Mass & Conversion Problem
A piece of pipe has an outer radius of 4.5cm, an inner radius of 2.8cm and length of 36cm
The density of the pipe is 7.8 g/cm^3
What is the mass of this pipe? Answer is in unites of kg.
Density=mass/volume
Mass= (density)(volume)
Volume= mass/density
I subtracted the volume of the hollow inside of the tube from the large radius (2.8+4.5cm) and multiplied that by the density given. Then I converted to kg by dividing by 1000. My answer came up to be appx 40 kg. But I believe I'm wrong.
Answers and Replies
Doc Al
Mentor
44,987
1,259
I subtracted the volume of the hollow inside of the tube from the large radius (2.8+4.5cm)...
The outer radius is given as 4.5 cm. (No need to add 2.8+4.5.)
Oh yeah thanks.
I thought that i had to add the radii because the diagram on the page made it seem as if the outer radius was that of only the thickness of the pipe.
Related Threads on Mass & Conversion Problem
  • Last Post
9K
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
