Homework Help: Magnetic field
  1. Jun 8, 2010 #1
    An ion of charge 1.6 x 10^(-19) C and Kinetic energy 2.0k eV enters perpendicularly into a uniform magnetic field .The ion performs a circular path of radius 4.3 cm .Determine the mass of the ion if the magnetic field intensity is 0.5 T.
    2. Relevant equations
    3. The attempt at a solution
    1/2 mv^2 = 2.0 x 10^3
    mv^2 = 4.0 x 10^3 ---1
    (mv^2)/r=Bev
    mv = (0.5)(1.6 x 10^(-19))(0.043)
    v = [3.44 x 10^(-21) ]/m ---2
    Sub 2 into 1 ,
    m{[3.44 x 10^(-21) ]/m }=4.0 x 10^3
    Solve for m , i got a very small figure which is wrong .
    THe correct answer is 1.84 x 10^(-26) kg
    where did i go wrong ?
  3. Jun 8, 2010 #2
    tiny-tim
    hi thereddevils! :smile:
    don't you have to convert electron-volts into something else?
  4. Jun 9, 2010 #3
    hi tiny tim ,
    what do i hv to convert that too ? I thought electron volt is joules which means enerygy ?
  5. Jun 9, 2010 #4
    tiny-tim
    no, a joule is a coulomb volt, not an electron volt …
    it's the energy if you move something with a coulomb of charge through one volt …
    an electron volt is the energy if you move something with the charge of an electron through one volt …
    joules volts coulombs and so on are SI units, but the electron volt isn't (se the PF Library on electric units ) …
    an electron has 1.602 10-19 coulombs of charge,
    so 1 eV = 1.602 10-19 joules :wink:
  6. Jun 9, 2010 #5
    thanks !
