Calculating Distance and Time Using Lorentz Transformation
In summary, according to the astronauts, distance from Earth to the galaxy is d' and time from Earth to the galaxy is t'.
Kunhee
51
A rocket is traveling toward a galaxy with speed v.
a) If NASA says that distance from Earth to the galaxy is d, what is the distance d' from Earth to the galaxy according to the astronauts?
b) The astronauts experience a travel time to the galaxy t' and NASA records the travel time as t. For NASA, d = vt. Show that the astronauts also find that distance = speed x time.
c = 3 x 10^8
Lorentz Factor = (1-(v/c)^2)^(-1/2)
x' = 1/LF ( x - vt)
t' = 1/LF ( t - vx / c^2)
Currently I only learned the equations above. I do not know the x', x, t', or t. Is this an intuitive question?
If you are asking that sort of question, you have a long way to go. What physics have you previously studied?
This is not an intuitive question.
You need to look up "introduction to special relativity" someplace (hint: google) and get back to us.
Since this is homework, you must be doing some sort of course that will have lessons, notes, and a textbook... have you tried those?
You may be able to figure out what is intended by noticing that there are primed and unprimed variables in the question though.
a)
d' = d - vt?
b)
x' = 1/LF (x - vt)
x' = 1/(1-(v/c)^2)^(-1/2) (x - vt)
x' = 1/(1) ( x- vt)
x' = x- vt
same as d' = d - vt
So if these are correct, could you explain to me why the notion of "time travel" is required to make this problem that of special relativity? Or does it simply mean that by making t' equal to t, we are dealing with change of time = 0.
Kunhee said:
a)
d' = d - vt?
b)
x' = 1/LF (x - vt)
x' = 1/(1) ( x- vt)
x' = x- vt
same as d' = d - vt
None of that makes any sense to me. Are you a high school student, learning SR on your own or a university student?
My apologies. I am learning on my own.
What physics do you already know?
I only learned high school physics.
I am using Kleppner and Kolenkow's textbook Intro to Mechanics.
They cover length contraction. Does that seem relevant here?
Yeah this is a length contraction question.
x' = 1/LF (x - vt)
x' = 1/LF (x - v(0)) because change in t = 0
x' = 1/LF x
So here, x' is d' that astronauts measure from Earth to the galaxy
and x is the d that NASA measures from Earth to the galaxy.
Am I correct so far?
x' = 1/LF (x - vt)
x' = 1/LF x
Personally, I would solve this problem using length contraction and time dilation, as the information is given as lengths and time intervals. The problem is stated in those terms and not in terms where you can immediately use the Lorentz Transformation.
If you want to use Lorentz, then you are going to have to restate the problem in terms of position and time coordinates, to which you can apply Lorentz.
Saying something like x' = d' is sloppy. To use Lorentz, you need more precision.
I'm not sure if that makes any sense tto you.
I see, the question is under the category "Lorentz Transformation" so I did not look ahead yet at Length Contraction and Time Dilation. I will look at those sections and try again.
I think K&K is excellent, but I hadn't looked at their section on SR. Just taking a quick look at it I can't find your problem (I have the second edition). Also, it seems a bit brief for learning this on your own. There is a free pdf available here:
http://www.lightandmatter.com/sr/
Another book I would recommend is:
https://www.amazon.com/dp/1891389610/?tag=pfamazon01-20
Both of these are entire texts on SR - rather than just a couple of chapters - and may be more appropraite for learning on your own.
Accessible - but a bit of a crash course:
http://www.physicsguy.com/ftl/html/FTL_intro.html
... while you are working on trying other texts.
Basically we don;t give full physics lessons here, though we can help with lessons and resources and give you a hand over the tricky parts. ie.
Links for learning special relativity:
http://physicsdatabase.com/2013/11/18/10-great-links-for-learning-special-relativity/
... these are college level but you don't need more than Newtonian physics and quadratic equations, basic algebra and the ability to draw graphs. If you can do kinematics using velocity-time diagrams you can learn special relativity. Understanding takes practise.
Likes Kunhee
Thank you Simon!
Likes Simon Bridge
1. What is Lorentz Transformation?
Lorentz transformation is a mathematical tool used in the theory of special relativity to describe the relationship between space and time coordinates of two inertial frames moving at constant velocities relative to each other.
2. Who developed Lorentz Transformation?
Lorentz Transformation was initially developed by Dutch physicist Hendrik Lorentz in the late 19th century. It was later refined and expanded upon by Albert Einstein in his theory of special relativity.
3. What is the purpose of Lorentz Transformation?
The purpose of Lorentz Transformation is to describe how space and time coordinates of an event change when observed from different frames of reference moving at constant velocities relative to each other. It allows for the consistent description of physical phenomena in different inertial frames of reference.
4. How does Lorentz Transformation relate to Einstein's theory of special relativity?
Lorentz Transformation is an essential mathematical tool in Einstein's theory of special relativity. It is used to explain the observed phenomena of length contraction, time dilation, and the relativity of simultaneity.
5. What are some real-life applications of Lorentz Transformation?
Lorentz Transformation is used in many practical applications, such as in GPS technology, particle accelerators, and nuclear reactors. It also plays a crucial role in the understanding of high-speed particles and the behavior of light in different reference frames.
