Magnet Closures for Small Leather Goods
  • Thread starter tamiclay
  • Tags
    Magnets
In summary, the conversation discusses the difficulties in finding a suitable closure for a small wallet size pouch that is used to carry a cell phone and credit cards. Suggestions are made for using a magnet or a Halbach array to close the pouch without interfering with the contents. However, concerns are raised about the potential demagnetization of credit cards and the effects on eelskin wallets.
tamiclay
I produce a small wallet size pouch that I have had a lot of problems figuring out how to make it close without impeding on the design of the pouch. The opening is a little over 3 inches. Its used to carry a cell phone and maybe some credit cards. A magnet would be perfect but for anything to get in the bag it would have to pass the magnet. Perhaps this is a stupid question but is there are magnet that is available that won't pose a problem for the cell phones and demagnatize credit cards - or even some sort of technology other than a zipper or snap that is available on the market that will fit well on a small leather good?
I can suggest a few options for magnet closures on small leather goods that may work for your pouch without causing any interference with the contents inside.
1. Use a magnet with a lower strength: Strong magnets can demagnetize credit cards and interfere with cell phone signals. However, there are weaker magnets available on the market that can still provide a secure closure without causing any harm. Look for magnets with a lower gauss rating, typically less than 1,000 gauss, to avoid any potential damage.
2. Utilize a magnet shield: You can also use a magnet shield or a magnetic field shield to prevent the magnet from affecting the contents inside the pouch. These shields are made of materials that can block or redirect magnetic fields, allowing you to use a stronger magnet for closure without any negative impact.
3. Consider alternative closure options: If you are still concerned about using a magnet, there are other closure options available on the market that may suit your design needs. For instance, you can use a push-button or a hook-and-loop closure, which are commonly used in small leather goods and do not require any magnetic components.
I hope these suggestions help you find a suitable solution for your pouch closure. It is always important to consider the potential effects of magnets on sensitive items like credit cards and cell phones, but with the right approach, you can still achieve a functional and aesthetically pleasing design.
What are magnet closures for small leather goods?
Magnet closures for small leather goods are small magnets used to secure the opening of small leather items such as wallets, purses, and bags. They work by attaching to a metal piece on the opposite side of the leather, creating a secure closure for the item.
How do magnet closures work?
Magnet closures work by using the magnetic force between two magnets. One magnet is attached to the leather item and the other is attached to a metal piece on the opposite side of the leather. When the two magnets are brought close together, they attract and create a secure closure for the item.
Are magnet closures safe to use?
Yes, magnet closures are generally safe to use. However, they should be kept away from electronic devices such as credit cards and phones, as the magnetic force can potentially damage these items.
Can magnet closures be replaced?
Yes, magnet closures can be replaced if they become damaged or worn out. They can be easily removed and replaced with a new magnet closure of the same size and strength.
What is the best type of magnet closure for small leather goods?
The best type of magnet closure for small leather goods depends on personal preference and the type of item it will be used on. Common types include snap closures, button closures, and magnetic clasps. It is important to choose a magnet closure that is strong enough to securely hold the item, but not too strong that it is difficult to open and close.
  • General Engineering
  • Materials and Chemical Engineering
  • General Discussion
  • Astronomy and Astrophysics
  • STEM Academic Advising
15K
