a homogenous and isotropic cosmological background. Our interest lies in the consequences for the evolution of the early universe and singularity resolution, as well as in the possibility of providing an alternative explanation for dark matter and dark energy in the late universe.
    The thesis is divided into two main parts, dedicated to alternative (and complementary) ways of tackling the problem of Quantum Gravity. The first part is concerned with cosmological applications of background independent approaches to Quantum Gravity, both in the context of loop quantisation and in quantum geometrodynamics. Particularly relevant in this work is the Group Field Theory approach, which we use to study the effective dynamics of the emergent universe from a full theory of Quantum Gravity (i.e. without symmetry reduction).
    In the second part, modified gravity theories are introduced as tools to provide an effective description of quantum gravitational effects, e.g. by introducing new degrees of freedom and symmetries. Particularly relevant in this respect is local conformal invariance, which finds a natural realisation in the framework of Weyl geometry. We build a modified theory of gravity based on such symmetry principle, and argue that new fields in the extended gravitational sector may play the role of dark matter. New degrees of freedom are also natural in models with varying fundamental `constants', which we examine critically.
    Finally, we discuss prospects for future work and point at directions for the derivation of realistic cosmological models from Quantum Gravity candidates.
    https://arxiv.org/abs/1804.02560
    Quantum gravity for piecewise flat spacetimes
    Aleksandar Mikovic, Marko Vojinovic
    (Submitted on 7 Apr 2018)
    We describe a theory of quantum gravity which is based on the assumption that the spacetime structure at small distances is given by a piecewise linear (PL) 4-manifold corresponding to a triangulation of a smooth 4-manifold. The fundamental degrees of freedom are the edge lengths of the triangulation. One can work with finitely many edge lengths, so that the corresponding Regge path integral can be made finite by using an appropriate path-integral measure. The semi-classical limit is computed by using the effective action formalism, and the existence of a semi-classical effective action restricts the choice of the path-integral measure. The classical limit is given by the Regge action, so that one has a quantum gravity theory for a piecewise-flat general relativity. By using the effective action formalism we show that the observed value of the cosmological constant can be recovered from the effective cosmological constant. When the number of 4-simplices in the spacetime triangulation is large, then the PL effective action is well approximated by a quantum field theory effective action with a physical cutoff determined by the smallest edge length.
  10. Jul 13, 2018 #2550
    atyy
    https://arxiv.org/abs/1804.00023
    Renormalization in symmetry restricted spin foam models with curvature
    Benjamin Bahr, Giovanni Rabuffo, Sebastian Steinhaus
    (Submitted on 30 Mar 2018 (v1), last revised 17 Apr 2018 (this version, v2))
    We study the renormalization group flow of the Euclidean Engle-Pereira-Rovelli-Livine and Freidel-Krasnov (EPRL-FK) spin foam model in its asymptotic limit. The vertex amplitude is deformed to include a cosmological constant term. The state sum is reduced to describe a foliated spacetime whose spatial slices are flat, isotropic and homogeneous. The model admits a non-vanishing extrinsic curvature whereas the scale factor can expand or contract at successive time steps.
    The reduction of degrees of freedom allows a numerical evaluation of certain geometric observables on coarser and finer discretizations. Their comparison defines the renormalization group (RG) flow of the model in the parameters (α,Λ,G). We first consider the projection of the RG flow along the α direction, which shows a UV-attractive fixed point. Then, we extend our analysis to two- and three-dimensional parameter spaces. Most notably, we find the indications of a fixed point in the (α,Λ,G) space showing one attractive and two repulsive directions.
    https://arxiv.org/abs/1804.04147
    White-hole dark matter and the origin of past low-entropy
    Carlo Rovelli, Francesca Vidotto
    (Submitted on 11 Apr 2018 (v1), last revised 21 Apr 2018 (this version, v2))
    Recent results on the end of black hole evaporation give new weight to the hypothesis that a component of dark matter could be formed by remnants of evaporated black holes: stable Planck-size white holes with a large interior. The expected lifetime of these objects is consistent with their production at reheating. But remnants could also be pre-big bang relics in a bounce cosmology, and this possibility has strong implications on the issue of the source of past low entropy: it could realise a perspectival interpretation of past low entropy. The ideas briefly presented in this essay are developed in forthcoming papers.
    https://arxiv.org/abs/1805.08257
    Probing the Shape of Quantum Surfaces: the Quadrupole Moment Operator
    Christophe Goeller, Etera R. Livine
    (Submitted on 21 May 2018)
    The standard toolkit of operators to probe quanta of geometry in loop quantum gravity consists in area and volume operators as well as holonomy operators. New operators have been defined, in the U(N) framework for intertwiners, which allow to explore the finer structure of quanta of geometry. However these operators do not carry information on the global shape of the intertwiners. Here we introduce dual multipole moments for continuous and discrete surfaces, defined through the normal vector to the surface, taking special care to maintain parametrization invariance. These are raised to multipole operators probing the shape of quantum surfaces. Further focusing on the quadrupole moment, we show that it appears as the Hessian matrix of the large spin Gaussian approximation of coherent intertwiners, which is the standard method for extracting the semi-classical regime of spinfoam transition amplitudes. This offers an improvement on the usual loop quantum gravity techniques, which mostly focus on the volume operator, in the perspective of modeling (quantum) gravitational waves as shape fluctuations waves propagating on spin network states.
    https://arxiv.org/abs/1804.08643
    Loop quantum gravity and the continuum
    Wolfgang Wieland
    (Submitted on 23 Apr 2018)
    In this paper, we will make an attempt to clarify the relation between three-dimensional euclidean loop quantum gravity with vanishing cosmological constant and quantum field theory in the continuum. We will argue, in particular, that in three spacetime dimensions the discrete spectra for the geometric boundary observables that we find in loop quantum gravity can be understood from the quantisation of a conformal boundary field theory in the continuum without ever introducing spin networks or triangulations of space. At a technical level, the starting point is the Hamiltonian formalism for general relativity in regions with boundaries at finite distance. At these finite boundaries, we choose specific Robin boundary conditions (the boundary is a minimal surface) that are derived from a boundary field theory for an SU(2) boundary spinor, which is minimally coupled to the spin connection in the bulk. The resulting boundary equations of motion define a conformal field theory with vanishing central charge. We will quantise this boundary field theory and show that the length of a one-dimensional cross section of the boundary has a discrete spectrum. In addition, we will introduce a new class of coherent states, study the quasi-local observables that generate the quasi-local Virasoro algebra and discuss some strategies to evaluate the partition function of the theory.
    https://arxiv.org/abs/1805.08644
    On the Hamiltonian operator in loop quantum gravity
    Cong Zhang, Jerzy Lewandowski, Yongge Ma
    (Submitted on 22 May 2018 (v1), last revised 23 May 2018 (this version, v2))
    Although the physical Hamiltonian operator can be constructed in the deparameterized model of loop quantum gravity coupled to a scalar field, its property is still unknown. This open issue is attacked in this paper by considering an operator H^v representing the square of the physical Hamiltonian operator acting nontrivially on two-valent spin networks. The Hilbert space Hv preserved by the graphing changing operator H^v is consist of spin networks with a single two-valent non-degenerate vertex. The matrix element of H^v are explicitly worked out in a suitable basis. It turns out that the operator H^v is essentially self-adjoint, which implies a well-defined physical Hamiltonian operator in Hv for the deparameterized model.
