Homework Help: Maple help
Tags:
  1. Nov 13, 2014 #1
    Using maple cw version, trying to write a state that will compute f=x/y^2 over several iterations.
    y^2 is changing but x is dependent on a value input my user.
    I don't really know how to write the loop?
    I need the loop to run on an interval of different y values that I can put in and then the x value is determined before the loop begins and is fixed, not sure how to put that in either.
    2. Relevant equations
    f=x/y^2
    3. The attempt at a solution
    I guess I would have to use a do loop,
    do x/y^2
    and I would have to declare the x value
    so x=0 for example
    while y -30.5...30.5
    and then answer=f; printed each time
    or something like that
    I'm not really sure on the syntax I haven't used maple before and the online stuff isn't very helpful.
  3. Nov 13, 2014 #2
    Ray Vickson
    I am going to try attaching a pdf file of a short Maple session that does some of what you want. I have not attached a file to a PF response before, so I don't know if it will work.
    Hooray, it worked!
  4. Nov 14, 2014 #3
    Hi!
    Thanks for the reply.
    I am using a different function than x/y^2 but I am getting an error even though I followed the steps you posted.
    Here is my output.
    > Y:=seq(0+.1*(i-1),i=1..570);
    Y := 0., 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2,
    1.3, 1.4, 1.5, 1.6, 1.7, 1.8, 1.9, 2.0, 2.1, 2.2, 2.3, 2.4,
    2.5, 2.6, 2.7, 2.8, 2.9, 3.0, 3.1, 3.2, 3.3, 3.4, 3.5, 3.6,
    3.7, 3.8, 3.9, 4.0, 4.1, 4.2, 4.3, 4.4, 4.5, 4.6, 4.7, 4.8,
    4.9, 5.0, 5.1, 5.2, 5.3, 5.4, 5.5, 5.6, 5.7, 5.8, 5.9, 6.0,
    6.1, 6.2, 6.3, 6.4, 6.5, 6.6, 6.7, 6.8, 6.9, 7.0, 7.1, 7.2,
    7.3, 7.4, 7.5, 7.6, 7.7, 7.8, 7.9, 8.0, 8.1, 8.2, 8.3, 8.4,
    8.5, 8.6, 8.7, 8.8, 8.9, 9.0, 9.1, 9.2, 9.3, 9.4, 9.5, 9.6,
    9.7, 9.8, 9.9, 10.0, 10.1, 10.2, 10.3, 10.4, 10.5, 10.6, 10.7,
    10.8, 10.9, 11.0, 11.1, 11.2, 11.3, 11.4, 11.5, 11.6, 11.7,
    11.8, 11.9, 12.0, 12.1, 12.2, 12.3, 12.4, 12.5, 12.6, 12.7,
    12.8, 12.9, 13.0, 13.1, 13.2, 13.3, 13.4, 13.5, 13.6, 13.7,
    13.8, 13.9, 14.0, 14.1, 14.2, 14.3, 14.4, 14.5, 14.6, 14.7,
    14.8, 14.9, 15.0, 15.1, 15.2, 15.3, 15.4, 15.5, 15.6, 15.7,
    15.8, 15.9, 16.0, 16.1, 16.2, 16.3, 16.4, 16.5, 16.6, 16.7,
    16.8, 16.9, 17.0, 17.1, 17.2, 17.3, 17.4, 17.5, 17.6, 17.7,
    17.8, 17.9, 18.0, 18.1, 18.2, 18.3, 18.4, 18.5, 18.6, 18.7,
    18.8, 18.9, 19.0, 19.1, 19.2, 19.3, 19.4, 19.5, 19.6, 19.7,
    19.8, 19.9, 20.0, 20.1, 20.2, 20.3, 20.4, 20.5, 20.6, 20.7,
    20.8, 20.9, 21.0, 21.1, 21.2, 21.3, 21.4, 21.5, 21.6, 21.7,
    21.8, 21.9, 22.0, 22.1, 22.2, 22.3, 22.4, 22.5, 22.6, 22.7,
    22.8, 22.9, 23.0, 23.1, 23.2, 23.3, 23.4, 23.5, 23.6, 23.7,
    23.8, 23.9, 24.0, 24.1, 24.2, 24.3, 24.4, 24.5, 24.6, 24.7,
    24.8, 24.9, 25.0, 25.1, 25.2, 25.3, 25.4, 25.5, 25.6, 25.7,
    25.8, 25.9, 26.0, 26.1, 26.2, 26.3, 26.4, 26.5, 26.6, 26.7,
    26.8, 26.9, 27.0, 27.1, 27.2, 27.3, 27.4, 27.5, 27.6, 27.7,
    27.8, 27.9, 28.0, 28.1, 28.2, 28.3, 28.4, 28.5, 28.6, 28.7,
    28.8, 28.9, 29.0, 29.1, 29.2, 29.3, 29.4, 29.5, 29.6, 29.7,
    29.8, 29.9, 30.0, 30.1, 30.2, 30.3, 30.4, 30.5, 30.6, 30.7,
    30.8, 30.9, 31.0, 31.1, 31.2, 31.3, 31.4, 31.5, 31.6, 31.7,
    31.8, 31.9, 32.0, 32.1, 32.2, 32.3, 32.4, 32.5, 32.6, 32.7,
    32.8, 32.9, 33.0, 33.1, 33.2, 33.3, 33.4, 33.5, 33.6, 33.7,
    33.8, 33.9, 34.0, 34.1, 34.2, 34.3, 34.4, 34.5, 34.6, 34.7,
    34.8, 34.9, 35.0, 35.1, 35.2, 35.3, 35.4, 35.5, 35.6, 35.7,
    35.8, 35.9, 36.0, 36.1, 36.2, 36.3, 36.4, 36.5, 36.6, 36.7,
    36.8, 36.9, 37.0, 37.1, 37.2, 37.3, 37.4, 37.5, 37.6, 37.7,
    37.8, 37.9, 38.0, 38.1, 38.2, 38.3, 38.4, 38.5, 38.6, 38.7,
    38.8, 38.9, 39.0, 39.1, 39.2, 39.3, 39.4, 39.5, 39.6, 39.7,
    39.8, 39.9, 40.0, 40.1, 40.2, 40.3, 40.4, 40.5, 40.6, 40.7,
    40.8, 40.9, 41.0, 41.1, 41.2, 41.3, 41.4, 41.5, 41.6, 41.7,
    41.8, 41.9, 42.0, 42.1, 42.2, 42.3, 42.4, 42.5, 42.6, 42.7,
    42.8, 42.9, 43.0, 43.1, 43.2, 43.3, 43.4, 43.5, 43.6, 43.7,
    43.8, 43.9, 44.0, 44.1, 44.2, 44.3, 44.4, 44.5, 44.6, 44.7,
    44.8, 44.9, 45.0, 45.1, 45.2, 45.3, 45.4, 45.5, 45.6, 45.7,
    45.8, 45.9, 46.0, 46.1, 46.2, 46.3, 46.4, 46.5, 46.6, 46.7,
    46.8, 46.9, 47.0, 47.1, 47.2, 47.3, 47.4, 47.5, 47.6, 47.7,
    47.8, 47.9, 48.0, 48.1, 48.2, 48.3, 48.4, 48.5, 48.6, 48.7,
    48.8, 48.9, 49.0, 49.1, 49.2, 49.3, 49.4, 49.5, 49.6, 49.7,
    49.8, 49.9, 50.0, 50.1, 50.2, 50.3, 50.4, 50.5, 50.6, 50.7,
    50.8, 50.9, 51.0, 51.1, 51.2, 51.3, 51.4, 51.5, 51.6, 51.7,
    51.8, 51.9, 52.0, 52.1, 52.2, 52.3, 52.4, 52.5, 52.6, 52.7,
    52.8, 52.9, 53.0, 53.1, 53.2, 53.3, 53.4, 53.5, 53.6, 53.7,
    53.8, 53.9, 54.0, 54.1, 54.2, 54.3, 54.4, 54.5, 54.6, 54.7,
    54.8, 54.9, 55.0, 55.1, 55.2, 55.3, 55.4, 55.5, 55.6, 55.7,
    55.8, 55.9, 56.0, 56.1, 56.2, 56.3, 56.4, 56.5, 56.6, 56.7,
    56.8, 56.9
    > for i from 1 to 570 do
    > if (i=1) then printf("%5s %5s %10s\n", "x", "y", "f(x,y)"):
    > end if:
    > printf("%5.1f %5.1f %10.6f\n", 2.0, Y,f(2.0,Y)):
    > end do:
    x y f(x,y)
    2.0 0.0
    Error, (in fprintf) number expected for floating point format
    > i:='i';
    i := i
  5. Nov 14, 2014 #4
    Mark44
    Staff: Mentor
    You haven't defined your function. The second printf statement prints 2.0, then the value for y (0.0), and then fails to print a value for f(2.0, y).
  6. Nov 14, 2014 #5
    Ray Vickson
    Look again at your printf statement, and compare it (very carefully) with what I wrote in my little worksheet. See the difference?
