Magnetic fields and conduction
In summary, a magnetic field is a region in space created by moving electric charges that can exert a force on charged particles. It affects the conduction of electricity by inducing an electric current in conductors. The relationship between magnetic fields and conductivity is that materials with high conductivity can easily conduct electricity in the presence of a magnetic field. Magnetic fields can be shielded or blocked by certain materials and are used in everyday devices and technologies such as electric motors, MRI machines, and household appliances.
jalen
25
12.5A, 3.1x10^-5
How far from a long conductor passing a current of 12.5A is the magentic field of strength 3.1x10^-5T?
B= uI/2(pi)r
r=uI/2(pi)B
=(4pi)(12.5A)/ 2(pi)(3.1x10^-5T)
= 8.1x10^5m
u_0 isn't 4 pi.
This solution is correct. The magnetic field created by a long conductor carrying a current is directly proportional to the current and inversely proportional to the distance from the conductor. In this case, with a current of 12.5A and a magnetic field strength of 3.1x10^-5T, the distance from the conductor is 8.1x10^5m. This calculation is important in understanding the relationship between magnetic fields and conduction, as the strength of the magnetic field can be controlled by adjusting the current and the distance from the conductor. It is also a useful tool in designing and engineering devices that utilize magnetic fields, such as motors and generators.
1. What is a magnetic field and how is it created?
A magnetic field is a region in space that exerts a force on charged particles and can cause them to move. It is created by moving electric charges, such as the flow of current through a wire or the movement of electrons in atoms.
2. How do magnetic fields affect conduction of electricity?
Magnetic fields can induce an electric current in a conductor. This means that if a conductor, such as a wire, is placed in a changing magnetic field, it will experience a force that causes electrons to move, resulting in the flow of electricity.
3. What is the relationship between magnetic fields and conductivity?
The conductivity of a material is directly related to its ability to conduct electricity in the presence of a magnetic field. Materials with high conductivity, such as metals, can easily conduct electricity in the presence of a magnetic field, while materials with low conductivity, such as rubber, have a weaker response to magnetic fields.
4. Can magnetic fields be shielded or blocked?
Yes, magnetic fields can be shielded or blocked by certain materials, such as iron or steel, which are highly permeable to magnetic fields. These materials act as a barrier to the magnetic field, reducing its strength and preventing it from affecting other objects.
5. How are magnetic fields and conduction used in everyday life?
Magnetic fields and conduction are used in a variety of everyday devices, such as electric motors, generators, and transformers. They are also used in technologies like MRI machines and particle accelerators. Additionally, many household appliances, such as refrigerators and washing machines, use magnetic fields and conduction to function.
