Calculate the difference in height of the fluid levels
In summary: See full answer belowIn summary, a schematic drawing of an open ended well-type manometer is shown, with a well attached to one end of the manometer tube and filled with a fluid with an SG of 2.95. The manometer tube has a diameter of 5mm and the well has a diameter of 50mm. Initially, the pressure on both sides of the manometer is atmospheric, resulting in equal fluid levels. When a gauge pressure of 2.1 psi is applied to the well side, the difference in height of the fluid levels on each side is 0.5m. The fluid level on the well side is depressed by 50mm, while the level on the low pressure side rises by
NZBRU
The figure shows a schematic drawing of an open ended well-type manometer.
Attached to one end of the manometer tube is a well (a reservoir with a higher crossectional
area compared to that of the tube). The manometer is filled with a fluid with an SG = 2.95.
The manometer tube has a diameter of 5mm and the well is cylindrical with a diameter of
50mm.
Initially, with the pressure on both sides of the manometer is atmospheric. The fluid level is
consequently the same on both sides of the manometer. A gauge pressure of 2.1 psi is
applied to the well side of the manometer.
a) Calculate the difference in height of the fluid levels on each side of the manometer.
b) Calculate the amount by which the fluid level on the well side is depressed. Calculate the
amount by which the fluid level on the low pressure side rises.
ΔP = ρgh
[/B]
h = ΔP/ρg
h = 2.1 psi to pas / 2950 kg/m^3 * 9.81
2.1 psi to pas = 14478.99 Pa
So, h = 14478.99/2950*9.81
a) h = 0.5 meaning the difference in height is 0.5m?
b) Not sure what exactly the answer requires. Does it require the height in respect to an algebraic representation of the height of the water initially?
Cheers.
seems right, but you should provide an appropriate number of decimal places, even if the trailing digits are zeroes.
Cheers.
It asks how much of the 0.5m difference is due to the level in the well going down and how much is due to the level in the tube going up. Hint: what do you think the ratio of those two quantities will be?
Thank you for replying :) Well seeing as the narrow section is 5mm wide and the wide section is 50mm wide it could be stated that ten times the volume could fit in the wide section meaning the radio would be- 1n:10w (narrow, wide). So for 500mm
50mm narrow to 450mm wide meaning that the fluid level on the well is depressed by 50mm and the fluid level on the other side is increased by 450mm?
You need to think about that again.
Herpaderp, just realized I had to find the ratio of the who heights from v = 2pir^2 for each side. Thanks for the help, I am pretty sure I have that right now. I do apologize for asking another question a similar question has stumped me. Another question states that:
A U-shaped tube is partially filled with water. One end of the tube is then capped
so that the air in that end is trapped (initially at atmospheric pressure). The tube has a bore
diameter of 10mm. The initial height of the entrapped air gap is 200mm. A gauge pressure of 1500 mmHg is then applied to the other end of the tube.
And asks
Explain how the function of this system is different in principle to the function of a
closed ended manometer used to measure absolute pressure.
Seeing as one end is closed and by knowing the height difference and density of the liquid the the pressure could be calculated. The only difference I could see if that the pressure measured would be at gauge but you could just subtract 1atm in pascals from the calculated result.
And asks
Are you suggesting that the trapped air will be at 1 atm throughout?
One end of the tube is then capped so that the air in that end is trapped (initially at atmospheric pressure) hmm. That does imply that the pressure on that end will change and not be at an atmospheric pressure meaning the absolute pressure at the other end can not be calculated. I assume when it can be the open end of the tube is at 1atm and the other end is where the calculated pressure is.
It can be calculated, if you make certain assumptions about how the volume of the trapped air will change.
I am not familiar with pressure in liquid solutions but I suppose it makes sense that the volume would change if the 1atm gas was sealed as the pressure would change and Pv = NRT meaning v = nRT/P (if the pressure increases then the volume decreases). You could state that the difference is that the volume of the sealed air would decrease meaning that a different calculation would have to be performed.
Yes, that's what I had in mind. But what assumption do you need to make (or extra measurement take) to apply that equation?
I have just realized I have not done the second question correctly which was:
Well the volume of the entrapped gas is 200mm * 2pi(10^2) = 125 663.706 millimeters^3 or 0.000125663706 m^3. The pressure was 1atm or 101 325 pascals. I have no idea what to do with that information.
You quoted the equation PV=nRT. If the pressure is increased to 1500mm Hg, what will happen to the volume? What do you need to assume does not change, in order to use that equation?
1. What does "calculate the difference in height of the fluid levels" mean?
The difference in height of the fluid levels refers to the measurement of the vertical distance between two points on a fluid surface. This calculation is often used in the study of fluid mechanics to determine the pressure and flow of a fluid.
2. How do you calculate the difference in height of the fluid levels?
The difference in height of the fluid levels can be calculated by subtracting the initial height from the final height. This can be done using a ruler or measuring device to determine the height at each point.
3. What units are typically used to measure the height of fluid levels?
The height of fluid levels is typically measured in units of length, such as centimeters, inches, or meters. The specific unit used may depend on the size and scale of the system being studied.
4. Why is it important to calculate the difference in height of the fluid levels?
Calculating the difference in height of the fluid levels is important in understanding the behavior of fluids and their interactions with their surroundings. It can also provide valuable information for practical applications, such as designing efficient fluid systems.
5. Are there any factors that can affect the accuracy of the calculated difference in height of the fluid levels?
Yes, there are several factors that can affect the accuracy of the calculated difference in height of the fluid levels. These include the precision of the measuring device, the conditions of the fluid (such as turbulence or viscosity), and any external forces acting on the fluid (such as gravity or pressure).
  • Classical Physics
  • Other Physics Topics
