How does the compression of a magnetic field affect its strength?
In summary, a magnetic field strength will increase when a magnetic object is compressed. This increase is due to the extra close spacing of the field lines.
Enjoicube
49
Hello All,
I am trying to understand something I read in an article about magnetars and pulsars. The article states that when a magnetic object, such as a star, is compressed, the magnetic field strength increases. Intuitively, this seems true, as the number of field lines will remain constant, but they will become more closely spaced. How is this explained more technically?
One website I visited said the following
"Note, if you compress a magnetic field 'adiabatically' you amplify its strength. For example, a solar magnetic field is on average a few gauss for a star about 1 million kilometers in radius. If you compress this to the size of a neutron star which is 20 kilometers in radius, the magnetic field energy density ( B^2/8 pi) is amplified by the ratio of the volumes which is 1.25 x 10^14. The field strength increases by the square root of 8 x pi times this number or 56 million Gauss for a 1 Gauss initial field. Neutron star fields can be higher than this because the process of core collapse is not exactly adiabatic (ie conserving the magnetic field energy). For highly-conducting bodies, the conserved quantity is the product of the field strength times the radius squared so that for a real star collapsing to a neutron star, the field will increase by (2,000,000/20)^2 = 10 billion times so that a 100 Gauss surface field for a progenitor star that supernovas to become a neutron star, is amplified to a 1 trillion Gauss neutron star surface field"
However i couldn't find anything similar anywhere else.
It is just a kind of "square cube law". The volume of a field is proportional to the radius^3, and energy density is proportional to the field^2. So if you half the radius then you decrease the volume by a factor of 8 so the energy density must be increased by a factor of 8 in order to keep the same total energy and therefore the field must be increased by a factor of sqrt(8).
What is a magnetic field compression?
A magnetic field compression is a phenomenon in which the strength and density of a magnetic field becomes more concentrated in a certain area.
What causes magnetic field compression?
Magnetic field compression is caused by the interaction of charged particles with a magnetic field. This can occur in many different situations, such as solar winds interacting with Earth's magnetic field or when plasma is confined within a magnetic field in a fusion reactor.
Why is magnetic field compression important?
Magnetic field compression is important because it plays a critical role in many natural and man-made processes. It affects the behavior of charged particles, such as electrons and protons, which can impact space weather and influence the functioning of electronic equipment. It is also essential for technologies such as medical imaging and particle accelerators.
How is magnetic field compression measured?
The strength of a magnetic field is typically measured using a device called a magnetometer. This instrument can detect changes in the magnetic field and provide information about its strength and direction. In addition, scientists can also use computer simulations and mathematical models to study and predict magnetic field compression.
Can magnetic field compression be controlled?
While we currently do not have the technology to directly control magnetic field compression, scientists are researching ways to manipulate and shape magnetic fields for various applications. For example, researchers are exploring the use of powerful magnets to control and shape plasma in fusion reactors and to develop new technologies for space propulsion.
  • Astronomy and Astrophysics
10K
  • Electromagnetism
31K
