Mass defect and binding energy
  1. Apr 20, 2013 #1
    I don't know if I completely understand mass defect and binding energy so I will write what I understand and hopefully you can explain any misunderstandings I have.
    I know what mass defect is and that I understand that we need the strong nuclear force to keep the nucleus together etc. but I don't understand where binding energy comes from.
    So if we have a proton and a neutron and we bring them together to form a deuterium atom, will some of the mass of each become converted into strong nuclear force to keep them together? Where does the energy liberated come from then? Shouldn't there be energy liberated when two nuclei are fused together? Also, can you explain the effect of gravitational potential energy? Is the decrease in GPE the reason why energy is liberated?
    So basically, where does the energy of mass defect go (becomes strong force?) and where does the energy of fusion reactions come from?
    If we want to separate a nucleus into its constituents, we have to provide energy equivalent to mass defect, correct? According to E=mc^2, the energy put into the system to separate nucleons is transformed into mass, making the final particles heavier (their actual mass). This creates and is equivalent to the mass defect.
    Or does nuclear energy come from either splitting high-mass nuclei or fusing lighter nuclei as this increases the binding energy per nucleon?
    Thank you!
  3. Apr 20, 2013 #2
    mfb
    2016 Award
    Staff: Mentor
    You cannot "convert a mass into a force". The nucleons attract each other, if they merge they release energy, the total energy (in the rest frame) of the system reduces, therefore the mass reduces.
    It is.
    You can have the same effect with gravity (collapsing stars, ...). For nuclei, gravity is irrelevant, however.
    Right
    Those are methods to release energy (by producing nuclei with more binding energy).
  4. Apr 20, 2013 #3
    So nuclear force always exists between any two nucleons and when nucleons come together to create a nucleus, mass defect provides the binding energy, so nuclear force has nothing to do with energy released in nuclear reactions (bombs, etc.). Increasing binding energy causes the liberation of energy in nuclear reactions.
    Thank you!
  5. Apr 20, 2013 #4
    mfb
    2016 Award
    Staff: Mentor
    Its range is very short.
    How did you get that impression? The strong force is the (main) cause for nuclear binding energies, and nuclear bombs just release energy based on the binding energy differences of different nuclei.
  6. Apr 20, 2013 #5
    I didn't use the right words to say what I mean :( I meant to say that when the binding energy per nucleon is increases, energy is liberated (which is ultimately due to nuclear strong force).
  7. Apr 20, 2013 #6
    mfb
    2016 Award
    Staff: Mentor
    Right.
  8. Apr 20, 2013 #7
    Astronuc
    Staff: Mentor
    This is a bit confusing. But nuclear force always exists among nucleons in a nucleus.
    The energy required to break down a nucleus into its component nucleons is called the nuclear binding energy.
    http://www.chem.purdue.edu/gchelp/howtosolveit/Nuclear/nuclear_binding_energy.htm#Top
    The mass defect is merely a measure of the binding energy required to remove a nucleon, or nucleons from a nucleus, or if enough energy could be applied, to dissociate a nucleus into it's constituent components. The mass defect is a manifestation of the nucleons settling into a lower energy state, somewhat analogous to atoms forming molecules.
    The binding energy may be expressed in the form of a gamma ray, or kinetic energy of nuclei, which is the case with most fusion reactions or all fission reactions. In fission, the two nuclei (fission products) are in a tighter bound state (greater binding energy per nucleon) that the nucleus that fissioned. Note that 2 or 3 neutrons are also released in the fission process, as are gamma rays in some cases.
    http://hyperphysics.phy-astr.gsu.edu/hbase/nucene/nucbin.html
    Deuterons can be formed by a proton and neutron combining, in which case a gamma ray is emitted with an energy equivalent to the binding energy, or by pp fusion, in which a positron and neutrino are emitted.
    http://hyperphysics.phy-astr.gsu.edu/hbase/astro/procyc.html#c4
  9. Apr 20, 2013 #8
    Thank you! I think I understand all of it except the last part :(
    "Deuterons can be formed by a proton and neutron combining, in which case a gamma ray is emitted" why are gamma rays emitted? Does this have to do with the nucleons going to a 'lower energy state' and thus releasing energy?
  10. Apr 20, 2013 #9
    Astronuc
    Staff: Mentor
    Neutron capture by a nucleus is usually associated with gamma emission. The reaction is referred to as (n,γ). When a nucleus absorbs a neutron, it changes the nuclear configuration (A -> A+1), and the mass of nucleus is less than the mass of the initial nucleus and free neutron.
    Bascially it has to do with the nucleons forming a more bounded state as compared to the free nucleons.
    Upon neutron absorption, some nuclei form metastable states, which decay by isomeric transition, i.e., gamma emission. This is related to nucleon spin.
    http://epubs.surrey.ac.uk/469/1/fulltext.pdf
  11. May 5, 2013 #10
    I was under the impression that when a particle passes the Coulomb barrier, it releases it's binding energy and enters the nucleus. The mass defect is the summation of the released binding energies of the nucleons in an atom. For instance the mass defect is the difference in mass between an isotope and the sum of the mass of the nucleons in the atom. Is that right?
  12. May 5, 2013 #11
