1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
LT Spice - Bridge Rectifier
  1. Dec 10, 2008 #1
    I am to build a linear power supply in four stages. However, at stage two, i have to add a bridge rectifier to the ouput of my transformer. My lecturer at university says i should get a graph that is a sine wave, with the negative values reflected into the positive x axis (Volatage). I was wondering were am i going wrong?
    2. The attempt at a solution
    http://img399.imageshack.us/img399/1367/ltspice1gm7.jpg [Broken]
    Any help would be greatly appreciated.
    Thanks.
  3. Dec 10, 2008 #2
    You need to plot the difference between rectifidp and rectifidn. Or, alternatively, plot the voltage across your load resistor, R5.
  4. Dec 10, 2008 #3
    Yeah, had a suspicion it might have been that, but it took me a while to work out how to enter an expression. Only started using the program a few days ago, so i'm still getting used to it.
    http://img218.imageshack.us/img218/138/ltspice2rc0.jpg [Broken]
    Many thanks for your help.
  5. Dec 10, 2008 #4
    I've got another problem. For a full wave bridge, with a capacitive filter, we are told the following relationship between Vdc [V(Regout)-V(Rectifidn)] and Vac [V(Secondary)]:
    Vdc = 1.41 x Vac
    However, i'm obtaining the following results:
    http://img386.imageshack.us/img386/5310/lt4vr1.jpg [Broken]
    I'm just wondering if i have the wrong formula, or taking incorrect readings?
    Thanks.
  6. Dec 10, 2008 #5
    Redbelly98
    Staff Emeritus
    A couple of things to keep in mind here:
    That formula uses the rms voltage, not the amplitude, for Vac.
    Also, it does not account for the 2 diode drops in the rectifier voltage.
  7. Dec 10, 2008 #6
    Ah, forgot about rms. Thanks.
    That equation was given a bridge rectifier (4 diodes) with a capacitor and load resistor, but exluding the regulator. So i assume to calculate Vac, if i want Vdc of 5, i simply calculate 5+the voltage acrross the regultor, all divided by 1.41.
  8. Dec 11, 2008 #7
    Redbelly98
    Staff Emeritus
    You can check that on your Spice circuit, "transformer1 stage 5".
    If you plot
    V(rectifidp) - V(rectifidn) ​
    and
    V(secondary) ​
    you can see if the regulator input voltage equals the amplitude of the transformer secondary.
  9. Dec 11, 2008 #8
    Yeah, thanks for your help.
Similar Discussions: LT Spice - Bridge Rectifier
  1. Rectifier Circuit (Replies: 3)
  2. Halfwave rectifier (Replies: 0)
  3. Design of a rectifier (Replies: 27)
Loading...
