• Support PF! Buy your school textbooks, materials and every day products Here!
LTI System Property
Is the following system stable. If so how.
y(t)= [itex]\frac{d}{dt}[/itex] x(t)
I have tried the following proof but i think it is wrong.
PROOF:
  1. The System is LINEAR
  2. The system is time invariant
So on applying the stability criterion for LTI systems
ie . [itex]\int^{\infty}_{-\infty} h(t) dt[/itex] < [itex]\infty[/itex] --------- 1
For the above system h(t) = [itex] \delta^{'}(t)[/itex]
so on applying h(t) = [itex] \delta^{'}(t)[/itex] in eq. 1
[itex]\int^{\infty}_{-\infty} \delta^{'}(t) dt[/itex] = [itex] \delta(0)[/itex]
So the system is not stable.
I think the above proof is way off the mark.
please provide the correct proof. thanks
Answers and Replies
The system (BIBO) stable if the impulse response is absolutely integrable, that is,
[itex]\int^{\infty}_{-\infty} |h(t)| dt < \infty [/itex]
For the differentiator, we have (as you have found in your question)
[itex] h(t) = \delta (t)' [/itex].
Since
[itex] \int^{\infty}_{-\infty} | \delta (t)' | dt= \infty[/itex],
The system is LTI as
[itex]\frac{d}{dt} (a_1x_1(t) + a_1x_1(t)) = a_1 \frac{d}{dt} x_1(t) + a_2 \frac{d}{dt} x_2(t) = a_1y_1(t) + a_2y_2(t)[/itex]
and
[itex]\frac{d}{dt} x(t-\tau) = y(t-\tau)[/itex].
Thanks for your reply but i am trying to find if it is stable or not. i think my derivation is wrong.
here let x(t) be input that is bounded. As you let t-> inifinity, y(t) remains real and bounded, therefore the system is Stable.
if we had y(t) = tx(t), then if t->infinity x(t) is still bounded, but it is being multiplied by a factor of infinity so your output y(t) -> infinity therefore is unstable.
@Larrytsai
you mentioned the following
where x(t) can be any input signal. You say that in the system that i have posted the system is stable since x(t) is stable but i find by intuition that this is not the case if the input signal has discontinuities. At the point of discontinuity the output would then be a DIRAC delta [itex]\delta(t)[/itex] whose value is infinite at t = 0 (http://en.wikipedia.org/wiki/Dirac_delta_function" [Broken]). So by intuition the system is not stable.
The problem is I am unable to provide a rigorous proof to back my intuition. I believe my proof is wrong.
Any help would be appreciated. thanks!
Related Threads on LTI System Property
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
