Which Rod Rotation Induces EMF in a Magnetic Field?
In summary, the action of rotating a conductor about an axis perpendicular to the magnetic field will result in an induced emf due to the change in magnetic flux, while rotating about an axis parallel to the magnetic field or through the midpoint will not result in an induced emf.
Terocamo
47
Which of the following action would cause and e.m.f. induced in the conductor?
1. The rod is rotating about an axis parallel to the B field through one end of the rod.
2. The rod is rotating about an axis perpendicular to the B field through one end of the rod.
3. The rod is rotating about an axis through the mid point perpendicular to the B field.
I know 1 will have a voltage build up and 3 will not but i have trouble understanding 2, the answer said there is emf in rod 2.
Hi there,
I can provide some insight on the electromagnetic induction process and how it applies to the given scenarios.
To understand why there is an induced emf in scenario 2, it is important to first understand the concept of magnetic flux. Magnetic flux is a measure of the amount of magnetic field passing through a given area. When there is a change in magnetic flux, an emf is induced in a conductor.
In scenario 2, the rod is rotating about an axis perpendicular to the magnetic field. This means that the area of the rod that is perpendicular to the magnetic field is changing as it rotates. This change in area results in a change in magnetic flux, which in turn induces an emf in the conductor.
In contrast, in scenario 1, the area of the rod that is perpendicular to the magnetic field remains constant as it rotates. Therefore, there is no change in magnetic flux and no induced emf.
In scenario 3, the axis of rotation is through the midpoint of the rod, which means that the area of the rod perpendicular to the magnetic field is changing, but the change is symmetrical on both sides of the midpoint. This results in an equal and opposite induced emf on either side, canceling each other out and resulting in no net induced emf.
I hope this helps to clarify why there is an induced emf in scenario 2 and not in scenarios 1 and 3. Keep up the good work in your studies!
What is magnetic induction?
Magnetic induction is the process by which a changing magnetic field creates an electric current in a conductor. This phenomenon was first described by Michael Faraday in the 19th century and is the basis for modern technology such as generators and transformers.
What is the magnetic induction problem?
The magnetic induction problem refers to the challenge of predicting and controlling the strength and direction of magnetic fields in a given system. This can be difficult due to the complex and nonlinear nature of magnetic fields.
What are some applications of magnetic induction?
Magnetic induction has many practical applications, such as power generation in generators and motors, data storage in hard drives, and medical imaging in MRI machines. It is also used in industrial processes such as welding and metal refining.
How is magnetic induction calculated?
Magnetic induction is calculated using the mathematical relationship between the strength of a magnetic field, the speed of the changing magnetic field, and the size and shape of the conductor. This is known as Faraday's law of induction.
What are some factors that can affect magnetic induction?
The strength and direction of a magnetic field can be affected by the material it passes through, the presence of other magnetic fields, and the shape and orientation of the conductor. Other factors such as temperature and electrical resistance can also impact magnetic induction.
