Magnetism & Electrons: Exploring Unusual Transformer Design
In summary: This behavior is not observed in a normal circuit because there is no changing magnetic field to induce a current. In summary, the unusual transformer design described causes a phenomenon known as Lenz's Law, which results in a reduced current when the output is shorted.
dr strangelov
Hi,
Here is magnetism and it`s effect on electrons question for you eggheads.
I am experimenting with a unusual transformer design, it is a flyback transformer ferrite core (square) with a circular secondary spool filled with wire on the outside, a primary coil in the middle wound longitudal to the secondary over a circular spool with a single layer of wire but one half is wound in the opposite direction to the other forming two opposing magnetic fields.The 3rd spool that fits over (nearest) the core is unpopulated at present. I hope this is clear, it is best to draw it from the description to get a clear picture.
The output of the secondary is feed to a full wave rectifier and a scope probe placed across the secondary windings, with the primary pulsed a voltage appears on the scope, now if we short the output of the rectifier the secondary voltage only drops a little. Yes there will be a volt drop across the diodes but it will not account for the still large secondary voltage.
Can anyone explain why the electrons do not seem to flow as you would expect in a normal circuit??
The secondary is wound with pancake coils but i don`t think that should make a difference to the effect i have described.
cheers
Dr strangelove
The question you are asking is related to a phenomenon known as the "Lenz's Law". This law states that an induced current will always be in such a direction that it opposes the change in flux that causes it. In other words, the current created by the magnetic field of the primary coil will always attempt to resist the change in the magnetic field that caused it. Thus, when the output of the rectifier is shorted, the current will still flow, but it will not be as strong as before. The reason for this is that the current created by the magnetic field is now attempting to counteract the short circuit, reducing the overall amount of current flowing through the circuit.
1. What is the purpose of studying magnetism and electrons in transformer design?
The purpose of studying magnetism and electrons in transformer design is to understand the principles and mechanisms behind the functioning of transformers. By understanding the interactions between magnetic fields and electrons, scientists and engineers can design more efficient and effective transformers for various applications.
2. How do magnetism and electrons affect the performance of transformers?
Magnetism and electrons play a crucial role in the performance of transformers. The magnetic field created by the flow of electrons through the transformer's coils is responsible for inducing a voltage in the secondary coil. This voltage is then used to transfer electrical energy from one circuit to another.
3. What are some unusual transformer designs that involve magnetism and electrons?
Some unusual transformer designs that involve magnetism and electrons include the Tesla coil, which uses resonance to produce high-voltage, high-frequency alternating currents, and the flyback transformer, which uses magnetic fields to store and release energy in a continuous cycle.
4. How does the number of windings in a transformer's coils affect its performance?
The number of windings in a transformer's coils directly affects its performance. More windings in the primary coil result in a stronger magnetic field and a higher induced voltage in the secondary coil. This allows for a higher transfer of energy and a more efficient transformer.
5. Are there any practical applications for unusual transformer designs?
Yes, there are practical applications for unusual transformer designs. For example, the Tesla coil is commonly used in high-frequency research and in devices such as radio transmitters and medical equipment. The flyback transformer is used in CRT televisions and computer monitors to generate the high voltage needed for the display to function.
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
