Markov Chain - Rat w/4 Rooms
  1. Sep 14, 2008 #1
    I've attached the diagram of 4 rooms, which a rat must move through. Each period he changes his room (his state). As you can see if you click on the image, the rat cannot access room 2 from 3, vice versa.
    If I assume the rat begins in room 1, how do I calculate the probability he will be in room 4 after his second move? I have the transitional probability matrix correct, I'm just not sure how to move forward.
    Thank you,
    Jeff
  3. Sep 15, 2008 #2
    HallsofIvy
    Set up the "transition matrix". According to your picture, if the rat is in room 1, the is a 1/3 chance he will move to each of 2, 3, 4. That means you want your first column to be [0 1/3 1/3 1/3]. That's because you will be multiplying the matrix by a column matrix with entries representing the probability the rat is in room 1, 2, 3, or 4 respectively. If you know for certain the rat is in room 1, then your column matrix is [1 0 0 0] and it is the first column of the matrix that multiplies that first 1.
    Similarly, if the rat is in room 2 the probability is 1/2 that it will move to room 1 and 1/2 that it will move to room 4: the second column in your matrix must be [1/2 0 0 1/2].
    If the rat is in room 3 the probability is also 1/2 that it will move to room 1 and 1/2 that it will move to room 4 so your third column is the same as the second column.
    Finally, if the rat is in room 3, the probability is 1/3 that it will move to room 1, 1/3 that it will move to room 2, and 1/3 that it will move to room 3 so the fourth column is [1/3 1/3 1/3 0].
    Your transition matrix is
    [tex]A= \left[\begin{array}{cccc} 0 & \frac{1}{3} & \frac{1}{3} & \frac{1}{3} \\ \frac{1}{2} & 0 & 0 \frac{1}{2} \\ \frac{1}{2} & 0 & 0 \frac{1}{2} \\ \frac{1}{3} & \frac{1}{3} & \frac{1}{3} & 0\end{array}\right][/tex]
    Is that what you have?
    To find "the probability he will be in room 4 after his second move If the rat begins in room 1" you need to calculate A2 times the column matrix [1 0 0 0].
  4. Sep 15, 2008 #3
    Thanks - that's what I thought, but I wasn't sure about the treatment of the initial probability vector.
    Jeff
