Explaining Magnetic Induction - Hello World!
In summary, the formula U[induced] = Flux / t can be used to explain both cases because they both involve a changing magnetic flux being cut by an object. This change in magnetic flux induces a current in the object.
boris16
46
hello
*We are able to explain why current is induced when piece of wire inside MF is pulled with force F[pull] ( wire is thus moving perpendicular to MF or at some angle ):
Example A1:
If we put a wire inside MF and we start moving a part of wire called L ( drawn in green ) with length b to the right with force F[pull], then MF will push each free electron inside L with force F[M] = e[0] * v * B in downward direction ( v is velocity, B is density of MF and e[0] is charge ). That creates current I. BTW, those little X marks represent magnetic field lines going into the screen:
http://img221.imageshack.us/img221/3564/10rf0.png
Magnetic field will ( due to induced current I ) start pulling L in opposite direction of F[pull] --> F[opposite] = -F[pull]
*We can also explain why even if piece of wire is at rest, but instead MF is moving, a current is created inside that wire:
Example A2
Voltage difference in a wire L gets induced even if wire is at rest and we bring a magnet near this wire with velocity v:
http://img75.imageshack.us/img75/4909/14uv9.png
Since magnetic field lines are in a way moving in downward direction, it is as if charges are moving in upward direction and thus charges in a wire will be separated like in the above picture ( it’s not apparent in the picture, but magnetic field lines are almost perpendicular to wire).
Even my book says that if wire is moved parallel with magnetic field lines then there isn't any induced voltage and no current runs and thus no force opposes F[pull].
But then pages later my book suddenly tells us that induced current runs whenever there is change in magnetic flux. And it provides us with an example:
If we have two coils, C1 and C2 and if we put a ferromagnet inside C1 and run a current through C1, then magnetic field lines will go through the second coil and due to change in magnetic flux, a second coil will have an induced current:
http://img486.imageshack.us/img486/6325/feromagnetrc4.png
a)
Now in the examples A1 and A2 one was able to explain why current was induced without the need to resort to magnetic flux lines. But how can we explain why magnetic field exerts force on charges inside coil C2? Unlike with example A2, here even if we pretend that MF is at rest and instead charges are moving in downward direction, the fact remains that charges are moving parallel to magnetic field lines and thus MF shouldn’t exert any force on charges inside coil C2, no matter how much magnetic flux is changing!
b)
IMPORTANT - Even if one accepts the fact that if strength of MF is changing that will cause induced current, but why can both cases ( one where charge is moving and other where strength of MF itself is changing ) be explained by the same formula --> U[induced] = Flux / t
Flux … change in magnetic flux
t … time
With wire moving through the magnetic field we can rationalize why MF created induced current. But if strength of MF itself is changing ( while charge in a wire is at rest ) there is no apparent reason, or even if there is some apparent reason, it's not due to charge weakening MF on one side and strengthening it on the other side.
So why does same formula work for both cases?
bye
There need not be any "charge" in C2 for the magnetic flux to influence. C2 can be without power, which it is. Current flowing in a wire will induce a magnetic field that is concentric around the wire. Consider this diagram:
http://sol.sci.uop.edu/~jfalward/physics17/chapter9/fieldnearwire.jpg
When the power is turned on to the first coil, a magnetic will "spring into being", filling the space around it. And since C2 is in its vicinity, there will be induced current as the changing magnetic flux cuts across C2
t … time
All of your cases have one thing in common, the magnetic flux being cut by the object is changing per unit time. Whether its being cut becuase of a changing magnetic field or moving object. This is all that's needed to induce a current using a magnetic field.. You don't need to complicate things.
Hello! I can provide some explanations for your questions.
a) The force exerted on the charges inside coil C2 can be explained by the Lorentz force law, which states that a charged particle moving in a magnetic field experiences a force perpendicular to both the direction of its motion and the direction of the magnetic field. In this case, the charges inside coil C2 are moving in a direction perpendicular to the magnetic field lines, thus resulting in a force being exerted on them. The changing magnetic flux also plays a role in this force, as it induces the current in the coil, which in turn creates a magnetic field that interacts with the original magnetic field.
b) The formula U[induced] = Flux / t is a simplified version of Faraday's law of induction, which states that the induced electromotive force (EMF) in a closed circuit is equal to the negative of the time rate of change of the magnetic flux through the circuit. This formula works for both cases because in both situations, there is a change in magnetic flux, which results in an induced EMF. In the first case, the change in flux is due to the movement of the wire, while in the second case, it is due to the changing strength of the magnetic field.
I hope this helps to clarify your questions. Let me know if you have any further questions or need more clarification.
1.
What is magnetic induction?
Magnetic induction is the process by which a magnetic field is created in a material when it is placed in the presence of a changing magnetic field. This results in the production of an electric current in the material.
2.
How does magnetic induction work?
Magnetic induction works through the principle of electromagnetic induction, which states that a changing magnetic field will induce an electric current in a conductor. This is due to the movement of electrons within the material in response to the changing magnetic field.
3.
What are some real-world applications of magnetic induction?
Magnetic induction has numerous applications, including generators, motors, transformers, and in wireless charging technology. It also plays a crucial role in the functioning of many electronic devices, such as speakers and hard drives.
4.
What factors affect the strength of magnetic induction?
The strength of magnetic induction is affected by several factors, including the strength and direction of the magnetic field, the distance between the magnetic field and the material, and the material's properties, such as its conductivity and permeability.
5.
How is magnetic induction measured?
Magnetic induction is typically measured using a device called a gaussmeter, which measures the strength of a magnetic field in units of gauss or tesla. The strength of the induced current can also be measured using a voltmeter or ammeter.
