Maclaurin Series
  • Thread starter Punkyc7
F(x)= (cos(2x)/(1+x^2))
Is there anyway to do this without taking a lot of derivatives and looking for a pattern?
Answers and Replies
SammyS
Staff Emeritus
1,044
So, I take it that you need to find the Maclaurin Series for the function: f(x) = (cos(2x))/(1+x2) .
How many terms do you need, or do you need to write the result using notation.
If you know the Maclaurin Series for cos(x) and 1/(1+x2) or 1/(1+x), then No, you don't need to take a of derivatives.
The first 3 non zero terms,
I know the Maclaurin series for both of them but when I try doing it like that I don't get the right answer. I have only been able to solve it by taking a bunch of derivatives
SammyS
Staff Emeritus
1,044
What is the series for for each?
Can you multiply (a1+a2+a3+...)·(b1+b2+b3+...) ?
It's: a1b1+a1b2+a2b1+a1b3+a2b2+a3b1...
((-1)^n *((2x)^2n)/(2n!) and (-1^n)((x^2)^n) since our x is -x^2 in the 1/(1+x^2)
Ok so how would you know when to stop the a1 and then move onto the a2 and so on... and yes your allowed to multiply them
SammyS
Staff Emeritus
1,044
I suppose you mean that:
[tex]\cos(2x)=\sum_{n=0}^\infty \ (-1)^n\,\frac{(2x)^{2n}}{(2n)!}[/tex]
and
[tex]\frac{1}{1+x^2}=\sum_{n=0}^\infty \ (-1)^{n}\,x^{2n}[/tex]
Write out the first three terms for each and multiply. Of course group all the terms having the same power of x together.
[tex]\cos(2x)=1-2x^2+\frac{2x^4}{3}-\dots[/tex]
[tex]\frac{1}{1+x^2}=1-\frac{1}{x^2}+\frac{1}{x^4}-\dots[/tex]
Multiply them together.
What term(s) do you multiply, then sum, to get the constant term?
What term(s) do you multiply, then sum, to get the linear (x1) term? -Right, there is none.
What term(s) do you multiply, then sum, to get the squared (x2) term?
Thank you for your help it makes sense now
SammyS
Staff Emeritus
1,044
Cool! Thanks for the THANKS!!! We often don't get that!
Related Threads on Maclaurin Series
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
