Magnetic Levitation
  1. Aug 25, 2012 #1
    OK, this'll be my first post here.
    I was writing on a topic about magnetism when I realized that I simply don't know enough to answer the question effectively.
    The question is,
    How much energy does it take to magnetically levitate a 180.0 kg mass using the Earth's gravitational field? (That is, using electricity to power an electromagnet to generate another magnetic field)
    Some searching gave me the equation for Magnetic Pressure and Electrical force, but I don't understand how to solve this problem.
    A prompt reply would be appreciated.
    Thanks!
  3. Aug 25, 2012 #2
    Drakkith
    Staff: Mentor
    Hmmm. The problem is that the Earth's magnetic field is very very weak. I saw a thread or two on this in the past and while I don't remember the details I do remember that it required a huge amount of power. So much that I don't think it was possible to levitate something that carried it's own power source.
    Unfortunately I don't know how to figure the force required either lol.
  4. Aug 25, 2012 #3
    i guess use a solenoid to create a strong / almost uniform magnetic field, hang the mass by a wire which is partly in the magnetic field created by the solenoid and run a current through the wire?
  5. Aug 25, 2012 #4
    sophiecentaur
    I remember setting a similar problem which involved calculating how much current a DC electricity cable would have to carry in order to support its own weight in the Earth's field. The BIL = Force formula was all you needed. You could do the same for your solenoid.
    BTW, the answer was a ridiculous value - as you'd expect and which I can't remember - and tells you that the arrangement is self-defeating as you need thick (=heavy) cable to carry the current without melting.
  6. Aug 25, 2012 #5
    Thanks guys, a ridiculous number is what I'm looking for.
    Could you use electrostatic forces to levitate instead and would it be more efficient?
  7. Aug 26, 2012 #6
    Drakkith
    Staff: Mentor
    The Earth isn't charged, so it wouldn't work.
  8. Aug 26, 2012 #7
    Riiiight, silly me.
    Given that I'm calculating for a charged piece of flat metal, not a solenoid, do I need to modify the equation
    F=IBL
    Or can I just get rid of L?
  9. Aug 26, 2012 #8
    Drakkith
    Staff: Mentor
    Why are you using a charged piece of metal?
  10. Aug 26, 2012 #9
    *shrugs*
    Uh, does it affect my calculations?
  11. Aug 26, 2012 #10
    mfb
    2016 Award
    Staff: Mentor
    High current density, and problems with electric resistance? Use superconductors.
    However, the magnetic field of earth is too weak and too homogeneous to levitate an object just based on this field. It is possible to levitate objects with other magnets. With superconductors, this is quite easy and does not require any power to keep it levitating (well ok, you have to cool the superconductor).
  12. Aug 26, 2012 #11
  13. Aug 26, 2012 #12
    Drakkith
    Staff: Mentor
    I'm slightly confused. What exactly are you wanting to calculate?
  14. Aug 26, 2012 #13
    Hi.
    The magnetic FORCE should be 180*9.8 Newton. You do not have to think of ENERGY, do you ?
    Regards.
  15. Aug 26, 2012 #14
    OK, let's clarify some things here.
    MFB, thanks for the recommendation; For the time being I'm just trying to prove how ludicrous it is to do it without the superconductors. I'm getting a result of about 5.7*10^7 Amperes required to counteract a gravitational force of 1765 Newtons, but I'm not sure my equation is correct. I'm just calculating for F=IB because I'm not using a solenoid, so I don't have a figure for L; does this give me a wrong answer?
    sweet springs, I know what the force should be, but I'm trying to figure out if I can simply use F=IBL to calculate Amperage required to levitate magnetically.
  16. Aug 26, 2012 #15
    mfb
    2016 Award
    Staff: Mentor
    I*B is not a force. You need some length scale of your current. However, there is a problem: You cannot create or destroy charges. You always need some way for the charges to return - in the opposite direction, which gives a force downwards.
    Therefore, you cannot simply use the homogeneous part of the magnetic field to levitate something. You have to use its variation in space, and this is extremely small (of the order of (50µT)/(5000km)).
    To get a force of 1N, you already need something like 10^9 Ampere in a loop with 100m^2 internal area (WolframAlpha query) or 10^5 A with an area of 1km^2.
    Superconductors can get current densities of about 10^6A/cm^2, for 10^5 A you need ~0.1cm^2 cable cross-section or ~10g/m cable length (probably more). Ignoring stability issues, this 1km-loop will have a mass of ~50kg and a corresponding force of 500N. As the area scales quadratic with the cable length, scaling the whole system by a factor of 500 would fit - but how do you handle a loop of a really thin wire with a diameter of ~500km?
    Maybe you can improve the setup a bit - use better superconductors, use regions with a larger variation of the magnetic field and so on. But the numbers are so far away from any reasonable setup that I would be extremely surprised if that would help.
    For regular conductors, something like 10^3 A/cm^2 is more realistic. Don't even try ;).
  17. Aug 26, 2012 #16
    Ah, thanks.
    So it has to be a solenoid, and one with a huge diameter, too. Let me see if I understand your point.
    10^9 Amperes * 100 meters^2 * magnetic field of Earth (50 microTeslas/5000km) = 1 Newton of force
    Because I want to use a 25-meter^2 area loop, I can just multiply the Amperage by 4 to get the value for 1 Newton, right? That would give me something ridiculous on the order of 4*10^10 Amperes for a single Newton. (o_O)
    Am I right?
    Right now I'm just calculating for how ridiculous the preposition is. How would using a superconductor affect how practical the premise is?
  18. Aug 27, 2012 #17
    mfb
    2016 Award
    Staff: Mentor
    4 times 10^9 A is just 4*10^9 A, not 4*10^10. Apart from that, you are right, the product of current and area determines the force, if you keep the position of the setup the same and neglect effects of higher order.
    Superconductors have a better current density, so you get more current per cable mass.
    With magnets in the lab as field source, things are much better. You can easily get gradients of 1T/m (and more), which is better by a factor of 10^11. Instead of superconducing rings, you can use a simple superconducting object of any shape, and use the Meissner effect for levitation.
Have something to add?
Similar Discussions: Magnetic Levitation
  1. Levitating magnetism (Replies: 4)
Loading...
