1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Mass And Density Question
  1. Jan 30, 2013 #1
    A steel I beam is 6.44 m long, 32.2 cm high and 14.0 cm wide. The top bottom and sides are all 2.00 cm thick. If the density of the steel is 7.56 x 10^3 kg/m^3, find the mass of the beam.
    2. Relevant equations
    I'm not sure which equations to use actually.
    3. The attempt at a solution
    So what I was thinking was
    The 2 horizontal parts are 14.0cm * 2.00cm = 28 *2 = 56 cm²
    And the 1 vertical part is (32.2cm-4cm) *2cm = 56.4 cm²
    So that is 112.4 cm²
    Converting this to m² would be .01124m²
    After that I'm kind of lost, and I don't even know if THAT'S correct. The thing that's throwing me off is the fact they say there's a length, width, height, and a thickness. Whereas I was taught that thickness and height are the same thing. I don't know how to approach this.
    Could someone explain what the difference between height and thickness here...and if i'm on the right track
    Thanks everyone
  3. Jan 30, 2013 #2
    cepheid
    Staff Emeritus
    Welcome to PF CollegeStudent!
    The reason why there are four dimensions given instead of three is that an I-beam looks like this (like a capital letter I) in cross section):
    Code (Text):
                  w
                                t
            |   t  |  h
                                t
    And "l" is the length of the beam, i.e the distance that this extends "out of your screen." Does that make sense?
    EDIT: I attached a screen shot in case that ASCII diagram looks messed up in other browsers.
  4. Jan 30, 2013 #3
    cepheid
    Staff Emeritus
    One thing that is ambiguous is whether h is the height from the bottom surface of the bottom horizontal section to the top surface of the top horizontal section (i.e. does it include the two thicknesses of those sections), or is it JUST the height of the vertical section, excluding the thicknesses of the horzontal parts. Whatever, just assume something, state explicitly what you assumed, and do the calculation.
  5. Jan 30, 2013 #4
    SteamKing
    Staff Emeritus
    Your calculation of the cross sectional area looks OK.
    Finish the calculation and determine the mass of the beam.
Similar Discussions: Mass And Density Question
  1. Mass Density (Replies: 2)
  2. Density and mass (Replies: 3)
  3. Density mass (Replies: 1)
  4. Density and mass (Replies: 3)
Loading...
