Maclaurin Series
The Maclaurin series for a function f is given by [tex]\sum\frac{x^n}{2n}[/tex]. What is the value of f(4)(0), the fourth derivative of at x = 0?
a.) 1
b.) 2
c.) 3
d.) 4
e.) 5
The Maclaurin Series is the infinite series centered at x = 0 with the following formula:
f(x) = f(0) + f'(0)x + [tex]\frac{f''(0)x^2}{2!}[/tex] + [tex]\frac{f^n (0)x^n}{n!}[/tex]
I tried differentiating the series starting from f(x) to f4(x) Here is my work:
f(x) = [tex]\sum[/tex][tex]\frac{x^n}{2n}[/tex]
f'(x) = [tex]\sum[/tex][tex]\frac{x^{n-1}}{2}[/tex]
f''(x) = [tex]\sum[/tex][tex]\frac{(n-1)x^{n-2}}{2}[/tex]
f'''(x) = [tex]\sum[/tex][tex]\frac{(n-1)(n-2)x^{n-3}}{2}[/tex]
f4(x) = [tex]\sum[/tex][tex]\frac{(n-1)(n-2)(n-3)x^{n-4}}{2}[/tex]
Therefore:
f4(0) = [tex]\sum[/tex][tex]\frac{(n-1)(n-2)(n-3)(0)}{2}[/tex] = 0.
0 is not in the answer choice. I would like hints please, not answers... what am I doing wrong?
Answers and Replies
Depends on the limit of the sum. Say I gave you [itex]x^5+x^4+x^3+x^2+x+1=\sum_{n=0}^5 x^n[/itex] and asked you what the derivative at zero was, you wouldn't say its zero would you?
HallsofIvy
41,847
965
I think you are making this much too complicated!
The nth term of a MacLaurin series is, as you say,
[tex]\frac{f^{(n)}(0)}{n!}x^n[/tex].
If a power series is [itex]\sum a_nx^n[/itex], then
[tex]\frac{f^{(n)}(0)}{n!}x^n= a_n x^n[/tex]
so
[tex]f^{(n)}(0)= n!a_n[/tex]
In your example, [itex]a_n= 1/2n[/itex].
Thank you. I see what I did wrong now then. I didn't know we can be able to equate the nth term of the MacLaurin with the series.
Thanks again!
Related Threads on Maclaurin Series
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
