Marine Propeller Resistance
  • Thread starter copria
Main Question or Discussion Point
Is there a noticable diffence in torque required to spin a marine propeller at a constant rpm (say 2000rpm) when under a different water column? (5m vs 35m)
Answers and Replies
mgb_phys
7,774
Not much, water isn't very compressible.
ussually the problem is running them near the surface, the impact from air onto the surface of the water causes cavitation.
russ_watters
Mentor
19,716
6,060
note, however, that cavitation is reduced with depth because of the pressure.
If I want to optimize the energy release from cavitation would it be better to have a shallow water column (producing larger amounts of cavitation) or a deep water column (larger force collapsing the cavitation bubble)?
or
Would both cases yield the same energy release?
assuming the propeller is at a constant speed
russ_watters
Mentor
19,716
6,060
Energy release? What energy release?
thermal energy release
russ_watters
Mentor
19,716
6,060
You mean you want to eliminate cavitation, right? Higher pressure reduces/eliminates cavitation, reducing energy/efficiency loss.
No, I want to create cavitation (like a cavitation water heater).
Sorry I did not specify earlier.
Related Threads on Marine Propeller Resistance
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
15K
  • Last Post