    https://arxiv.org/abs/1804.11101
    The Tensor Track V: Holographic Tensors
    Nicolas Delporte, Vincent Rivasseau
    (Submitted on 30 Apr 2018)
    We review the fast developing subject of tensor models for the NAdS2/NCFT1 holographic correspondence. We include a brief review of the Sachdev-Ye-Kitaev (SYK) model and then focus on the associated quantum mechanical tensor models (GW and CTKT). We examine their main features and how they compare with SYK. To end, we discuss different extensions: the large D limit of matrix-tensor models, the large N expansion of symmetric/antisymmetric tensors, the use of probes, the construction of a bilocal action for tensors, some attempts to extend the above models to higher dimensions and a proposal to break the tensor symmetry.
    https://arxiv.org/abs/1805.01619
    Functional Renormalization Group analysis of rank 3 tensorial group field theory: The full quartic invariant truncation
    Joseph Ben Geloun, Tim A. Koslowski, Daniele Oriti, Antonio D. Pereira
    (Submitted on 4 May 2018)
    In this paper we consider the complete momentum-independent quartic order truncation for the effective average action of a real Abelian rank 3 tensorial group field theory. This complete truncation includes non-melonic as well as double-trace interactions. In the usual functional renormalization group perspective, the inclusion of more operators that belong to the underlying theory space corresponds to an improvement of the truncation of the effective average action. We show that the inclusion of non-melonic and double-trace operators in the truncation brings subtleties. In particular, we discuss the assignment of scaling dimensions to the non-melonic sector and how the inclusion of double-trace operators considerably changes the results for critical exponents when they are not included. We argue that this is not a particular problem of the present model by comparing the results with a pure tensor model. We discuss how these issues should be investigated in future work.
    https://arxiv.org/abs/1805.03099
    The separate universe framework in group field theory condensate cosmology
    Florian Gerhardt, Daniele Oriti, Edward Wilson-Ewing
    (Submitted on 8 May 2018)
    We use the separate universe framework to study cosmological perturbations within the group field theory formalism for quantum gravity, based on multi-condensate quantum states. Working with a group field theory action for gravity minimally coupled to four scalar fields that can act as a set of relational clock and rods, we argue that these multi-condensate states correspond to cosmological space-times with small long-wavelength scalar perturbations. Equations of motion for the cosmological perturbations are derived, which in the classical limit agree with the standard results of general relativity and also include quantum gravity corrections that become important when the space-time curvature approaches the Planck scale.
    https://arxiv.org/abs/1805.03224
    Pre-big-bang black-hole remnants and the past low entropy
    Dark matter could be composed by black-hole remnants formed before the big-bang era in a bouncing cosmology. This hypothetical scenario has major implications on the issue of the arrow of time: it would upset a common attribution of past low entropy to the state of the geometry, and provide a concrete realisation to the perspectival interpretation of past low entropy.
    https://arxiv.org/abs/1805.03872
    Small black/white hole stability and dark matter
    (Submitted on 10 May 2018)
    We show that the expected lifetime of white holes formed as remnants of evaporated black holes is consistent with their production at reheating. We give a simple quantum description of these objects and argue that a quantum superposition of black and white holes with large interiors is stable, because it is protected by the existence of a minimal eigenvalue of the area, predicted by Loop Quantum Gravity. These two results support the hypothesis that a component of dark matter could be formed by small black hole remnants.
    https://arxiv.org/abs/1806.00456
    Towards a dual spin network basis for (3+1)d lattice gauge theories and topological phases
    Clement Delcamp, Bianca Dittrich
    (Submitted on 1 Jun 2018)
    Using a recent strategy to encode the space of flat connections on a three-manifold with string-like defects into the space of flat connections on a so-called 2d Heegaard surface, we propose a novel way to define gauge invariant bases for (3+1)d lattice gauge theories and gauge models of topological phases. In particular, this method reconstructs the spin network basis and yields a novel dual spin network basis. While the spin network basis allows to interpret states in terms of electric excitations, on top of a vacuum sharply peaked on a vanishing electric field, the dual spin network basis describes magnetic (or curvature) excitations, on top of a vacuum sharply peaked on a vanishing magnetic field (or flat connection). This technique is also applicable for manifolds with boundaries. We distinguish in particular a dual pair of boundary conditions, namely of electric type and of magnetic type. This can be used to consider a generalization of Ocneanu's tube algebra in order to reveal the algebraic structure of the excitations associated with certain 3d manifolds.
    https://arxiv.org/abs/1807.03066
    Numerical methods for EPRL spin foam transition amplitudes and Lorentzian recouping theory
    Pietro Dona, Giorgio Sarno
    (Submitted on 9 Jul 2018)
    The intricated combinatorial structure and the non-compactness of the Lorentz group have always made the computation of SL(2,C) EPRL spin foam transition amplitudes a very hard and resource demanding task. With \texttt{sl2cfoam} we provide a C-coded library for the evaluation of the Lorentzian EPRL vertex amplitude. We provide a tool to compute the Lorentzian EPRL 4-simplex vertex amplitude in the intertwiner basis and some utilities to evaluate SU(2) invariants, booster functions and SL(2,C) Clebsch-Gordan coefficients. We discuss the data storage, parallelizations, time, and memory performances and possible future developments.
    https://arxiv.org/abs/1807.03334
    An introduction to the SYK model
    Vladimir Rosenhaus
    These notes are a short introduction to the Sachdev-Ye-Kitaev model. We discuss: SYK and tensor models as a new class of large N quantum field theories, the near-conformal invariance in the infrared, the computation of correlation functions, generalizations of SYK, and applications to AdS/CFT and strange metals.
    https://arxiv.org/abs/1807.02501
    Tensor networks as path integral geometry
    Ashley Milsted, Guifre Vidal
    (Submitted on 6 Jul 2018)
    In the context of a quantum critical spin chain whose low energy physics corresponds to a conformal field theory (CFT), it was recently demonstrated [A. Milsted G. Vidal, arXiv:1805.12524] that certain classes of tensor networks used for numerically describing the ground state of the spin chain can also be used to implement (discrete, approximate versions of) conformal transformations on the lattice. In the continuum, the same conformal transformations can be implemented through a CFT path integral on some curved spacetime. Based on this observation, in this paper we propose to interpret the tensor networks themselves as a path integrals on curved spacetime. This perspective assigns (a discrete, approximate version of) a geometry to the tensor network, namely that of the underlying curved spacetime.
  11. Aug 17, 2018 #2551
    atyy
    https://arxiv.org/abs/1807.06098
    Spin-foam model for gravity coupled to massless scalar field
    Marcin Kisielowski, Jerzy Lewandowski
    (Submitted on 16 Jul 2018)
    A spin-foam model is derived from the canonical model of Loop Quantum Gravity coupled to a massless scalar field. We generalized to the full theory the scheme first proposed in the context of Loop Quantum Cosmology by Ashtekar, Campiglia and Henderson, later developed by Henderson, Rovelli, Vidotto and Wilson-Ewing.
    https://arxiv.org/abs/1807.06354
    Hamiltonian analysis of the BFCG formulation of General Relativity
    Aleksandar Mikovic, Miguel A. Oliveira, Marko Vojinovic
    (Submitted on 17 Jul 2018)
    We perform the complete Hamiltonian analysis of the BFCG action for General Relativity. We determine all the constraints of the theory and classify them into the first-class and the second-class constraints. We also show how the canonical formulation of BFCG General Relativity reduces to the Einstein-Cartan and triad canonical formulations. The reduced phase space analysis also gives a 2-connection which is suitable for the construction of a spin-foam basis which will be a categorical generalization of the spin-network basis from Loop Quantum Gravity.
    https://arxiv.org/abs/1807.06848
    Deformations of Lorentzian Polyhedra: Kapovich-Millson phase space and SU(1,1) Intertwiners
    Etera R. Livine
    (Submitted on 18 Jul 2018)
    We describe the Lorentzian version of the Kapovitch-Millson phase space for polyhedra with N faces. Starting with the Schwinger representation of the su(1,1) Lie algebra in terms of a pair of complex variables (or spinor), we define the phase space for a space-like vectors in the three-dimensional Minkowski space R1,2. Considering N copies of this space, quotiented by a closure constraint forcing the sum of those 3-vectors to vanish, we obtain the phase space for Lorentzian polyhedra with N faces whose normal vectors are space-like, up to Lorentz transformations. We identify a generating set of SU(1,1)-invariant observables, whose flow by the Poisson bracket generate both area-preserving and area-changing deformations. We further show that the area-preserving observables form a glN(R) Lie algebra and that they generate a GLN(R) action on Lorentzian polyhedra at fixed total area. That action is cyclic and all Lorentzian polyhedra can be obtained from a totally squashed polyhedron (with only two non-trivial faces) by a GLN(R) transformation. All those features carry on to the quantum level, where quantum Lorentzian polyhedra are defined as SU(1,1) intertwiners between unitary SU(1,1)-representations from the principal continuous series. Those SU(1,1)-intertwiners are the building blocks of spin network states in loop quantum gravity in 3+1 dimensions for time-like slicing and the present analysis applies to deformations of the quantum geometry of time-like boundaries in quantum gravity, which is especially relevant to the study of quasi-local observables and holographic duality.
    https://arxiv.org/abs/1807.10704
    Gravitational Fluctuations as an Alternative to Inflation
    Herbert W. Hamber, Lu Heng Sunny Yu
    (Submitted on 27 Jul 2018)
    In this work we explore an explanation for the galaxy power spectrum P(k) based on the non-perturbative quantum field-theoretical treatment of Einstein gravity, instead of one based on inflation models. In particular the power spectral index, which represents the slope on the P(k) graph, can be related to critical scaling exponents derived from the Wilson renormalization group analysis, and one finds that the derived value fits favorably with the Sloan Digital Sky Survey telescope data. We then make use of the transfer functions, based only on the Boltzmann equations which describe states out of equilibrium, and Einstein's General Relativity, to extrapolate the power spectrum to the Cosmic Microwave Background (CMB) regime and find that the results fits rather well with current data. Our approach contrasts with the conventional explanation which uses inflation to generate the scale invariant Harrison-Zel'dovich spectrum on CMB scales, and uses the transfer function to extrapolate it to galaxy regime. The results we present here only assumes quantum field theory and Einstein's Gravity, and hence provides a competing explanation of the power spectrum, without relying on the assumptions usually associated with inflationary models.
    https://arxiv.org/abs/1808.00207
    Quantum fields in the background spacetime of a loop quantum gravity black hole
    Flora Moulin, Killian Martineau, Julien Grain, Aurélien Barrau
    (Submitted on 1 Aug 2018)
    The description of black holes in loop quantum gravity is a hard and tricky task. In this article, we focus on a minisuperspace approach based on a polymerization procedure. We consider the resulting effective metric and study the propagation of quantum fields in this background. The cross sections for scalar particles and fermions are explicitly calculated. The radial equation of motion is also derived in full generality, beyond the specifically considered metric.
    https://arxiv.org/abs/1808.00673
    From Euclidean to Lorentzian Loop Quantum Gravity via a Positive Complexifier
    (Submitted on 2 Aug 2018 (v1), last revised 5 Aug 2018 (this version, v2))
    We construct a positive complexifier, differentiable almost everywhere on the classical phase space of real triads and SU(2) connections, which generates a Wick Transform from Euclidean to Lorentzian gravity everywhere except on a phase space set of measure zero. This Wick transform assigns an equal role to the self dual and anti-self dual Ashtekar variables in quantum theory. We argue that the appropriate quantum arena for an analysis of the properties of the Wick rotation is the diffeomorphism invariant Hilbert space of Loop Quantum Gravity (LQG) rather than its kinematic Hilbert space. We examine issues related to the construction, in quantum theory, of the positive complexifier as a positive operator on this diffeomorphism invariant Hilbert space. Assuming the existence of such an operator, we explore the possibility of identifying physical states in Lorentzian LQG as Wick rotated images of physical states in the Euclidean theory. Our considerations derive from Thiemann's remarkable proposal to define Lorentzian LQG from Euclidean LQG via the implementation in quantum theory of a phase space `Wick rotation' which maps real Ashtekar-Barbero variables to Ashtekar's complex, self dual variables.
    https://arxiv.org/abs/1808.01252
    A review on Loop Quantum Gravity
    Pablo Antonio Moreno Casares
    (Submitted on 3 Aug 2018)
    The aim of this dissertation is to review `Loop Quantum Gravity', explaining the main structure of the theory and indicating its main open issues. We will develop the two main lines of research for the theory: the canonical quantization (first two chapters) and spin foams (third). The final chapter will be devoted to studying some of the problems of the theory and what things remain to be developed. In chapter 3 we will also include an example of a simple calculation done in the frame of LQG: Schwarzschild black hole entropy.
    https://arxiv.org/abs/1808.01744
    The no-boundary wave function for loop quantum cosmology
    (Submitted on 6 Aug 2018)
    Proposing smooth initial conditions is one of the most important tasks in quantum cosmology. On the other hand, the low-energy effective action, appearing in the semiclassical path integral, can get nontrivial quantum corrections near classical singularities due to specific quantum gravity proposals. In this article, we combine the well-known no-boundary proposal for the wavefunction of the universe with quantum modifications coming from loop quantum cosmology (LQC). Remarkably, we find that the restriction of a `slow-roll' type potential in the original Hartle-Hawking proposal is considerably relaxed due to quantum geometry regularizations. Interestingly, the same effects responsible for singularity-resolution in LQC also end up expanding the allowed space of smooth initial conditions leading to an inflationary universe.
