Lorentz Transformation
Two events occur at the same place in an inertial reference fram S, but are separated in time by 3 seconds. In a different frame S', they are separated in time by 4 seconds.
(a) What is the distance between the two events as measured in S'?
(b) What is the speed of S relative to S'?
I'm presuming:
t' = gamma*(t-ux/c^2)
I have the answer, and a hint saying to use the interval S^2, but I have no idea what that means, and where I start. When I look and the relevant Lorentz equations, they involve velocity, and I do not have a velocity here.
Could you please point me in the right direction?
Thank you in advance.
Answers and Replies
G01
The hint is implying that you use the invariant space-time interval to solve this problem. The following quantity is called the space time interval:
[tex](\Delta s)^2= (\Delta x)^2 + (\Delta y)^2 + (\Delta z^2) - (c\Delta t)^2[/tex]
This quantity is a Lorentz scalar and is thus invariant over Lorentz transformations (it is the same in all inertial frames). So, in one dimension this means:
[tex](\Delta x)^2- (c\Delta t)^2=(\Delta x')^2- (c\Delta t')^2[/tex]
Can you use this the solve the problem?
Do I find [tex](\Delta t)[/tex] by doing SQRT[(4^2)-(3^2)] = ROOT 7
Then at they are both at the same coordinates in the inertial reference frame, we can ignore x , y and z. Therefor S equals the root of (c^2)*(ROOT 7) = 7.9x10^8m
Is this correct?
G01
Is this correct?
You should only have one factor of c in your final line, since you take the square root of c^2 when solving for the answer.
Related Threads on Lorentz Transformation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
