Maclaurin Series
  • Thread starter wilcofan3
Find the Maclaurin Series for g(x)= (4)/(4+2x+x^2) and its interval of convergence.
I know the Maclaurin Series usually involves taking derivatives but every other problem I've done so far has had a degree that I've solved to. So, other than the general equation for the Maclaurin Series, I'm not sure what other equation is relevant.
At first I thought I might need to use partial fraction decomposition but then I realized the bottom did not factor easily. Do I just start taking derivatives of g(x)? And if so, where do I go from there? I would greatly appreciate a step-by-step breakdown, I think I will understand if someone breaks down the problem. Thanks!
Answers and Replies
6,878
Try dividing 4 by 4 + 2x + x^2, using ordinary polynomial long division. With a Maclaurin series, however you get the series doesn't much matter, since the series representation is unique.
Doing what I suggested above, I get the first three terms as 1 - 1/2 * x - 1/4 * x^2.
HallsofIvy
41,847
965
Another thing you can do is this: complete the square in the denominator to write the fraction as [itex]4/((x+1)^2+ 3)[/itex]. Divide both numerator and denominator by 3 to get (4/3)/((1/3)(x+1)^2+ 1) or (4/3)/(1- (-1/3)(x+1)^2) and think of that as the sum of a power series with first term 4/3 and common ration [itex](-1/3)(x+1)^2[/itex]. That gives the general term as [itex](4/3)(-1/3)^n(x+1)^}{2n}[/itex]. Unfortunately, that is now a Taylor's series, about x=-1, rather than a MacLaurin series!
Related Threads on Maclaurin Series
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
