Lorentz invariance and GR
  • #51
A. Neumaier
Insights Author
7,613
3,443
How is Lorentz invariance handled in GR? [...] does GR imply small Lorentz violations in practice?
No. Lorentz invariance is independent of general covariance = diffeomorphism invariance. The latter only replaces the translation invariance of flat field theories.
Lorentz invariance is seen explicitly in general relativity coupled to a spinor field, where gravity is represented by a frame field and local Lorentz invariance is imposed on the frames.
  • #52
PAllen
1,547
This is way above my math level (conventional treatments of GR). Physically, the way I see Lorentz invariance being violated in GR is:
1) There is no coordinate system where the Minkowski metric can be used to compute path invariants.
2) If two inertial observers set up overlapping Fermi-normal coordinates, the Lorentz transform will not work to translate observations from one to the other.
  • #53
3,507
People have gotten special relativity as a low energy limit, even Maxwell's equations. Gravity, not yet. There are non-relativistic versions of AdS/CFT, but they are probably not UV complete.
2+1D: http://www.als.lbl.gov/als/science/sci_archive/144dirac_fermions.html
3+1D: http://arxiv.org/abs/hep-th/0507118
Long list of references: http://arxiv.org/abs/1102.0789
Non-relativistic AdS/CFT: http://arxiv.org/abs/0804.4053
Thanks for the refs, looks like interesting stuff.
  • #54
A. Neumaier
Insights Author
7,613
3,443
Local Lorentz invariance is a property of what one finds in the (flat!) tangent hyperplane at each point, which reflects faithfully a neighborhood of that point in terms of Riemann normal coordinates. You can see it if you consider gravity formulated in terms of local orthonormal frames.
  • #55
PAllen
1,547
Then I don't think we're disagreeing. If you consider any region of finite size in GR, you will not find exact Lorentz invariance.
  • #56
3,507
Exactly. At least we seem to agree on that.
  • #57
3,507
So if in GR, fermionic particles can't define an SR inertial frame due its having a finite size in the 4-manifold, we must conclude only the vacuum and massless bosons can be real inertial frames as defined in SR, and wouldn't be exactly exchangeable with the fermion frames.
In other words all fermionic matter undergoes some degree of acceleration-is affected by curvature. Is this logic correct?
Related Threads on Lorentz invariance and GR
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
