Magnetism Question - Compare Radii of Circular Paths
  • Thread starter cmantzioros
  • Tags
    Magnetism
In summary, magnetism is a fundamental force of nature that causes objects to attract or repel each other based on their magnetic properties. It can also cause charged particles to move in circular paths when they are placed in a magnetic field. The radii of these circular paths are directly proportional to the strength of the magnetic field, the speed of the charged particle, and the mass of the charged particle. The equation r = mv/qB can be used to calculate the radius of a circular path in a magnetic field.
cmantzioros
29
[SOLVED] Magnetism question
A proton, a deuteron and an alpha particle with the same kinetic energies enter a region of uniform magnetic field, moving at right angles to B. Compare the radii of their circular paths.
v = qBR / m
Using the equation above:
K (kinetic energy) = [(q^2)(B^2)(R^2)] / 2m
so (R^2) = (2mK) / [(q^2)(B^2)]
From here, I don't know what to do... How do I compare the radii?
Never mind... got it.
The radii of the circular paths can be compared by looking at the values of R^2 for each particle. Since we are assuming that the kinetic energies (K) and the magnetic field strength (B) are the same for all three particles, the only varying factors are the mass (m) and charge (q) of the particles.
From the equation, we can see that the radius (R) is inversely proportional to the mass (m) and directly proportional to the charge (q). This means that the particle with the smallest mass will have the largest radius, and the particle with the largest charge will also have the largest radius.
In this case, the proton has the smallest mass and the largest charge, so it will have the largest radius. The deuteron has a larger mass than the proton, but a smaller charge, so its radius will be smaller than the proton's. The alpha particle has the largest mass, but the smallest charge, so it will have the smallest radius of the three particles.
Therefore, the order of the radii from largest to smallest is: proton, deuteron, alpha particle.
1. What is magnetism?
Magnetism is a fundamental force of nature that causes objects to attract or repel each other based on their magnetic properties.
2. How is magnetism related to circular paths?
Magnetism can cause charged particles, such as electrons, to move in circular paths when they are placed in a magnetic field.
3. How do the radii of circular paths compare in a magnetic field?
The radii of circular paths in a magnetic field are directly proportional to the strength of the magnetic field and the speed of the charged particle. This means that the larger the magnetic field or the faster the particle is moving, the larger the radius of the circular path will be.
4. What factors can affect the radii of circular paths in a magnetic field?
The strength of the magnetic field, the speed of the charged particle, and the mass of the charged particle can all affect the radius of the circular path in a magnetic field.
5. How can the radius of a circular path be calculated in a magnetic field?
The radius of a circular path can be calculated using the equation r = mv/qB, where r is the radius, m is the mass of the charged particle, v is its velocity, q is its charge, and B is the strength of the magnetic field.