  12. Oct 10, 2018 #2552
    julian
    https://arxiv.org/abs/1808.00535
    Pure states statistical mechanics: On its foundations and applications to quantum gravity
    Fabio Anza
    The project concerns the interplay among quantum mechanics, statistical mechanics and thermodynamics, in isolated quantum systems. The underlying goal is to improve our understanding of the concept of thermal equilibrium in quantum systems. First, I investigated the role played by observables and measurements in the emergence of thermal behaviour. This led to a new notion of thermal equilibrium which is specific for a given observable, rather than for the whole state of the system. The equilibrium picture that emerges is a generalization of statistical mechanics in which we are not interested in the state of the system but only in the outcome of the measurement process. I investigated how this picture relates to one of the most promising approaches for the emergence of thermal behaviour in isolated quantum systems: the Eigenstate Thermalization Hypothesis. Then, I applied the results to study some equilibrium properties of many-body localised systems. Despite the localization phenomenon, which prevents thermalization of subsystems, I was able to show that we can still use the predictions of statistical mechanics to describe the equilibrium of some observables. Moreover, the intuition developed in the process led me to propose an experimentally accessible way to unravel the interacting nature of many-body localised systems. Second, I exploited the "Concentration of Measure" phenomenon to study the macroscopic properties of the basis states of Loop Quantum Gravity. These techniques were previously used to explain why the thermal behaviour in quantum systems is such an ubiquitous phenomenon, at the macroscopic scale. I focused on the local properties, their thermodynamic behaviour and interplay with the semiclassical limit. This was motivated by the necessity to understand, from a quantum gravity perspective, how and why a classical horizon exhibits thermal properties.
    https://arxiv.org/abs/1808.03472
    Towards conditions for black-hole singularity-resolution in asymptotically safe quantum gravity
    Ademola Adeifeoba, Astrid Eichhorn, Alessia Platania
    (Submitted on 10 Aug 2018)
    We explore the fate of the curvature singularity of Schwarzschild (deSitter) black holes in asymptotically safe quantum gravity. Specifically, we upgrade the classical spacetime by including the running of the Newton coupling and cosmological constant. In this setting, the antiscreening character of the gravitational interaction can remove the singularity, yet a nonzero value of the cosmological constant in the ultraviolet appears to reintroduce it. We find hints that a finite value of the cosmological constant in the infrared is compatible with singularity resolution provided that the cosmological constant is driven to zero fast enough in the ultraviolet. We compare the corresponding bounds on the critical exponents to the literature.
    https://arxiv.org/abs/1808.05842
    On the possibility of laboratory evidence for quantum superposition of geometries
    Marios Christodoulou, Carlo Rovelli
    (Submitted on 17 Aug 2018)
    We analyze the recent proposal of measuring a quantum gravity phenomenon in the lab by entangling two particles gravitationally. We give a generally covariant description of this phenomenon, where the relevant effect turns out to be a quantum superposition of proper times. We point out that measurement of this effect would count as evidence for quantum superposition of spacetime geometries. This interpretation addresses objections appeared in the literature. We observe that the effect sheds light on the Planck mass, and argue that it is very plausibly a real effect.
    https://arxiv.org/abs/1808.06974
    Detailed background dynamics and trans-planckian effects in loop quantum cosmology
    Killian Martineau
    (Submitted on 21 Aug 2018)
    Cosmology appears as the most promising way to test and constrain quantum gravity theories. Loop quantum gravity is among the most advanced attempts to perform a non-perturbative quantization of general relativity. Its cosmological counterpart, loop quantum cosmology, has clear predictions both for the cosmological background and for the perturbations. In particular, the initial Big Bang singularity is replaced by a bounce due to quantum geometry effects. In this proceeding I will focus on new results obtained in loop quantum cosmology: i) the prediction of the duration of inflation as a function of all the unknown parameters of the model and ii) new primordial power spectra obtained with modified dispersion relations accounting for trans-planckian effects.
    https://arxiv.org/abs/1808.08857
    A status report on the phenomenology of black holes in loop quantum gravity: Evaporation, tunneling to white holes, dark matter and gravitational waves
    Aurélien Barrau, Killian Martineau, Flora Moulin
    (Submitted on 27 Aug 2018)
    The understanding of black holes in loop quantum gravity is becoming increasingly accurate. This review focuses on the possible experimental or observational consequences of the underlying spinfoam structure of space-time. It adresses both the aspects associated with the Hawking evaporation and the ones due to the possible existence of a bounce. Finally, consequences for dark matter and gravitational waves are considered.
    https://arxiv.org/abs/1808.09216
    Abelian 2+1D Loop Quantum Gravity Coupled to a Scalar Field
    Christoph Charles
    (Submitted on 28 Aug 2018)
    In order to study 3d loop quantum gravity coupled to matter, we consider a simplified model of abelian quantum gravity, the so-called U(1)^3 model. Abelian gravity coupled to a scalar field shares a lot of commonalities with parameterized field theories. We use this to develop an exact quantization of the model. This is used to discuss solutions to various problems that plague even the 4d theory, namely the definition of an inverse metric and the role of the choice of representation for the holonomy-flux algebra.
    https://arxiv.org/abs/1808.09765
    Phase transitions in group field theory: The Landau perspective
    Andreas G. A. Pithis, Johannes Thürigen
    (Submitted on 29 Aug 2018)
    In various approaches to quantum gravity continuum spacetime is expected to emerge from discrete geometries through a phase transition. In group field theory, various indications for such a transition have recently been found but a complete understanding of such a phenomenon remains an open issue. In this work, we investigate the critical behavior of different group field theory models in the Gaussian approximation. Applying the Ginzburg criterion to quantify field fluctuations, we find that this approximation breaks down in the case of three-dimensional Euclidean quantum gravity as described by the dynamical Boulatov model on the compact group SU(2). This result is independent of the peculiar gauge symmetry and specific form of nonlocality of the model. On the contrary, we find that the Gaussian approximation is valid for a rank-1 GFT on the noncompact sector of fields on SL(2,R) related to Lorentzian models. Though a nonperturbative analysis is needed to settle the question of phase transitions for compact groups, the results may also indicate the necessity to consider group field theory on noncompact domains for phase transitions to occur.
    https://arxiv.org/abs/1808.09971
    Volume of 4-polytopes from bivectors
    Benjamin Bahr
    In this article we prove a formula for the volume of 4-dimensional polytopes, in terms of their face bivectors, and the crossings within their boundary graph. This proves that the volume is an invariant of bivector-coloured graphs in ##S^3##.
    https://arxiv.org/abs/1808.10225
    Phenomenology of Quantum Reduced Loop Gravity in the isotropic cosmological sector
    Emanuele Alesci, Aurélien Barrau, Gioele Botta, Killian Martineau, Gabriele Stagno
    (Submitted on 30 Aug 2018)
    Quantum reduced loop gravity is designed to consistently study symmetry reduced systems within the loop quantum gravity framework. In particular, it bridges the gap between the effective cosmological models of loop quantum cosmology and the full theory, addressing the dynamics before the minisuperspace reduction. This mostly preserves the graph structure and SU(2) quantum numbers. In this article, we study the phenomenological consequences of the isotropic sector of the theory, the so-called emergent bouncing universe model. In particular, the parameter space is scanned and we show that the number of inflationary e-folds is almost always higher than the observational lower-bound. We also compute the primordial tensor power spectrum and study its sensitivity upon the fundamental parameters used in the model.
    https://arxiv.org/abs/1808.10469
    Group field theory and its cosmology in a matter reference frame
    Steffen Gielen
    (Submitted on 30 Aug 2018 (v1), last revised 25 Sep 2018 (this version, v2))
    While the equations of general relativity take the same form in any coordinate system, choosing a suitable set of coordinates is essential in any practical application. This poses a challenge in background-independent quantum gravity, where coordinates are not a priori available and need to be reconstructed from physical degrees of freedom. We review the general idea of coupling free scalar fields to gravity and using these scalars as a "matter reference frame." The resulting coordinate system is harmonic, i.e. it satisfies harmonic (de Donder) gauge. We then show how to introduce such matter reference frames in the group field theory approach to quantum gravity, where spacetime is emergent from a "condensate" of fundamental quantum degrees of freedom of geometry, and how to use matter coordinates to extract physics. We review recent results in homogeneous and inhomogeneous cosmology, and give a new application to the case of spherical symmetry. We find tentative evidence that spherically symmetric group field theory condensates defined in this setting can reproduce the near-horizon geometry of a Schwarzschild black hole.
    https://arxiv.org/abs/1809.00313
    Cosmological perturbations with inverse-volume corrections in loop quantum cosmology
    Yu Han
    (Submitted on 2 Sep 2018)
    Although the cosmological perturbations with inverse-volume corrections from loop quantum cosmology have been studied using the anomaly free algebra approach in many literatures, there still remains an important issue that some counter terms in the perturbed constraints cannot be uniquely fixed on the spatially flat FRW background, which causes ambiguities in the perturbation equations. In this paper we show that this problem can be overcome by extending the anomaly free algebra to spatially closed FRW background. We find that a consistent deformed algebra can be obtained in the spatially closed case, and each counter term can be uniquely fixed in terms of the inverse-volume correction functions, then by taking the large ##r_o## limit, we recover the anomaly free Hamiltonian on the spatially flat background, using this Hamiltonian we obtain the gauge invariant cosmological perturbations for scalar, vector and tensor modes in the spatially flat case. Moreover, we also derive the quantum corrected Mukhanov equations, from which the scalar and tensor spectral indices with inverse-volume corrections are given. The results obtained in this paper show some differences with those in previous literatures.
    https://arxiv.org/abs/1809.00556
    A change of perspective: switching quantum reference frames via a perspective-neutral framework
    Augustin Vanrietvelde, Philipp A Hoehn, Flaminia Giacomini, Esteban Castro-Ruiz
    (Submitted on 3 Sep 2018)
    Treating reference frames fundamentally as quantum systems is inevitable in quantum gravity and also in quantum foundations once considering laboratories as physical systems. Both fields thereby face the question of how to describe physics relative to quantum reference systems and how the descriptions relative to different such choices are related. Here, we exploit a fruitful interplay of ideas from both fields to begin developing a unifying approach to transformations among quantum reference systems that ultimately aims at encompassing both quantum and gravitational physics. In particular, using a gravity inspired symmetry principle, which enforces physical observables to be relational and leads to an inherent redundancy in the description, we develop a perspective-neutral structure, which contains all frame perspectives at once and via which they are changed. We show that taking the perspective of a specific frame amounts to a fixing of the symmetry related redundancies in both the classical and quantum theory and that changing perspective corresponds to a symmetry transformation. We implement this using the language of constrained systems, which naturally encodes symmetries. Within a simple one-dimensional model, we recover some of the quantum frame transformations of arXiv:1712.07207, embedding them in a perspective-neutral framework. Using them, we illustrate how entanglement and classicality of an observed system depend on the quantum frame perspective. Our operational language also inspires a new interpretation of Dirac and reduced quantized theories as perspective-neutral and perspectival quantum theories, respectively. In this light, we suggest a new take on the relation between a `quantum general covariance' and the diffeomorphism symmetry in quantum gravity.
    https://arxiv.org/abs/1809.00913
    Observation of thermal Hawking radiation at the Hawking temperature in an analogue black hole
    Juan Ramón Muñoz de Nova, Katrine Golubkov, Victor I. Kolobov, Jeff Steinhauer
    (Submitted on 4 Sep 2018 (v1), last revised 14 Sep 2018 (this version, v2))
    We measure the correlation spectrum of the Hawking radiation emitted by an analogue black hole and find it to be thermal at the Hawking temperature implied by the analogue surface gravity. The Hawking radiation is in the regime of linear dispersion, in analogy with a real black hole. Furthermore, the radiation inside of the black hole is seen to be composed of negative-energy partners only. This work confirms the prediction of Hawking's theory regarding the value of the Hawking temperature, as well as the thermality of the spectrum. The thermality of Hawking radiation is the root of the information paradox. The correlations between the Hawking and partner particles imply that the analogue black hole has no analogue firewall.
    https://arxiv.org/abs/1809.01747
    Glimpses of Space-Time Beyond the Singularities Using Supercomputers
    Parampreet Singh
    (Submitted on 5 Sep 2018)
    A fundamental problem of Einstein's theory of classical general relativity is the existence of singularities such as the big bang. All known laws of physics end at these boundaries of classical space-time. Thanks to recent developments in quantum gravity, supercomputers are now playing an important role in understanding the resolution of big bang and black hole singularities. Using supercomputers, explorations of the very genesis of space and time from quantum geometry are revealing a novel picture of what lies beyond classical singularities and the new physics of the birth of our universe.
    https://arxiv.org/abs/1809.01908
    A Local Resolution of the Problem of Time
    Edward Anderson
    (Submitted on 6 Sep 2018 (v1), last revised 24 Sep 2018 (this version, v2))
    We here announce and outline a solution of this major and longstanding foundational problem, dealing with all seven of its heavily-interrelated local facets.
