howdoIphysics
- 1
Hey I'm new here so I don't know if this is the right forum, but from what I could see this was the most relevant.
A long solenoid with 50 turns per cm carries a current of 0.2 A. The solenoid is filled with an iron
alloy. The magnetic field B inside the iron alloy is measured to be 1.58 T acting parallel to the axis of
the solenoid.
Calculate the:
i) size of the applied field Bapp;
ii) size of the magnetization M in the iron alloy;
This is my problem really as I don't know so far I've been using the magnetic field of a solenoid = (N/L)
*I*μ0, however I don't know if this correct or if it needs the permeability of the core to produce an accurate value.
I've also been using Bt= Bapp+μ0*M rearranged to M= (Bt-Bapp)/μ0 to answer the second question.
Well this is just plugging numbers into the equations so I'm confident that I haven't done anything wrong here.
Assuming the solenoid field is Bapp, Bapp=5000*0.2*1.3×10−6 = 0.0013.
Putting that into the rearranged equation. M = (1.58 - 0.0013)/1.3×10−6 = 1.2106.
My problem here is those values seem very small and ridiculously large respectively, have I done something wrong or am looking for errors where there are none?
the solenoid.
Calculate the:
