Dragonfall
- 1,030
- 4
If I want to indent my code, I use spacebar, but it doesn't do it enough. How can I change the indent size?
To change the code indent size in Maple, go to the "Tools" menu and select "Options". In the "Editor" tab, you will find the option to adjust the indent size under the "Indentation and Tab Settings" section.
Yes, you can change the code indent size for specific sections of your Maple code by using the "Indent Region" and "Unindent Region" options under the "Edit" menu. This will allow you to adjust the indent size for a selected block of code.
The default code indent size in Maple is 4 spaces. However, you can change this to your preferred size by following the steps mentioned in the first question.
Yes, you can change the code indent size in Maple for a specific file by going to the "File" menu and selecting "Properties". In the "Maple Properties" window, you will find an option to change the indent size under the "Editor" tab.
Yes, changing the code indent size in Maple will affect the formatting of your existing code. It is recommended to make the change before writing any code, or you will have to manually adjust the indent size for your existing code.
