LUB and GLB Properties
  • Thread starter ragnes
ragnes
1. Prove that an ordered field has the LUB property iff it has the GLB property.
I know that I need to prove that if the ordered field has the GLB property, then it has the LUB property, and that if the ordered field does NOT has the GLB property, then it also does not have the LUB property. I'm just really stuck on how to start the proof - do you assume the ordered field is bounded?
Any help would be appreciated!
Answers and Replies
Dick
26,263
620
Hint: if a set S has a lower bound, what can you say about the set (-1)*S?
ragnes
That it has an upper bound?...
Dick
26,263
620
Yes. And how is the lower bound of S related to the upper bound of (-1)*S?
HallsofIvy
43,021
970
Don't guess! If U is the LUB, it is, first, of all, an upper bound. In other words, for any x in the field, [itex]x\le U[/itex]. Multiplying both sides by -1, [itex]-x\ge -U[/itex]. But if y is any member of the field, x= -y is also in the field and so [itex]y= -x\ge -U[/itex]. That is, -U is a lower bound. Now you need to show it is the greatest lower bound.
Don't forget that this is an "ordered field", not necessarily the field of real numbers. What is meant by "-1"? Have you proven or can you prove that "if a< b, then -a> -b"?
Suggested for: LUB and GLB Properties
  • Last Post
  • Last Post
  • Last Post
  • Last Post