  13. Oct 10, 2018 #2553
    julian
    https://arxiv.org/abs/1809.03172
    Non-adiabatic Evolution of Primordial Perturbations and non-Gaussinity in Hybrid Approach of Loop Quantum Cosmology
    Qiang Wu, Tao Zhu, Anzhong Wang
    (Submitted on 10 Sep 2018)
    While loop quantum cosmology (LQC) predicts a robust quantum bounce of the background evolution of a Friedmann-Robertson-Walker (FRW) spacetime prior to the standard slow-roll inflation, whereby the big bang singularity is resolved, there are several different quantization procedures to cosmological perturbations, for instance, {\em the deformed algebra, dressed metric, and hybrid quantizations}. This paper devotes to study the quantum bounce effects of primordial perturbations in the hybrid approach. The main discrepancy of this approach is the effective positive mass at the quantum bounce for the evolution of the background that is dominated by the kinetic energy of the inflaton field at the bounce, while this mass is always nonpositive in the dressed metric approach. It is this positivity of the effective mass that violates the adiabatic evolution of primordial perturbations at the initial moments of the quantum bounce. With the assumption that the evolution of the background is dominated by the kinetic energy of the inflaton at the bounce, we find that the effective potentials for both scalar and tensor perturbations can be well approximately described by a P\"{o}schl-Teller (PT) potential, which allows us to find analytical solutions of perturbations, and from these analytical expressions we are able to study the non-adiabatic evolution of primordial perturbations in details. In particular, we derive their quantum bounce effects and investigate their observational constraints. In addition, the impacts of quantum bounce effects on the non-Gaussinity and their implication on the explanations of observed power asymmetry in CMB have also been explored.
    https://arxiv.org/abs/1809.03884
    Perturbations in Hybrid Loop Quantum Cosmology: Continuum Limit in Fourier Space
    Beatriz Elizaga Navascués, Guillermo A. Mena Marugán
    (Submitted on 11 Sep 2018)
    We analyze the passage to a continuum limit of the mode spectrum of primordial perturbations around flat cosmological spacetimes in hybrid Loop Quantum Cosmology, showing that this limit can be reached even if one starts by considering a finite fiducial cell as spatial slice. We focus our attention on regimes in which the background cosmology follows the effective dynamics of Loop Quantum Cosmology, although we comment on extensions of our arguments beyond this regime, as well as to some formalisms other than the hybrid approach. Whereas the perturbed system can be described in an invariant way under changes of the fiducial volume using the standard variables of the improved prescription for Loop Quantum Cosmology, we show that the desired continuum limit can be established by means of scaling transformations of the physical volume when this volume grows unboundedly. These transformations lead to a model with a continuum of modes and independent of any scale of reference for the physical volume. For the sake of comparison, we also consider an alternative road to the continuum in Fourier space that has been employed in geometrodynamics and is based on the use of scaling transformations of the fiducial volume, together with variables that are independent of them.
    https://arxiv.org/abs/1809.04465
    Anomaly freedom in perturbative models of Euclidean loop quantum gravity
    Jian-Pin Wu, Martin Bojowald, Yongge Ma
    (Submitted on 12 Sep 2018)
    Euclidean gravity provides an interesting test system for an analysis of cosmological perturbations in an effective Hamiltonian constraint with holonomy modifications from loop quantum gravity. This paper presents a discussion of scalar modes, with a specific form of the holonomy modification function derived from a general expansion in a connection formulation. Compared with some previous models, the constraint brackets are deformed in a different and more restricted way. A general comparison of anomaly-free brackets in various effective and operator versions shows overall consistency between different approaches.
    https://arxiv.org/abs/1809.05093
    Switching quantum reference frames in the N-body problem and the absence of global relational perspectives
    (Submitted on 13 Sep 2018)
    Given the importance of quantum reference systems to both quantum and gravitational physics, it is pertinent to develop a systematic method for switching between the descriptions of physics relative to different choices of quantum reference systems, which is valid in both fields. Here, we continue with such a unifying approach, begun in arxiv:1809.00556, whose key ingredients is a gravity-inspired symmetry principle, which enforces physics to be relational and leads, thanks to gauge related redundancies, to a perspective-neutral structure which contains all frame choices at once and via which frame perspectives can be consistently switched. Formulated in the language of constrained systems, the perspective-neutral structure turns out to be the constraint surface classically and the gauge invariant Hilbert space in the Dirac quantized theory. By contrast, a perspective relative to a specific frame corresponds to a gauge choice and the associated reduced phase and Hilbert space. Quantum reference frame switches thereby amount to a symmetry transformation. In the quantum theory, they require a transformation that takes one from the Dirac to a reduced quantum theory and we show that it amounts to a trivialization of the constraints and a subsequent projection onto the classical gauge fixing conditions. We illustrate this method in the relational N-body problem with rotational and translational symmetry. This model is particularly interesting because it features the Gribov problem so that globally valid gauge fixing conditions are impossible which, in turn, implies also that globally valid relational frame perspectives are absent in both the classical and quantum theory. These challenges notwithstanding, we exhibit how one can systematically construct the quantum reference frame transformations for the three-body problem.
    https://arxiv.org/abs/1809.08083
    Time in quantum theory, the Wheeler-DeWitt equation and the Born-Oppenheimer approximation
    Alexander Yu. Kamenshchik, Alessandro Tronconi, Tereza Vardanyan, Giovanni Venturi
    (Submitted on 21 Sep 2018)
    We compare two different approaches to the treatment of the Wheeler-DeWitt equation and the introduction of time in quantum cosmology. One approach is based on the gauge-fixing procedure in theories with first-class constraints, while the other uses the Born-Oppenheimer method. We apply both to a very simple cosmological model and observe that they give similar predictions. We also discuss the problem of time in non-relativistic quantum mechanics and some questions concerning the correspondence between classical and quantum theories.
    https://arxiv.org/abs/1809.08277
    Hiding the cosmological constant
    S. Carlip
    Perhaps the expectations of quantum field theory are right, and the universe really does have a very large cosmological constant. I show that if one does not assume homogeneity or an arrow of time at the Planck scale, a large class of initial data for general relativity exhibits expansions and shears that are enormous at small scales, but quickly average to zero macroscopically. For an infinite subset of this data, the averaged spatial curvature is also small, and has a vanishing time derivative. Subsequent evolution is more complex, but I argue that quantum fluctuations should preserve these properties. The resulting picture is a version of Wheeler's "spacetime foam," in which the cosmological constant produces high curvature at the Planck scale but is hidden at observable scales.
    https://arxiv.org/abs/1809.09659
    A quantum gravity extension to the Mixmaster dynamics
    Edward Wilson-Ewing
    (Submitted on 25 Sep 2018)
    In the loop quantum cosmology effective dynamics for the vacuum Bianchi type I and type IX space-times, a non-singular bounce replaces the classical singularity. The bounce can be approximated as an instantaneous transition between two classical vacuum Bianchi I solutions, with simple transition rules relating the solutions before and after the bounce: the evolution of the mean logarithmic scale factor is reversed, while the shape parameters are unaffected. As a result, the loop quantum cosmology effective dynamics for the vacuum Bianchi IX space-time can be approximated by a sequence of classical vacuum Bianchi I solutions, following the usual Mixmaster transition maps in the classical regime, and undergoing a bounce with this new transition rule in the Planck regime.
