Magnetic Field lines
  • Thread starter abrahamjp
Hello All,
I was just checking magnetic field lines as in attached figure.
I am curious to see some gaps between adjecent field lines in the figure.
Why it is not like a sheath( for example in lighting field) but as lines?
Thanx in advance
Abraham
Answers and Replies
There is actually a continuum of field lines, but only a finite number of discrete lines can be visualized by this method.
Others will probably give more knowledgeable answers, but I suspect that the gaps between the lines of iron fillings are caused by magnetic forces between the fillings themselves.
sophiecentaur
2020 Award
25,377
4,948
Field lines are only a 'construct' to give an idea what the field is doing. There are alternative ways of showing the field. You can write pairs of numbers on a regular grid (magnitude and direction of the magnetic field vector) or you can draw contours of equal potential - but we are not familiar with that way. The spacing between the lines gives an indication of the strength of the field - close together means strong.
When you do the trick with iron filings, the tiny bits of iron actually affect the local H field strength and produce a local B field. This means they tend to stick together in chains. It's a stunning demonstration but you shouldn't read too much into what you see - or expect to get a 'measurement' out of the picture.
The 'holes' in the picture are where the field is too low for the filings to stick together.
Related Threads on Magnetic Field lines
  • Last Post
  • Last Post
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
