LQC is dead
  1. Jul 23, 2013 #1
  3. Jul 23, 2013 #2
    atyy
    !!! tom.stoer check out 24:00 "Rovellitis"! There's a discussion of the anomaly problem.
  4. Jul 24, 2013 #3
    tom.stoer
    Can't play the video :-(
  5. Jul 24, 2013 #4
    tom.stoer
    But can read the PDF - and LQG is seriously ill
  6. Jul 24, 2013 #5
    MTd2
    Who's the girl with the microphone?
  7. Jul 24, 2013 #6
    George Jones
    Staff Emeritus
    I also thought that I couldn't play the video, but, a minute or two after clicking on it, the video appeared.
  8. Jul 24, 2013 #7
    tom.stoer
    the video is flash, and my device at home is an ipad ;-(
    anyway, the slides explain a lot; and the anomaly-issue is known for years but mostly swept under the carpet
  9. Jul 24, 2013 #8
    .....nothing unexpected
  10. Jul 24, 2013 #9
    The impression I got from skimming the video was that LQC, contrary to initial hopes, offers no advantage for escaping the problems of LQG. It seemed like the reasoning was: now we consider LQC just part of LQG, so LQC inherits all of LQG's problems. That is, the anomaly problem wasn't actually avoided, nor has it been solved, so there is nothing of real value left in the sub field.
    Maybe I understood it wrong, but I figured I would try to give a summary for others who don't feel like watching it / can't watch it.
  11. Jul 24, 2013 #10
    bcrowell
    Staff Emeritus
    What does the "anomaly problem" mean?
  12. Jul 24, 2013 #11
    I don't remember exactly, it's been around for a while though. Roughly speaking, canonical LQG attempts to solve QG using two things: new variables, and a non standard approach to applying constraints. The approach to applying constraints has inconsistencies, specifically with the Hamiltonian constraint, and these inconsistencies are collectively referred to as "anomalies".
    Over the years there has only been partial progress towards fixing the problem, or in other words it's still there. I think the standard response in the community is to hide in spin foam models, which typically avoid the the Hamiltonian and therefore don't have/hide the anomaly problem.
    Edit: There was a paper I read that explained the inconsistency at a fairly elementary level (using a simple qm problem to illustrate it). Unfortunately I can't find it, maybe someone else knows what I'm talking about and can link it for you.
    2nd Edit: Tom Stoer linked the paper I was talking about below, as well as explained it in much better detail. The paper is http://arxiv.org/pdf/1009.4475v1.pdf. If you read the section "a simple example", at the very least you will the see the problem illustrated.
  13. Jul 25, 2013 #12
    tom.stoer
    The anomaly problem sais that loop quantization destroys the classical symmetries of the Holst action and that LQG is inconsistent and not viable as a quantum theory of gravity.
    There are several related issues.
    The constraint algebra consists of three constraints Gauß G, diffeomorphism constraint D, Hamiltonian H (relict of timelike diffeomorphism due to spacelike foliation). The constraint algebra is non-Lie, the commutator of H[f] and H[g] with two testfunctions f and g involves structure functions instead of constants; a canonical treatment or solution is not known!!
    The constraints are not solved equivalently but step-wise. H cannot be solved at all (up to know); formal solutions are known but unphysical. When discretizing and using the Weyl algebra quantization the infinitesimal generators D is no longer defined; only finite diffeomorphisms can be defined. That is a first hint that the quantization affects the constraint algebra in an uncontrolled way.
    A quantum version of H is still unknown (not unique) so its constraint algebra is not known (ambiguous), either!! Thiemann's trick plus quantization / discretization results in a H that seems to be unphysical (does not create volume). Some steps in the quantization seem to be ad hoc. That is a second hint that the quantization affects the constraint algebra in an uncontrolled way.
    The derivation of the LQG constraint algebra involves one time-gauge fixing before quantization. That is well-known from QED and QCD (temporal or Weyl gauge). All other gauge fixings are done after quantization. Attempts to check consistency w/o time-gauge using full constraint quantization a la Dirac generates 2nd class constraints for a consistent treatment / solution in LQG is still unknown (2nd class constraints modify the commutator relations). There are hints that unphysical gauge d.o.f. become dynamical gauge artifacts when quantizing incorrectly!! (Alexandrov)
    The way the constraints are implemented are far from natural. Time-gauge is applied by setting the d.o.f. = the field to zero. Other constraints are solved by applying them to states. But as infinitesimal diffeomorphisms fail to be defined after quantization this seems to be problematic (I do not know what is the current status but the way Thiemann implemented the constraints results in a rather strange, ultra-local topology). Sometimes constraints are implemented a la Gupta-Bleuler which is known to be problematic in non-abelian gauge theories. There is nothing explicitly wrong, but many constructions are not unique, ad hoc or seem to be strange.
    There are hints that the operator algebra does not close after quantization. It only closed modulo constraints. The way these additional terms vanish depend in some sense on the above mentioned tricks. So this is a hint that quantization destroys the off-shell closure of the algebra and that the quantized theory contains gauge artifacts / unphysical gauge d.o.f.!!
    The algebra depends implicitly on the Immirzi parameter β which is still not fully understood and which introduces a quantization ambiguity. A natural choice β=i is not viable b/c it introduces reality conditions which are not fully understood in the canonical framework. For real β the Hamiltonian is awefully complicated. When looking at it from the spin foam perspective the simplicity constrains are somehow related to the reality conditions. But the simplicity constraints become second-class, affect the path integral measure which has not been worked out completely. All this indicates that we should not expect too many insights from the spin-foam approach (as far as I can see the path integral is never able to solve fundamental problems).