    https://arxiv.org/abs/1809.09874
    The Vacuum State of Primordial Fluctuations in Hybrid Loop Quantum Cosmology
    Beatriz Elizaga Navascués, Daniel Martín de Blas, Guillermo A. Mena Marugán
    (Submitted on 26 Sep 2018)
    We investigate the role played by the vacuum of the primordial fluctuations in hybrid Loop Quantum Cosmology. We consider scenarios where the inflaton potential is a mass term and the unperturbed quantum geometry is governed by the effective dynamics of Loop Quantum Cosmology. In this situation, the phenomenologically interesting solutions have a preinflationary regime where the kinetic energy of the inflaton dominates over the potential. For these kind of solutions, we show that the primordial power spectra depend strongly on the choice of vacuum. We study in detail the case of adiabatic states of low order and the non-oscillating vacuum introduced by Mart\'in de Blas and Olmedo, all imposed at the bounce. The adiabatic spectra are typically suppressed at large scales, and display rapid oscillations with an increase of power at intermediate scales. In the non-oscillating vacuum, there is power suppression for large scales, but the rapid oscillations are absent. We argue that the oscillations are due to the imposition of initial adiabatic conditions in the region of kinetic dominance, and that they would also be present in General Relativity. Finally, we discuss the sensitivity of our results to changes of the initial time and other data of the model.
    https://arxiv.org/abs/1810.00949
    On the Empirical Consequences of the AdS/CFT Duality
    Radin Dardashti, Richard Dawid, Sean Gryb, Karim Thébault
    (Submitted on 27 Sep 2018)
    We provide an analysis of the empirical consequences of the AdS/CFT duality with reference to the application of the duality in a fundamental theory, effective theory and instrumental context. Analysis of the first two contexts is intended to serve as a guide to the potential empirical and ontological status of gauge/gravity dualities as descriptions of actual physics at the Planck scale. The third context is directly connected to the use of AdS/CFT to describe real quark-gluon plasmas. In the latter context, we find that neither of the two duals are confirmed by the empirical data.
    https://arxiv.org/abs/1810.00238
    The BKL scenario, infrared renormalization, and quantum cosmology
    Martin Bojowald
    (Submitted on 29 Sep 2018)
    A discussion of inhomogeneity is indispensable to understand quantum cosmology, even if one uses the dynamics of homogeneous geometries as a first approximation. While a full quantization of inhomogeneous gravity is not available, a broad framework of effective field theory provides important ingredients for quantum cosmology. Such a setting also allows one to take into account lessons from the Belinski-Khalatnikov-Lifshitz (BKL) scenario. Based on several new ingredients, this article presents conditions on various parameters and mathematical constructions that appear in minisuperspace models. Examples from different approaches demonstrate their restrictive nature.
    https://arxiv.org/abs/1810.01259
    A relational Hamiltonian for group field theory
    Edward Wilson-Ewing
    (Submitted on 2 Oct 2018)
    Using a massless scalar field as a clock variable, the Legendre transform of the group field theory Lagrangian gives a relational Hamiltonian. In the classical theory, it is natural to define 'equal relational time' Poisson brackets, where 'equal time' corresponds to equal values of the scalar field clock. The quantum theory can then be defined by imposing 'equal relational time' commutation relations for the fundamental operators of the theory, with the states being elements of a Fock space with their evolution determined by the relational Hamiltonian operator. A particularly interesting family of states are condensates, as they are expected to correspond to the cosmological sector of group field theory. For the relational Hamiltonian considered in this paper, the coarse-grained dynamics of a simple type of condensate states agree exactly with the Friedmann equations in the classical limit, and also include quantum gravity corrections that ensure the big-bang singularity is replaced by a bounce.
    https://arxiv.org/abs/1810.01671
    Cosmological Implications of the Bekenstein Bound
    Tom Banks, Willy Fischler
    (Submitted on 3 Oct 2018 (v1), last revised 9 Oct 2018 (this version, v2))
    A brief review of "Holographic Space-Time" in the light of the seminal contributions of Jacob Bekenstein.
    https://arxiv.org/abs/1810.01880
    Black hole entropy and the Bekenstein bound
    Raphael Bousso
    (Submitted on 3 Oct 2018)
    I share some memories and offer a personal perspective on Jacob Bekenstein's legacy, focussing on black hole entropy and the Bekenstein bound. I summarize a number of fascinating recent developments that grew out of Bekenstein's pioneering contributions, from the Ryu-Takayanagi proposal to the Quantum Null Energy Condition.
    https://arxiv.org/abs/1810.02828
    How perturbative is quantum gravity?
    Astrid Eichhorn, Stefan Lippoldt, Jan M. Pawlowski, Manuel Reichert, Marc Schiffer
    (Submitted on 5 Oct 2018)
    We explore asymptotic safety of gravity-matter systems, discovering indications for a near-perturbative nature of these systems in the ultraviolet. Our results are based on the dynamical emergence of effective universality at the asymptotically safe fixed point. Our findings support the conjecture that an asymptotically safe completion of the Standard Model with gravity could be realized in a near-perturbative setting.
    https://arxiv.org/abs/1810.04153
    How to switch between relational quantum clocks
    Philipp A Hoehn, Augustin Vanrietvelde
    (Submitted on 9 Oct 2018)
    Every clock is a physical system and thereby ultimately quantum. A naturally arising question is thus how to describe time evolution relative to quantum clocks and, specifically, how the dynamics relative to different quantum clocks are related. This is a particularly pressing issue in view of the multiple choice facet of the problem of time in quantum gravity, which posits that there is no distinguished choice of internal clock in generic general relativistic systems and that different choices lead to inequivalent quantum theories. Exploiting a recent unifying approach to switching quantum reference systems (arXiv:1809.00556, arXiv:1809:05093), we exhibit a systematic method for switching between different clock choices in the quantum theory. We illustrate it by means of the parametrized particle, which, like gravity, features a Hamiltonian constraint. We explicitly switch between the quantum evolution relative to the non-relativistic time variable and that relative to the particle's position, which requires carefully regularizing the zero-modes in the so-called time-of-arrival observable. While this toy model is simple, our approach is general and, in particular, directly amenable to quantum cosmology. It proceeds by systematically linking the reduced quantum theories relative to different clock choices via the clock-choice-neutral Dirac quantized theory, in analogy to coordinate changes on a manifold. This method overcomes the multiple choice problem here, showing that it is actually a multiple choice feature of the complete relational quantum theory, taken as the conjunction of Dirac and reduced quantized theories. Precisely this conjunction permits to consistently switch between different temporal reference systems, which is a prerequisite for a quantum notion of general covariance.
