Magnetic Field in a cilindrical conductor
  1. Feb 22, 2016 #1
    Hey guys, I'm having trouble with a question covering magnectic field on a cilindrical conductor with a cilindrical cavity, here's the question:
    Consider a long cilindrical conductor with radius R1, with a cilindric cavity with radius a, in which R1>a. The axis of both cilinders are paralel, and are separated by a distance D≤R1-a. Assume that there's a uniform current density (J0) flowing through the cilinder's axis. Applying Ampere's law, use the concept of superposition of fields to calculate the resulting magnetic field on points
    a) inside the cavity
    b) outside the cavity but inside the conductor
    c) outside the conductor
    2. Relevant equations
    Ampere's Law
    B=(μ0*i)/2πR
    3. The attempt at a solution
    The attempt is attached below. But I couldn't figure out if the field inside the cavity is the field created by the surroundings of it or the field created by the whole conductor and avaliated inside the cavity. If it's the second option, how can I define it there?
  3. Feb 27, 2016 #2
    Thanks for the post! This is an automated courtesy bump. Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Magnetic Field in a cilindrical conductor
Loading...