    There have been some papers (by Perez?) studying the relation of discretization and quantization; and even discretization in the classical theory. The relation of spin foams and the canonical approach indicates that both approaches are somehow "singular limits" where curvature etc. is located edges / vertices. That could mean that "discretization + quantization" is one major problem. It is clear that discretization affects the constraint algebra in several ways, especially in the path integral approach, so this is another hint that inconsistencies are introduced in an uncontrolled way.
    Unfortunately there is not one paper summarizing these issues. The spin foam community has - to a large extent - decided to work on physical applications instead of consistently defining their theory. The first paper I am aware of is Nicolai's "outside view" from 2005 and Thiemann's reply in his "inside view" from 2006. My feeling was always that Thiemann did not fully address all issues. Then there are Alexandrov's papers from 2010-2012 or so, the best summary I am aware of which discusses many of these issues in detail - unfortunately w/o finding a solution.
    http://arxiv.org/abs/hep-th/0501114
    http://arxiv.org/abs/hep-th/0608210
    http://arxiv.org/abs/1009.4475
    https://www.physicsforums.com/showthread.php?t=545596
    https://www.physicsforums.com/showthread.php?t=544728
    You should have a look at the two threads where we discussed Alexandrov's in-depth analysis of the anomaly problem in detail (but forget his own proposal which did not succeed)
    One remark: it is often said that Alexandrov's papers are outdated b/c they do not take the EPRL/FK models into accout. As far as I can see this is wrong b/c these two approaches do neither address nor solve any of the above mentioned issues! The anomaly problem is still there.
    Another remark: all consistency checks regarding graviton propagators, vertices, semi-classical limit etc. are irrelevant b/c they do not address the regime whe the anomaly would kill the theory.
    I do not know whether the spinor/twistor approach (Wieland's papers) sheds new light on these issues. For me it seems that it's nothing else but the introduction of new variables which is in many ways equivalent to the standard approach (and therefore has the same problems). But perhaps I am overlooking something.
    I do not know whether Thiemann's dust approach will help; as far as I can see there is no progress regarding these anomaly related issues from the Erlangen group.
  14. Jul 25, 2013 #13
    http://arxiv.org/pdf/1101.3294v4.pdf
    "Calculating these constants for the EPRL/FK vertex amplitude appears
    to be a difficult problem, but the solution must exist"
    just optimism...
  15. Jul 25, 2013 #14
    MTd2
    I don't know if you've seen the following talks, but there some talks about Group Field Theory.
  16. Jul 25, 2013 #15
    tom.stoer
    GFT doesn't help;
    And EPRL/FK doesn't help, either. It has intrinsic problems regarding simplicity constraints (2nd class) and it has the cosine-problem.
    My experience from non-abelian gauge theory is that path integrals do not solve but hide conceptual problems. And I am convinced this is true in LQG as well.
  17. Jul 25, 2013 #16
    atyy
    By the time of http://arxiv.org/abs/1208.1463 , Bojowald knew of the signature change which is causing the trouble. The signature change means that if one imposes a gauge that assumes eg. Lorentzian signature at the start, but the mathematics shows Euclidean signature, then that's like a gauge anomaly, which means the procedure is not consistent. But in the same paper, Bojowald writes that the theory makes testable and falsifiable predictions. How can an inconsistent theory make a prediction?
  18. Jul 25, 2013 #17
    MTd2
    He tries to try to solve these problems in these papers:
    http://arxiv.org/abs/1302.5695
    Deformed General Relativity
    Martin Bojowald, George M. Paily
    (Submitted on 19 Dec 2012)
    Deformed special relativity is embedded in deformed general relativity using the methods of canonical relativity and loop quantum gravity. Phase-space dependent deformations of symmetry algebras then appear, which in some regimes can be rewritten as non-linear Poincare algebras with momentum-dependent deformations of commutators between boosts and time translations. In contrast to deformed special relativity, the deformations are derived for generators with an unambiguous physical role, following from the relationship between canonical constraints of gravity with stress-energy components. The original deformation does not appear in momentum space and does not give rise to non-locality issues or problems with macroscopic objects. Contact with deformed special relativity may help to test loop quantum gravity or restrict its quantization ambiguities.
    Quantum matter in quantum space-time
    Martin Bojowald, Golam Mortuza Hossain, Mikhail Kagan, Casey Tomlin
    (Submitted on 22 Feb 2013 (v1), last revised 7 Mar 2013 (this version, v2))
    Quantum matter in quantum space-time is discussed using general properties of energy-conservation laws. As a rather radical conclusion, it is found that standard methods of differential geometry and quantum field theory on curved space-time are inapplicable in canonical quantum gravity, even at the level of effective equation
  19. Jul 26, 2013 #18
    MathematicalPhysicist
    Well if you know some classical logic, then you know that from an inconsistent theory you can prove anything.
  20. Jul 26, 2013 #19
    tom.stoer
    I am not sure whether a quantum anomaly means inconsistency in the sense of 1=2. Usually anomalies mean that a mathematically consistent theory does no longer make sense physically.
  21. Jul 26, 2013 #20
    I am not sure I understand this "does no longer make sense physically."
    I mean for me, physically make sense is that a solution for a PDE for example doesn't diverge at infinity.
    But when we check for physical theories, the only validity (I mean to make it physically sensible) is the experiments that are done to verify or falsify the theory, as long as the maths is consistent (which we assume as well, we can't prove it, we can only disprove its consistency).
Loading...
Similar Threads for dead
B Is supersymmetry dead?
