Homework Help: Magnetic field problem
  1. Mar 31, 2005 #1
    I don't even know where to begin here, could use a hint =/
    "Two positive ions having same charge q but different masses, m1 and m2, are accelerated horizontally from rest through a potential difference V. They then enter a region where there is a uniform magnetic field B normal to the plan of the trajectory. Show that if the beam entered the magnetic field along the x-axis, the value of the y-coordinate for each ion at any time t is approximately y=Bx^2(q/8mV)^1/2 provided y remains much smaller than x. "
  3. Apr 2, 2005 #2
    Andrew Mason
    You would use the Lorentz force equation:
    [tex]\vec F = ma\hat j = q v\hat i \times B\hat k = qvB\hat j[/tex]
    Determine speed v from [tex]qV = E = \frac{1}{2}mv^2[/tex]
    Since a is in the direction perpendicular to v, it is in the direction of the y axis. So the distance moved in the y direction is
    [tex]y = \frac{1}{2}at^2[/tex]
    and t = x/v
    That should enable you so solve this problem.
    AM
