Homework Help: Magnetic susceptibility
  1. Oct 2, 2014 #1
    This is defined by M=XmH.
    Using H=(B/u0)-M to eliminate M gives us M=1/u0(Xm/1+Xm)B, where B is the total magnetic field.
    Now my problem is, my book states that for paramagnetic media, Xm is positive, and for diamagnetic media Xm is negative. Now for paramagnetism, we expect M and B to have the same directions, i.e the constant of proportionality above should be positive - Xm>0 achieves this so it is fine. For diamagnetism however, where M and B have opposite directions, we expect the constant to be negative. If we write the constant as 1/1+1/(Xm) (ignoring the positive u0), we see that Xm<0 achieves this, but only for Xm between 0 and -1. So what the book is saying doesn't seem to be true all the time. The only thing I can see that could save this is that apparently Xm values are typically of the order of around 10-5 so this would be correct - but I don't like how the book doesn't mention something that could theoretically happen so would be grateful if somebody could tell me if I'm right or not, thankyou :)
  3. Oct 3, 2014 #2
    rude man
    B = μ0H + μ0M = μ0H(1 + Xm).
    B cannot be negative!
  4. Oct 3, 2014 #3
    We're dealing with vectors though - I'm not sure what that has to do with anything?
  5. Oct 3, 2014 #4
    Edit: are you possiby claiming this is why Xm is limited between 0 and -1 in terms of the negative values it can take?
  6. Oct 3, 2014 #5
  7. Oct 3, 2014 #6
    rude man
    Not only possibly - definitely!
    What do vectors have to do with it? B nd H are always collinear.
  8. Oct 3, 2014 #7
    Why must B and H be collinear though, I'm struggling to see this - it would solve a few other issues I'm having with this topic too. And It's most likely very obvious...
  9. Oct 3, 2014 #8
    rude man
    B = μH.
    B and H are vectors. μ is a scalar.
    H is a function of current. The current sets up the H field per Ampere's law or more generally by del x H = j (in the absence of time-varying electric fields). j is current density. (In permanent magnets the currents are "amperian" currents not subject to resistive dissipation).
    B is the magnetic field as defined by F = qv x B. B is "generated" by H. In a vacuum, the relation is B = μ0H. If there is magnetic material present, individual domains will align with the H field (what else could they do? They either align with the H field or stay put, or anti-align in the case of predominantly diamagnetic materials. The domains that stay put average to zero net susceptibility. If most of them line up the susceptibility is high (can be > 1000 in certain paramagnetic substances, like iron).).
Have something to add?
Draft saved Draft deleted