  14. Jan 13, 2019 #2554
    https://arxiv.org/abs/1802.04264
    White Holes as Remnants: A Surprising Scenario for the End of a Black Hole
    Eugenio Bianchi, Marios Christodoulou, Fabio D'Ambrosio, Hal M. Haggard, Carlo Rovelli
    (Submitted on 12 Feb 2018 (v1), last revised 17 Mar 2018 (this version, v2))
    Quantum tunneling of a black hole into a white hole provides a model for the full life cycle of a black hole. The white hole acts as a long-lived remnant, solving the black-hole information paradox. The remnant solution of the paradox has long been viewed with suspicion, mostly because remnants seemed to be such exotic objects. We point out that (i) established physics includes objects with precisely the required properties for remnants: white holes with small masses but large finite interiors; (ii) non-perturbative quantum-gravity indicates that a black hole tunnels precisely into such a white hole, at the end of its evaporation. We address the objections to the existence of white-hole remnants, discuss their stability, and show how the notions of entropy relevant in this context allow them to evade several no-go arguments. A black hole's formation, evaporation, tunneling to a white hole, and final slow decay, form a unitary process that does not violate any known physics.
    https://arxiv.org/abs/1811.00532
    Statistical equilibrium of tetrahedra from maximum entropy principle
    Goffredo Chirco, Isha Kotecha, Daniele Oriti
    (Submitted on 1 Nov 2018)
    Discrete formulations of (quantum) gravity in four spacetime dimensions build space out of tetrahedra. We investigate a statistical mechanical system of tetrahedra from a many-body point of view based on non-local, combinatorial gluing constraints that are modelled as multi-particle interactions. We focus on Gibbs equilibrium states, constructed using Jaynes' principle of constrained maximisation of entropy, which has been shown recently to play an important role in characterising equilibrium in background independent systems. We apply this principle first to classical systems of many tetrahedra using different examples of geometrically motivated constraints. Then for a system of quantum tetrahedra, we show that the quantum statistical partition function of a Gibbs state with respect to some constraint operator can be reinterpreted as a partition function for a quantum field theory of tetrahedra, taking the form of a group field theory.
    https://arxiv.org/abs/1811.03667
    Light Cone Black Holes
    Tommaso De Lorenzo, Alejandro Perez
    (Submitted on 8 Nov 2018)
    When probed with conformally invariant matter fields, light cones in Minkowski spacetime satisfy thermodynamical relations which are the analog of those satisfied by stationary black holes coupled to standard matter fields. These properties stem from the fact that light cones are conformal Killing horizons stationary with respect to observers following the radial conformal Killing fields in flat spacetime. The four laws of light cone thermodynamics relate notions such as (conformal) temperature, (conformal) surface gravity, (conformal) energy and a conformally invariant notion related to area change. These quantities do not admit a direct physical interpretation in flat spacetime. However, they become the usual thermodynamical quantities when Minkowski is mapped, via a Weyl transformation, to a target spacetime where the conformal Killing field becomes a proper Killing field. In this paper we study the properties of such spacetimes. The simplest realisation turns out to be the Bertotti-Robinson solution, which is known to encode the near horizon geometry of near extremal and extremal charged black holes. The analogy between light cones in flat space and black hole horizons is therefore strengthened. The construction works in arbitrary dimensions; in two dimensions one recovers the Jackiv-Teitelboim black hole of dilaton gravity. Other interesting realisations are also presented.
    https://arxiv.org/abs/1811.08007
    Quantum insights on Primordial Black Holes as Dark Matter
    Francesca Vidotto
    (Submitted on 19 Nov 2018)
    A recent understanding on how quantum effects may affect black-hole evolution opens new scenarios for dark matter, in connection with the presence of black holes in the very early universe. Quantum fluctuations of the geometry allow for black holes to decay into white holes via a tunnelling. This process yields to an explosion and possibly to a long remnant phase, that cures the information paradox. Primordial black holes undergoing this evolution constitute a peculiar kind of decaying dark matter, whose lifetime depends on their mass M and can be as short as M2. As smaller black holes explode earlier, the resulting signal have a peculiar fluence-distance relation. I discuss the different emission channels that can be expected from the explosion (sub-millimetre, radio, TeV) and their detection challenges. In particular, one of these channels produces an observed wavelength that scales with the redshift following a unique flattened wavelength-distance function, leaving a signature also in the resulting diffuse emission. I conclude presenting the first insights on the cosmological constraints, concerning both the explosive phase and the subsequent remnant phase.
    https://arxiv.org/abs/1811.11744
    Holographic description of boundary gravitons in (3+1) dimensions
    Seth K. Asante, Bianca Dittrich, Hal M. Haggard
    (Submitted on 27 Nov 2018)
    Gravity is uniquely situated in between classical topological field theories and standard local field theories. This can be seen in the the quasi-local nature of gravitational observables, but is nowhere more apparent than in gravity's holographic formulation. Holography holds promise for simplifying computations in quantum gravity. While holographic descriptions of three-dimensional spacetimes and of spacetimes with a negative cosmological constant are well-developed, a complete boundary description of zero curvature, four-dimensional spacetime is not currently available. Building on previous work in three-dimensions, we provide a new route to four-dimensional holography and its boundary gravitons. Using Regge calculus linearized around a flat Euclidean background with the topology of a solid hyper-torus, we obtain the effective action for a dual boundary theory which describes the dynamics of the boundary gravitons. Remarkably, in the continuum limit and at large radii this boundary theory is local and closely analogous to the corresponding result in three-dimensions. The boundary effective action has a degenerate kinetic term that leads to singularities in the one-loop partition function that are independent of the discretization. These results establish a rich boundary dynamics for four-dimensional flat holography.
    https://arxiv.org/abs/1812.01542
    On the possibility of experimental detection of the discreteness of time
    (Submitted on 4 Dec 2018 (v1), last revised 8 Dec 2018 (this version, v2))
    The Bose-Marletto-Vedral experiment tests a non-relativistic quantum effect due to a gravitational interaction. It has received attention because it may soon be within observational reach in the lab. We observe here that: (i) in relativistic language the experiment tests an interference effect between proper-time intervals; (ii) the relevant difference of proper times is of the order of the Planck time if the masses of the particles in the experiment are of the order of the Planck mass (micrograms); (iii) the experiment might open a window on the structure of time at the Planck scale: if time differences are discrete at this scale ---as quantum gravity research may suggest--- the Planckian discreteness of time could show up as quantum levels of a measurable entanglement entropy.
    https://arxiv.org/abs/1812.05127
    Quantum gravity and black hole spin in gravitational wave observations: a test of the Bekenstein-Hawking entropy
    Eugenio Bianchi, Anuradha Gupta, Hal M. Haggard, B. S. Sathyaprakash
    (Submitted on 12 Dec 2018)
    Black hole entropy is a robust prediction of quantum gravity with no observational test to date. We use the Bekenstein-Hawking entropy formula to determine the probability distribution of the spin of black holes at equilibrium in the microcanonical ensemble. We argue that this ensemble is relevant for black holes formed in the early universe and predicts the existence of a population of black holes with zero spin. Observations of such a population at LIGO, Virgo, and future gravitational wave observatories would provide the first experimental test of the statistical nature of black hole entropy.
    https://arxiv.org/abs/1812.06193
    Tullio Regge's legacy: Regge calculus and discrete gravity
    John W. Barrett, Daniele Oriti, Ruth M. Williams
    (Submitted on 14 Dec 2018)
    The review paper "Discrete Structures in Physics", written in 2000, describes how Regge's discretization of Einstein's theory has been applied in classical relativity and quantum gravity. Here, developments since 2000 are reviewed briefly, with particular emphasis on progress in quantum gravity through spin foam models and group field theories.
Have something to add?
