narayanjr
- 3
For my Final Project for my AP Physics class is a rail gun. But I am having trouble getting it to fire anything or even move it. I have no trouble charging the bank but when it is discharged into the rails the projectile doesn't move.
I am using 11, 330v disposable camera capacitors in parallel. I am using a thick piece of graphite as my projectile, but have also tested aluminum foil and brass. The best I have gotten was placing aluminum foil across the top of the rails instead of between them, when I discharged the bank into the rails the foil pops into the air but that's it.
The rails are the width of pencil lead apart about 5 inches long 1 inch wide, Bolted to a block of between 2 sheets of plexiglass and bolted to a block of wood.
I have tested with 11 capacitors and with 4 caps since most of the ones i have seen online only used 3-5 caps. Still only got a spark. The current seems to jump straight through the graphite and sparks but never moves. I've tested with the caps charged from 150 up to 310 but never get any movement.
I am not sure what I am doing wrong, I am sure I may have left out some important detail but can't think of anything else right now, any questions lmk. Does anyone have any idea what could possibly be wrong with it? Thanks for any help.