    Note: I have tried several time, unsuccessfully, to write exactly what you should do, but for reasons I do not understand the PF server changes my message and refuses to print what I submitted. Therefore, I cannot tell you in detail what the problem is! I can try to sneak around the problem however: Y is an array and can only have a singe (first) element printed. What you want to do is compute and print the single value Y-of-i, etc. (The PF server will not even let me put Y-of-i in symbol form!)
  7. Nov 14, 2014 #6
    Ray Vickson
    In addition to the difficulty outlined in my previous response, the PF system also had me responding to you instead of the OP!
  8. Nov 14, 2014 #7
    Mark44
    Staff: Mentor
    The problem is in the bracket notation for arrays. You can write Y[j] but doing so with an index of i, the system thinks you are writing the start tag for italics. Change the index to j or some variable other than i and it will work for you.
  9. Nov 14, 2014 #8
    I did it's just above. I didn't include that part of the output because I know I have that done right.
  10. Nov 14, 2014 #9
    Mark44
    Staff: Mentor
    Try this, which is similar to what Ray was trying to convey:
    Code (Text):
    for j from 1 to 570 do
    > if (j=1) then printf("%5s %5s %10s\n", "x", "y", "f(x,y)"):
    > end if:
    > printf("%5.1f %5.1f %10.6f\n", 2.0, Y[j],f(2.0,Y[j])):
    >end do:
    Note that I changed the loop variable from i to j, because of the way that i inside brackets is displayed here at PF (i.e., as italic). You don't need to change i.
    Also note that in the second printf statement I have Y[j] in two places instead of just Y. The difference is that Y represents the whole array in some form, but what you want is a specific element in the array.
    One other thing. I don't know Maple at all, but if it is anything like C or C++, there's a difference between the = and == operators. The = operator is used for assignment and the == operator is used to determine whether two expressions have the same value. Your 'if (x = 1)' might not be doing what you want it to.
  11. Nov 14, 2014 #10
    Hi,
    If I use this I get error unexpected /
    If take the / out it gives the error, error missing operator or ';'
  12. Nov 14, 2014 #11
    Mark44
    Staff: Mentor
    Where is there a /? I don't see one at all in the code I provided.
  13. Nov 14, 2014 #12
    I got it to work thanks!
  14. Nov 14, 2014 #13
  15. Nov 14, 2014 #14
    Ray Vickson
    That is good to know. Thanks.
  16. Nov 14, 2014 #15
    Ray Vickson
    In Maple, ":=" is the assignment operation, while "=" is either a binary relationship or the signal for an equation, depending on context.
    For example:
    x:=2;
    x := 2
    is(x=2): lprint(%);
    true
    > is(x=1): lprint(%);
    false
    > eq:=y^2=z: lprint(%);
    y^2 = z
    > solve(eq,y): lprint(%);
    z^(1/2), -z^(1/2)
  17. Nov 15, 2014 #16
    Hi,
    If I put in a negative x co-ordinate the it doesn't give me the right output.
    Any ideas on how to fix this?
  18. Nov 15, 2014 #17
    Ray Vickson
    I cannot figure out exactly what your problem is because you have not given us a formula for your function. You must supply more details.
  19. Nov 15, 2014 #18
    The formula for the function is arctan((1.82+x)/y) - arctan(x/y)
  20. Nov 15, 2014 #19
    Ray Vickson
    So, this is related to the "skater" problem you described in another thread (provided that the goal is along the x-axis and the skater travels parallel to the y-axis). If x < 0 the skate-line goes through the inside of the goal, so the two angles add instead of subtract. This is also reflected in your formula, because -arctan(x/y) > 0. What is wrong with that?
  21. Nov 15, 2014 #20
    Mark44
    Staff: Mentor
    If you put in a negative x coordinate for what? Please show us the Maple code that you're talking about.
  22. Nov 15, 2014 #21
    Can I just say that the angle for x=-1 is the same for x=1 because they're the same position just on the opposite side?
    Would that be true?
    I guess I could incorporate a shift so that my x=0 was on the far left of the rink but I have already done a lot of calculations and would rather not start over.
  23. Nov 15, 2014 #22
    Ray Vickson
    No, you cannot claim that the angle for x = -1 is the same as for x = 1, because your x = distance past the right-hand end of the goal. The point x = 1 is at a distance of 1.91 from the center of the goal, while x = -1 is at a distance of -0.09 from the center of the goal. With your choice of variables, the goal's center is at x = -0.91.
  24. Nov 16, 2014 #23
    I chose (0,0) as the middle of the goal line. Is my equation wrong for this?
  25. Nov 16, 2014 #24
    Please respond via dm if you can.
  26. Nov 16, 2014 #25
    Ray Vickson
    Please repeat the equation. The one you wrote before does not seem to fit this new definition of x.
Have something to add?
Draft saved Draft deleted
