Markov chain question
  • I
  • Thread starter mathman
mathman
560
TL;DR Summary
Requirement for Markov chain.
Given events ##X_i## and the following: ##P(X_3|X_1,X_2)=P(X_3|X_2)## and ##P(X_4|X_1,X_2,X_3)=P(X_4|X_3)## prove ##P(X_4|X_1,X_2)=P(X_4|X_2)##?
Special case proof: Finite number of possibilities for each ##X_i##. Transition matrix from ##X_2## to ##X_4## is product of transitions from ##X_2## to ##X_3## to ##X_4##. Generalize?
Answers and Replies
andrewkirk
Insights Author
1,645
Are you sure this is true? It doesn't feel true. We can partition ##X=X_1\cup X_2\cup X_3\cup X_4## into 15 disjoint subsets ( ##=2^4 - 1##), and the only relationship between their probabilities is that they must be non-negative and sum to ##P(X)##. When we bring in the first two equations above, that still doesn't look like enough constraints on the 15 unknown probabilities to give us the third formula.
Given that, my approach would be to try to construct a counter-example by choosing values for the 15 disjoint components. If we find that we the third formula holds no matter how we change the 15 probabilities, the numbers should give us a clue as to why the relationship holds.
Note this does not use the properties of Markov Chains at all. I can't see how they would relate to the problem as stated.
mathman
560
The givens are the bare bones requirements for a sequence to be a Markov chain.
I couldn't follow you. Could you give the example?
andrewkirk
Insights Author
1,645
A Markov chain is defined as a process in which the probability of future events, as measured at time t, depends only on the state at time t. Markov chains can have continuous or discrete states and they can progress over continuous or discrete time. Finite state processes have finite transition matrices whereas continuous state processes have transition distributions.
How does a formula about four undefined events ##X_1,X_2,X_3,X_4##, with no context, have anything to do with that?
mathman
560
Consider these to be the first four states in a Markov chain. The statements given are the third state depends only on the second, independent of the first, while the fourth state depends only on the third, independent of the first two.
The question is:, ignore the third state. Is the fourth state dependent only on the second, independent of the first?
andrewkirk
Insights Author
1,645
Proof:
Let ##C_t## be the set of possible states at time ##t##.
\begin{align*}
P(X_4|X_1=x_1,X_2=x_2)
\sum_{x_3\in C_3}
P(X_4|X_1=x_1,X_2=x_2, X_3=x_3)
P(X_3=x_3|X_1=x_1,X_2=x_2)
\sum_{x_3\in C_3}
P(X_4|X_3=x_3)
\\ &\quad\quad\textrm{by first given equation}
\sum_{x_3\in C_3}
P(X_4|X_3=x_3)
P(X_3=x_3|X_2=x_2)
\\ &\quad\quad\textrm{by second given equation}
P(X_4=x_4|X_2=x_2)
\end{align*}
To cover the case of continuous states, replace the probabilities by probability density functions and the sums by integrals over the range ##C_3##.
To cover the case of continuous time, replace times 1, 2, 3, 4 by times ##0\le t_1\le t_2\le t_3\le t_4##,
mathman
560
This seems to be what I was looking for. For continuous states I think a proof is unnecessary, since the definition requires it.
Suggested for: Markov chain question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
