Magnetic field problem
  • Thread starter mmainak
mmainak
am stuck on a magnetic field problem, please help me out..
The XOY plane carries a uniform surface current density k`=50 x^ A/m. What is the magnetic field at the point z = -0.5m?
Curl B = mu0J
using stokes theorem
Int[Curl B.ds`]=Int[B.dl`]= Int[mu0 J`.ds`]
B. 2.pi.(.5)=50.pi.(.5)^2
i.e B=25 wb
but the answer is given 10pi.10^-6 wb.
Answers and Replies
Redbelly98
Staff Emeritus
Insights Author
12,134
161
The problem with using a circle for the closed path integral is that B does not point "around the circle" for a surface current. So ∫B·dl is not simply B·circumference.
Instead, B will point along the same direction everywhere on one side of the surface. What shape does that suggest you should use as the closed path, for calculating ∫B·dl?
Suggested for: Magnetic field problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
