Low drag gas nose bullet idea
I have an idea that I would like to discuss.
My idea is to emit a low pressure low friction gas out the nose of a small arms bullet. I believe it would lower the drag over the body of the bullet thus increasing velocity and range.
I just need to know if the phyics are right is this possible and would it work? I have just filed for a patent so I hope the phyics are right lol.
What do you guyz think would be a good gas?
Any help would be great thanks for looking at the thread.
Answers and Replies
You haven't described your reasoning, just the idea. Why do you think this would work? I can tell you that if you could somehow heat the air around the bullet you could reduce wave drag, which is substantial on a typical bullet.
Is there a pressurised gas that gives off extreme heat when it is released into a sea level atmosphere?
You still haven't justified your idea.
well i'm not an expert in phyics but i guessing if you release a lower pressure gas over the body of the bullet that means the air is thinner around the bullet thus reducing drag.
Are there two types of gas that when mixed have an extreme reation producing an enormous amount of heat?
SteamKing
Staff Emeritus
12,798
1,670
Regardless of the properties of this gas, where is it to be stored? Bullets, the actual projectile part, tend to be pretty small objects.
Bobbywhy
51
Since you have filed for a patent then the the invention and drawings are open to the public. Why not just post all the information (description, drawings, and claims) here so members and visitors can see for themselves exactly what you proposed in the patent application? Then everyone would be far better equipped to offer the opinions and judgements you have asked for. Thank you.
Cheers,
Bobbywhy
(edit) What's a "low friction gas"? Can you give some example of one?
The only thing I can think that the OP might be describing is hydrogen or helium, which is used in *light* *gas* guns, hence the name. But I do not think it is low friction so much as it has a much higher speed of sound than air.
Khashishi
493
How do you lower the pressure by adding gas? Adding gas increases the pressure. You can't displace a higher pressure gas with a lower pressure. You probably just end up making the pressure higher still.
I wonder if OP got his idea from supercavitating torpedoes, which work on a similar principle except underwater.
Not sure if the concept can be extended to a projectile in air....
Would a cryogenic gas have lower friction?
Bobbywhy
51
I had the same idea: supercavitating torpedoes!
sophiecentaur
2020 Award
26,548
5,576
Cheers,
Bobbywhy
A squirt of WD40?
Related Threads on Low drag gas nose bullet idea
  • Last Post
  • Last Post
  • Last Post
S
11K
  • Last Post
