Magnetic Fields Shrinking Radius
In summary, a magnetic field is a region of space that is created by moving electric charges and can be detected through a magnetic force. The flux of a magnetic field affects the size of its radius, causing it to decrease as the flux increases. This phenomenon is known as the shrinking radius. The conservation of energy is the cause of this shrinking radius, as the field adjusts its radius to conserve its total energy. Magnetic fields with shrinking radius have practical applications in technologies such as MRI machines and particle accelerators, as well as in research. The shrinking radius of a magnetic field can be reversed by decreasing the flux, but the process may not be instantaneous.
SWFanatic
An elastic conducting material is stretched into a circular loop of 20.0 cm radius. It is placed with its plane perpendicular to a uniform 0.900 T magnetic field. When released, the radius of the loop starts to shrink at an instantaneous rate of 78.0 cm/s. What emf is induced in the loop at that instant?
I am very lost in this section. Any help would be appreciated...just a starting point please! Thanks
What is the definition of flux? How does EMF relate to flux?
I would approach this problem by first understanding the concept of electromagnetic induction. When a conductor, such as the elastic material in this case, moves through a magnetic field, it experiences a change in magnetic flux and an electromotive force (emf) is induced in the conductor. This emf is given by the equation emf = -N(dΦ/dt), where N is the number of turns in the conductor and dΦ/dt is the rate of change of magnetic flux.
In this problem, we are given the radius of the circular loop, the rate at which the radius is shrinking, and the strength of the magnetic field. We can use this information to calculate the rate of change of magnetic flux, dΦ/dt. We know that the magnetic flux through a loop is given by Φ = BA, where B is the magnetic field strength and A is the area of the loop. Since the area of the loop is changing as the radius shrinks, we can use the equation A = πr^2 to find the area at any given time. Therefore, the rate of change of magnetic flux can be calculated as dΦ/dt = B(dA/dt) = 2πBr(dR/dt), where R is the radius of the loop at any given time.
Now, we have all the necessary information to calculate the emf induced in the loop at the given instant. We know the number of turns in the loop (which is not explicitly given in the problem, but we can assume it to be one), the magnetic field strength, and the rate of change of magnetic flux. Plugging these values into the equation for emf, we get emf = -N(dΦ/dt) = -2πBr(dR/dt). Substituting the given values, we get emf = -(1)(0.900 T)(2π)(20.0 cm)(78.0 cm/s) = -354.4 mV.
Therefore, at the instant when the radius of the loop is shrinking at a rate of 78.0 cm/s, an emf of 354.4 mV is induced in the loop. This emf will cause a current to flow in the loop, which can be used to do work or power a device connected to the loop.
1. What is a magnetic field?
A magnetic field is a region of space where a magnetic force can be detected. It is created by moving electric charges, such as those found in magnets or electric currents.
2. How does a magnetic field affect the size of its radius?
A magnetic field has a property called flux, which measures the strength of the field. As the flux of a magnetic field increases, the radius of the field decreases. This is known as the shrinking radius phenomenon.
3. What causes a magnetic field to shrink in radius?
The shrinking radius of a magnetic field is caused by the conservation of energy. As the flux increases, the energy of the magnetic field decreases. The field then adjusts its radius to conserve its total energy.
4. What are some practical applications of magnetic fields with shrinking radius?
Magnetic fields with shrinking radius have several practical applications, such as in MRI machines and particle accelerators. They are also used in research to study the properties of matter and in the development of new technologies.
5. Can a magnetic field's shrinking radius be reversed?
Yes, a magnetic field's shrinking radius can be reversed by decreasing the flux of the field. This can be achieved by reducing the current in an electric current or by moving a magnet away from the field. However, the process of reversing the shrinking radius may not be instantaneous and may depend on the specific properties of the magnetic field.
15K
