Magnetic slingshot
  • Thread starter soundstone
Main Question or Discussion Point
Hello everyone,
I'm trying to come up with a mathematical formula to calculate the force a magnet will be repelled at based on its current velocity when the charge flips polarity. For example if a point charge is located at (X, Y) and a magnet is being pulled in from position (X + 10, Y + 15) the closer it gets the strong the pull will be as calculated by vector distance and a charge value of the magnets. If when the pulled magnet at (X + 2, Y + 3) flips polarity, it will be shot away from the initial point charge based on the closed in distance between the magnet and initial point charge(ie the closer it is when flipped the stronger the repelling force would be thus making the magnet travel farther away) . I'd like to calculate the new force of repelling away from the point charge. Any help or leads would be greatly appreciated. Thanks in advance.
Regards,
Soundstone
Answers and Replies
davenn
2019 Award
9,238
7,508
Hi Soundstone
welcome to PF :)
from what I have read, a point charge needs to be moving to generate a magnetic field,
when then could interact with your moving magnet's field
have a look at this discussion here on PF and see if it helps.....
https://www.physicsforums.com/showthread.php?t=393658
its one of several threads on the subject, you will find others if you do a forum search on point charges
cheers
Dave
Thanks for the quick reply Dave, maybe a point charge isn't the right term. Say what I was referring to above as the static point charge was more like a magnet constantly generating a field. This magnet would be the triggering mechanism to slingshot a charged particle when placed X distance from the strongest point of the magnet within the field. I am sorry if I'm not explaining this correctly, Thanks again.
Related Threads on Magnetic slingshot
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
11K
