Magnetic Fields: Deciphering True/False Questions
In summary, the conversation is about understanding the behavior of magnetic fields and their relationship to charged particles with constant velocity. The main equation being used is F=qvB, but there are some confusing statements to consider. The question is asking which statements are true for a charged particle moving at a constant velocity, and the options include statements about the magnitude and behavior of the magnetic field, as well as the existence of an electric field. The correct equation to use is \v{B} = \mu q \v{v} \times \v{r} / (4\pi r^2).
jazzylady03
Magnetic Fields!
I have to choose which of these are true false. And they are really confusing me.
I know that the equation is F=qvB. However I am not sure what makes the problem different with constant velocity. Any help would be wonderful
Consider a charged particle moving with a constant velocity. Which of the following statements are true?
(Give ALL correct answers: B, AC, BCD.., or None)
A) The magnitude of the magnetic field generated by the charge is zero on the line of the moving charge.
B) The magnitude of the magnetic field generated by the charge is inversely proportional to the charge of the particle.
C) The magnitude of the magnetic field generated by the charge is inversely proportional to the speed of the particle.
D) The magnitude of the magnetic field generated by the charge is proportional to 1/r2 where r is the distance from the charge.
E) There is an electric field generated by the moving charge.
You're using the wrong equation. Try [tex] \v{B} = \mu q \v{v} \times \v{r} / (4\pi r^2) [/tex]
The correct answers are A and D.
A) True - The magnetic field is zero on the line of the moving charge because the particle is not experiencing a force in that direction.
B) False - The magnitude of the magnetic field is proportional to the charge of the particle, not inversely proportional.
C) False - The magnitude of the magnetic field is not affected by the speed of the particle.
D) True - The magnitude of the magnetic field is inversely proportional to the square of the distance from the charge.
E) False - The presence of a magnetic field does not necessarily mean there is also an electric field.
1. What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be detected. It is created by moving electric charges and is represented by imaginary lines called magnetic field lines.
2. How do magnetic fields affect objects?
Magnetic fields can attract or repel certain objects, depending on their magnetic properties. Objects made of iron, nickel, and cobalt are strongly affected by magnetic fields.
3. Can magnetic fields be seen?
No, magnetic fields cannot be seen with the naked eye. However, they can be visualized using tools such as compasses or iron fillings.
4. Do magnetic fields have a direction?
Yes, magnetic fields have a direction. They flow from the north pole of a magnet to the south pole. The direction of a magnetic field can be determined using a compass.
5. How are magnetic fields related to electricity?
Magnetic fields and electricity are closely related. Moving electric charges create magnetic fields, and changing magnetic fields can induce electric currents. This relationship is described by Maxwell's equations and is the basis for technologies such as generators and motors.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
11K
